1868796
1868796
    DYMO
    DYMO - 1868796 - LABEL TAPE, 0.47" X 22.9FT, WHITE/BLACK
1868796 数据手册
XTL Labels TM All-Purpose Vinyl Quick Specs • From textured surfaces to cables, vinyl labels are ideal for almost any labeling application • Vinyl offers moisture, chemical and UV resistance, making it ideal for labeling both indoors and outdoors • Available in a wide range of colors that fit with OSHA, ANSI, and ISO color standards to enhance workplace communication and safety • RoHS compliant • Easy-to-peel split back design makes applying labels quick and easy Label Widths 12, 19, 24, 38, 54 mm Tape Platform XTL Printer Compatibility XTL 300: Up to 24 mm wide XTL 500: Up to 54 mm wide Label Length 7m Printing System Thermal Transfer Temperature Rating -40°C to 60°C UL Recognized Yes, component to UL969 Country of Origin Belgium Material Vinyl • Durable thermal transfer printing technology – label text won’t smear or fade • Labels comply with ANSI/TIA 606-B standards Dimensions for 12 mm All-Purpose Vinyl Unit Length (mm) Width (mm) Height (mm) Weight (kg) QTY 72 35 120 0.063 1 Shelf 215 76 126 0.42 6 Case 400 230 145 2.4 30 Pallet 1200 800 1165 176.2 63 Item Number Width Color EAN Unit EAN Shelf EAN Case EAN Pallet 1868741 12 mm A 071701001207 30071701001208 50071701001202 – 1868746 12 mm A 071701001252 30071701001253 50071701001257 – 1868751 12 mm A 071701001306 30071701001307 50071701001301 – 1868756 12 mm A 071701001351 30071701001352 50071701001356 – 1868761 12 mm A 071701001405 30071701001406 50071701001400 – 1868766 12 mm A 071701001405 30071701001406 50071701001400 – 1868771 12 mm A 071701001504 30071701001505 50071701001509 – 1868776 12 mm A 071701001559 30071701001550 50071701001554 – 1868781 12 mm A 071701001603 30071701001604 50071701001608 – 1868786 12 mm A 071701001658 30071701001659 50071701001653 – 18687891 12 mm A 071701001689 30071701001680 50071701001684 – 1868796 12 mm A 071701001757 30071701001758 50071701001752 – 1868801 12 mm A 071701001801 30071701001802 50071701001806 DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC XTL Labels TM Dimensions for 19 mm All-Purpose Vinyl Length (mm) Width (mm) Height (mm) Weight (kg) QTY Unit 72 35 120 0.08 1 Shelf 215 76 126 0.54 6 Case 400 230 145 2.98 30 Pallet 1200 800 1165 213.05 63 Item Number Width Color EAN Unit EAN Shelf EAN Case EAN Pallet 1868742 19 mm A 071701001214 30071701001215 50071701001219 – 1868747 19 mm A 071701001269 30071701001260 50071701001264 – 1868752 19 mm A 071701001313 30071701001314 50071701001318 – 1868757 19 mm A 071701001368 30071701001369 50071701001363 – 1868762 19 mm A 071701001412 30071701001413 50071701001417 – 1868767 19 mm A 071701001412 30071701001413 50071701001417 – 1868772 19 mm A 071701001511 30071701001512 50071701001516 – 1868777 19 mm A 071701001566 30071701001567 50071701001561 – 1868782 19 mm A 071701001610 30071701001611 50071701001615 – 1868787 19 mm A 071701001665 30071701001666 50071701001660 – 1868792 19 mm A 071701001719 30071701001710 50071701001714 – 1868797 19 mm A 071701001719 30071701001710 50071701001714 – 1868802 19 mm A 071701001818 30071701001819 50071701001813 – Dimensions for 24 mm All-Purpose Vinyl Length (mm) Width (mm) Height (mm) Weight (kg) QTY