2125197
2125197
    DYMO
    DYMO - 2125197 - Label Printer, Hand Held, LetraTag 100H, Thermal Transfer, 180 dpi
2125197 数据手册
AVAILABLE FOR LIMTED TIME & VOLUMES ONLY LetraTag® 100H Special Edition HANDHELD LABEL MAKER IDEAL FOR THE OFFICE OR HOME • Large graphical display enables you to see text effects on screen before you print • Prints 5 font sizes, 7 text styles and 8 frames • 9-label memory • Date stamping • 195 symbols • Auto-off power saver • Easy-to-use navigation buttons for fast access to special features • Prints 1 or 2 lines per label (12mm width) • Prints on paper, plastic, metallic and iron-on LetraTag® labels*** • Uses 4 AA batteries (not included) Quick Specs Base Unit Includes: Unit Dimensions (H x W x L) • LetraTag® 100H Label Maker • L  T Paper Label Cassette, Black On White, 12mm X 4m • Instruction Manual • 1-Year Limited Warranty Card Item Number 2125197 Description LetraTag® 100H ABC BLACK Unit 265mm x 120mm x 84mm Weight (excluding battery) 0.4 kg Mac®/PC Compatible No Accepts Label Sizes 12mm Tape Platform LT Resolution 180 dpi Printing System Direct Thermal Print Speed 12mm/sec Cutter Type Manual Batteries 4 AA (not included) Adapter No Networking No Country of Origin China Length (cm) Width (cm) Height (cm) QTY EAN 8.4 12.0 26.5 1 3026981251979 Customer Price www.DYMO.com *** MADE IN EUROPE FABRIQUÉ EN EUROPE BELGIUM PLASTIC 12 mm PAPER 12 mm METALLIC 12 mm FABRIC IRON 12 mm ABC S0721660 S0721520 - S0718840 (2 m LENGTH ONLY) ABC S0721550 - - - ABC S0721680 - - - ABC S0721700 - - - ABC S0721690 - - - ABC S0721670 - - - ABC - - S0721750 - LETRATAG® 3-TAPE STARTER PACK (4 m) PLASTIC 12 mm LETRATAG® LABELS (4 m) ABC S0721800 ABC ABC LetraTag® Plastic LetraTag® Paper Wipeable, tear resistant and easy-to-use. Come in a variety of colours for added visual impact and easy communication Non-glossy labels are easy to peel and cut, with quick-change cassettes for on-the-fly labeling. LetraTag® Fabric Iron-On LetraTag® Metallic No more sewing labels into clothing, towels or backpacks. Simply print the label, then iron it right into the fabric. Give some flair to your labeling efforts with a metallic look. The DYMO® high quality labels are made in Belgium © 2020 Newell Brands *** DYMO® labels are made in Europe This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change.
2125197 价格&库存
很抱歉,暂时无法提供与“2125197”相匹配的价格&库存,您可以联系我们找货
