1868717
1868717
    DYMO
    DYMO - 1868717 - Label Printer Tape, Thermal Transfer, Black on White, 34 mm
1868717 数据手册
XTL Labels TM Heat-Shrink Tube (Pre-Sized) • DYMO XTL™ label makers print directly on Heat-Shrink Tubes • Heat-Shrink Tubes provide insulation when shrunk down and ensure a secure fit on wires and cables with a 3:1 shrink ratio • Constructed of flame-retardant polyolefin sleeves and tested to industry standards • Meets MIL-M-81531, MIL-STD-202G, SAE-DTL-23053/5 (Class 1 & 3) • Durable thermal transfer printing technology – label text won’t smear or fade • RoHS compliant Quick Specs Item Number 1868717 1868718 1868719 Width (mm) 6 12 24 mm DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM Length (mm) 34 34 34 Color A A A Quantity of Pre-Sized Labels 81 65 60 Label Widths 6, 12, 24, 54 mm Tape Platform XTL Printer Compatibility XTL 500 Printing System Thermal Transfer Temperature Rating Max 125°C UL Recognized Component to UL 224 Country of Origin Belgium Material Heat-Shrink Length (mm) Width (mm) Height (mm) Weight (kg) QTY EAN Unit 72 65 120 0.12 1 071701000798 Shelf 215 76 126 0.41 3 30071701000799 Case 400 230 145 2.37 15 50071701000793 Pallet 1200 800 1165 174.31 63 - Unit 72 65 120 0.12 1 071701000804 Shelf 215 76 126 0.41 3 30071701000805 Case 400 230 145 2.37 15 50071701000809 Pallet 1200 800 1165 174.31 63 - Unit 72 65 120 0.12 1 071701000811 Shelf 215 76 126 0.41 3 30071701000812 Case 400 230 145 2.37 15 50071701000816 Pallet 1200 800 1165 174.31 63 - This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC XTL Labels TM Item Number Width Length Color Quantity of Pre-Sized Labels Length (mm) Width (mm) Height (mm) Weight (kg) QTY EAN 72 65 120 0.12 1 071701001092 Unit 1868720 54 34 A 25 Shelf 215 76 126 0.41 3 30071701001093 Case 400 230 145 2.37 15 50071701001097 1200 800 1165 174.31 63 - Pallet Unit 1868731 1868732 6 12 47 47 A A 81 65 Shelf 1868734 24 54 DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM 47 47 A A 60 25 72 65 120 0.12 1 071701001108 215 76 126 0.41 3 30071701001109 50071701001103 Case 400 230 145 2.37 15 Pallet 1200 800 1165 174.31 63 - Unit 72 65 120 0.14 1 071701001115 Shelf 215 76 126 0.47 3 30071701001116 Case 400 230 145 2.67 15 50071701001110 1200 800 1165 174.31 63 - Pallet 1868733 A A Unit 72 65 120 0.12 1 071701001122 Shelf 215 76 126 0.41 3 30071701001123 50071701001127 Case 400 230 145 2.37 15 Pallet 1200 800 1165 174.31 63 - Unit 72 65 120 0.12 1 071701001139 Shelf 215 76 126 0.41 3 30071701001130 Case 400 230 145 2.37 15 50071701001134 Pallet 1200 800 1165 174.31 63 - This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC
1868717 价格&库存
很抱歉,暂时无法提供与“1868717”相匹配的价格&库存,您可以联系我们找货