Unit 120 35 120 0.09 1 Shelf 215 76 126 0.61 6 Case 400 230 145 3.34 30 Pallet 1200 800 1165 235.73 63 Item Number Width Color EAN Unit EAN Shelf EAN Case EAN Pallet 1868743 24 mm A 071701001221 30071701001222 50071701001226 – 1868748 24 mm A 071701001276 30071701001277 50071701001271 – 1868753 24 mm A 071701001320 30071701001321 50071701001325 – 1868758 24 mm A 071701001375 30071701001376 50071701001370 – 1868763 24 mm A 071701001429 30071701001420 50071701001424 – 1868768 24 mm A 071701001474 30071701001475 50071701001479 – 1868773 24 mm A 071701001528 30071701001529 50071701001523 – 1868778 24 mm A 071701001573 30071701001574 50071701001578 – 1868783 24 mm A 071701001627 30071701001628 50071701001622 – 1868788 24 mm A 071701001672 30071701001673 50071701001677 – 1868793 24 mm A 071701001726 30071701001727 50071701001721 – 1868798 24 mm A 071701001771 30071701001772 50071701001776 – 1868803 24 mm A 071701001276 30071701001277 50071701001271 – DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC XTL Labels TM Dimensions for 38 mm All-Purpose Vinyl Unit Length (mm) Width (mm) Height (mm) Weight (kg) QTY 72 65 120 0.14 1 Shelf 215 76 126 0.47 6 Case 400 230 145 2.67 15 Pallet 1200 800 1165 193.21 63 Item Number Width Color EAN Unit EAN Shelf EAN Case EAN Pallet 1868744 38 mm A 071701001238 30071701001239 50071701001233 – 1868749 38 mm A 071701001283 30071701001284 50071701001288 – 1868754 38 mm A 071701001337 30071701001338 50071701001332 – 1868759 38 mm A 071701001382 30071701001383 50071701001387 – 1868764 38 mm A 071701001436 30071701001437 50071701001431 – 1868769 38 mm A 071701001481 30071701001482 50071701001486 – 1868774 38 mm A 071701001535 30071701001536 50071701001530 – 1868779 38 mm A 071701001580 30071701001581 50071701001585 – 1868784 38 mm A 071701001634 30071701001635 50071701001639 – 1868789 38 mm A 071701001689 30071701001680 50071701001684 – 1868794 38 mm A 071701001733 30071701001734 50071701001738 – 1868799 38 mm A 071701001788 30071701001789 50071701001783 – 1868804 38 mm A 071701001832 30071701001833 50071701001837 – EAN Unit EAN Shelf EAN Case EAN Pallet Dimensions for 54 mm All-Purpose Vinyl Unit Length (mm) Width (mm) Height (mm) Weight (kg) QTY 72 65 120 0.18 1 Shelf 215 76 126 0.58 3 Case 400 230 145 3.19 6 Pallet 1200 800 1165 226.28 63 Item Number Width Color 1868745 54 mm A 071701001245 30071701001246 50071701001240 – 1868750 54 mm A 071701001290 30071701001291 50071701001295 – 1868755 54 mm A 071701001344 30071701001345 50071701001349 – 1868760 54 mm A 071701001399 30071701001390 50071701001394 – 1868765 54 mm A 071701001443 30071701001444 50071701001448 – 1868770 54 mm A 071701001498 30071701001499 50071701001493 – 1868775 54 mm A 071701001542 30071701001543 50071701001547 – 1868780 54 mm A 071701001597 30071701001598 50071701001592 – 1868785 54 mm A 071701001641 30071701001642 50071701001646 – 1868790 54 mm A 071701001696 30071701001697 50071701001691 – 1868795 54 mm A 071701001740 30071701001741 50071701001745 – 1868800 54 mm A 071701001795 30071701001796 50071701001790 – 1868805 54 mm A 071701001849 30071701001840 50071701001844 – DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC
1868796 价格&库存
很抱歉,暂时无法提供与“1868796”相匹配的价格&库存,您可以联系我们找货
