1801611
1801611
    DYMO
1801611 数据手册
Facility, Security, and Pro A/V Rhino 4200 ™ All-Purpose Labelling Tool with QWERTY Keyboard Compact, time-saving labelling for on-the-go pros. Get labelling jobs done fast – and done right. The new DYMO Rhino 4200 gets labelling jobs done fast – and done ® ™ right. Easily navigate the familiar QWERTY keyboard. Use one-touch “Hot Key” shortcuts to quickly create and format wire/cable wraps, flags, Code 39 and Code 128 barcodes, fixed-Length labels, breaker labels and more. Print labels up to 19 mm wide in flexible nylon, permanent polyester and durable vinyl materials – PLUS print directly on heat-shrink tubes. Save even more time with great new features – like the ‘Favorites’ key which provides single-key access to commonly used labels, symbols and terms; and the ‘Custom’ key which eliminates repeated steps by saving customized settings. DYMO | Rhino 4200 features: ® ™ 1 Easy to navigate computer-style QWERTY keyboard Quick and comfortable text entry 2 One-Touch “Hot Keys” – a DYMO® exclusive Shortcut keys for creating and formatting wire/cable wraps, flags, Code 39 and Code 128 bar codes, fixed-Length, general and breaker labels 3 Industrial-strength labelling versatility Print 6 mm, 9 mm, 12 mm and 19 mm wide labels in a variety of materials and colours – PLUS print directly on heat-shrink tubes 4  EW “Favorites” key N Single-key access to your most commonly used labels, symbols and terms 5  EW “Custom” key prevents needless repetition N Customize and save settings for individual label formats Li-ion Rechargeable Up to 19 mm 24 mm label widths not for use with the Rhino 4200 ™ LABEL APPLICATIONS Labels that stick and stay stuck. DYMO Industrial labels are tough– jobsite tested and UL recognized. Labels won’t smear or fade and are built with industrial-strength adhesives to resist moisture, UV light and extreme temperatures. Whether you are labelling to OSHA, ISO and ANSI colour standards or labelling in harsh conditions, DYMO Industrial labels have you covered. DYMO Industrial labels are designed to work exclusively with Rhino printers and to perform on a variety of surfaces. ® ® LABEL COLOUR 6 mm 9 mm BLACK ON WHITE – BLACK ON YELLOW – – BLACK ON ORANGE – – BLACK ON GREY – WHITE ON RED 18443 S0718580 12 mm 18444 S0718600 18432 S0718450 18435 19 mm 24 mm 18445 1805430 18433 1805431 S0718620 S0718470 S0718490 S0718500 18436 1805427 – 1805413 1805419 1805425 – – 1805416 1805422 1805429 WHITE ON BLACK – 1805437 1805435 1805436 1805432 WHITE ON GREEN – – 1805414 1805420 1805426 WHITE ON BLUE – – 1805243 1805417 1805423 WHITE ON PURPLE – – 1805415 1805421 1805428 WHITE ON BROWN – – 1805412 1805418 1805424 BLACK ON WHITE 1805442 BLACK ON CLEAR 1805440 1805441 ® ™ LEARN MORE: www.dymo.com/industrial Length 5.5 m VINYL - UL Recognized Component to UL969 - RoHS compliant PERMANENT POLYESTER Length 5.5 m - UL Recognized Component to UL969 - RoHS compliant BLACK ON METALLIC HEAT SHRINK TUBES Length 1.5 m - UL Recognized Component to UL224 - Meets MIL-STD-202G, MIL-M-81531 & SAE-DTL 23053/5 (Class 1 & 3) - RoHS compliant FLEXIBLE NYLON 3:1 BLACK ON WHITE BLACK ON YELLOW 18051 S0718260 18052 18482 S0718240 18508DMO 622289 622290 1805433 18485 18486 18487 1805434 18057 1805443 18058 1805444 S0718160 S0718170 18053 S0718280 18054 S0718290 BLACK ON WHITE – – BLACK ON YELLOW – – 18111 – – – S0718180 18055 S0718300 18056 S0718310 18488 S0718100 18490 S0718080 S0718200 S0718330 S0718340 18489 S0718120 18491 1734524 S0773840 1734525 S0718090 S0773850 18113 – – – – Length 5.5 m - RoHS compliant SELF-LAMINATING 1734523 S0773830 - UL Recognized Component to UL969 - RoHS compliant NON-ADHESIVE TAG 18484 S0718220 S0718270 Length 3.5 m 18483 S0718210 BLACK ON WHITE S0718350 S0718380 Length 5.5 m - RoHS compliant BLACK ON WHITE Rhino 4200 SINGLE UNIT (BLISTER) 1734821 S0773860 For more information or to find out your nearest distributor, please visit www.dymo.com/industrial or call us at (+44) 020 7341 55 29. ™ Code: S0955950 Box includes: • Rhino 4200 printer ™ • Quick reference guide • 19 mm white flexible nylon tape Product specifications: • Runs on optional rechargeable lithium-ion battery pack or 6 AA batteries • 1 year warranty + 1 year extra when registering • Unit weight: 770 gr ©2011 DYMO DYMO bvba, Industiepark-Noord 30 B9100 Sint-Niklaas, Belgium www.dymo.com/industrial ® Optional accessories: • AC adapter Code: S0721430 • Rechargeable lithium-ion battery pack Code: S0895840 S0966970
1801611 价格&库存
很抱歉,暂时无法提供与“1801611”相匹配的价格&库存,您可以联系我们找货
