XTL Labels
TM
All-Purpose Vinyl
Quick Specs
• From textured surfaces to cables, vinyl labels are ideal for almost any
labeling application
• Vinyl offers moisture, chemical and UV resistance, making it ideal for
labeling both indoors and outdoors
• Available in a wide range of colors that fit with OSHA, ANSI, and ISO
color standards to enhance workplace communication and safety
• RoHS compliant
• Easy-to-peel split back design makes applying labels quick and easy
Label Widths
12, 19, 24, 38, 54 mm
Tape Platform
XTL
Printer Compatibility
XTL 300: Up to 24 mm wide
XTL 500: Up to 54 mm wide
Label Length
7m
Printing System
Thermal Transfer
Temperature Rating
-40°C to 60°C
UL Recognized
Yes, component to UL969
Country of Origin
Belgium
Material
Vinyl
• Durable thermal transfer printing technology – label text won’t smear or fade
• Labels comply with ANSI/TIA 606-B standards
Dimensions for 12 mm All-Purpose Vinyl
Unit
Length
(mm)
Width
(mm)
Height
(mm)
Weight
(kg)
QTY
72
35
120
0.063
1
Shelf
215
76
126
0.42
6
Case
400
230
145
2.4
30
Pallet
1200
800
1165
176.2
63
Item Number
Width
Color
EAN Unit
EAN Shelf
EAN Case
EAN Pallet
1868741
12 mm
A
071701001207
30071701001208
50071701001202
1868746
12 mm
A
071701001252
30071701001253
50071701001257
1868751
12 mm
A
071701001306
30071701001307
50071701001301
1868756
12 mm
A
071701001351
30071701001352
50071701001356
1868761
12 mm
A
071701001405
30071701001406
50071701001400
1868766
12 mm
A
071701001405
30071701001406
50071701001400
1868771
12 mm
A
071701001504
30071701001505
50071701001509
1868776
12 mm
A
071701001559
30071701001550
50071701001554
1868781
12 mm
A
071701001603
30071701001604
50071701001608
1868786
12 mm
A
071701001658
30071701001659
50071701001653
18687891
12 mm
A
071701001689
30071701001680
50071701001684
1868796
12 mm
A
071701001757
30071701001758
50071701001752
1868801
12 mm
A
071701001801
30071701001802
50071701001806
DISTRIBUTED BY:
Newell Europe Sàrl
Chemin de Blandonnet 10
1214 Vernier – Switzerland
WWW.DYMO.COM
This information is being provided for general information purposes and the compliance
standards and certifications referenced herein are based on current standards which are subject to change.
©2015 Newell Europe LLC
XTL Labels
TM
Dimensions for 19 mm All-Purpose Vinyl
Length
(mm)
Width
(mm)
Height
(mm)
Weight
(kg)
QTY
Unit
72
35
120
0.08
1
Shelf
215
76
126
0.54
6
Case
400
230
145
2.98
30
Pallet
1200
800
1165
213.05
63
Item Number
Width
Color
EAN Unit
EAN Shelf
EAN Case
EAN Pallet
1868742
19 mm
A
071701001214
30071701001215
50071701001219
1868747
19 mm
A
071701001269
30071701001260
50071701001264
1868752
19 mm
A
071701001313
30071701001314
50071701001318
1868757
19 mm
A
071701001368
30071701001369
50071701001363
1868762
19 mm
A
071701001412
30071701001413
50071701001417
1868767
19 mm
A
071701001412
30071701001413
50071701001417
1868772
19 mm
A
071701001511
30071701001512
50071701001516
1868777
19 mm
A
071701001566
30071701001567
50071701001561
1868782
19 mm
A
071701001610
30071701001611
50071701001615
1868787
19 mm
A
071701001665
30071701001666
50071701001660
1868792
19 mm
A
071701001719
30071701001710
50071701001714
1868797
19 mm
A
071701001719
30071701001710
50071701001714
1868802
19 mm
A
071701001818
30071701001819
50071701001813
Dimensions for 24 mm All-Purpose Vinyl
Length
(mm)
Width
(mm)
Height
(mm)
Weight
(kg)
QTY
Unit
120
35
120
0.09
1
Shelf
215
76
126
0.61
6
Case
400
230
145
3.34
30
Pallet
1200
800
1165
235.73
63
Item Number
Width
Color
EAN Unit
EAN Shelf
EAN Case
EAN Pallet
1868743
24 mm
A
071701001221
30071701001222
50071701001226
1868748
24 mm
A
071701001276
30071701001277
50071701001271
1868753
24 mm
A
071701001320
30071701001321
50071701001325
1868758
24 mm
A
071701001375
30071701001376
50071701001370
1868763
24 mm
A
071701001429
30071701001420
50071701001424
1868768
24 mm
A
071701001474
30071701001475
50071701001479
1868773
24 mm
A
071701001528
30071701001529
50071701001523
1868778
24 mm
A
071701001573
30071701001574
50071701001578
1868783
24 mm
A
071701001627
30071701001628
50071701001622
1868788
24 mm
A
071701001672
30071701001673
50071701001677
1868793
24 mm
A
071701001726
30071701001727
50071701001721
1868798
24 mm
A
071701001771
30071701001772
50071701001776
1868803
24 mm
A
071701001276
30071701001277
50071701001271
DISTRIBUTED BY:
Newell Europe Sàrl
WWW.DYMO.COM
XTL Labels
TM
Dimensions for 38 mm All-Purpose Vinyl
Unit
Length
(mm)
Width
(mm)
Height
(mm)
Weight
(kg)
QTY
72
65
120
0.14
1
Shelf
215
76
126
0.47
6
Case
400
230
145
2.67
15
Pallet
1200
800
1165
193.21
63
Item Number
Width
Color
EAN Unit
EAN Shelf
EAN Case
EAN Pallet
1868744
38 mm
A
071701001238
30071701001239
50071701001233
1868749
38 mm
A
071701001283
30071701001284
50071701001288
1868754
38 mm
A
071701001337
30071701001338
50071701001332
1868759
38 mm
A
071701001382
30071701001383
50071701001387
1868764
38 mm
A
071701001436
30071701001437
50071701001431
1868769
38 mm
A
071701001481
30071701001482
50071701001486
1868774
38 mm
A
071701001535
30071701001536
50071701001530
1868779
38 mm
A
071701001580
30071701001581
50071701001585
1868784
38 mm
A
071701001634
30071701001635
50071701001639
1868789
38 mm
A
071701001689
30071701001680
50071701001684
1868794
38 mm
A
071701001733
30071701001734
50071701001738
1868799
38 mm
A
071701001788
30071701001789
50071701001783
1868804
38 mm
A
071701001832
30071701001833
50071701001837
EAN Unit
EAN Shelf
EAN Case
EAN Pallet
Dimensions for 54 mm All-Purpose Vinyl
Unit
Length
(mm)
Width
(mm)
Height
(mm)
Weight
(kg)
QTY
72
65
120
0.18
1
Shelf
215
76
126
0.58
3
Case
400
230
145
3.19
6
Pallet
1200
800
1165
226.28
63
Item Number
Width
Color
1868745
54 mm
A
071701001245
30071701001246
50071701001240
1868750
54 mm
A
071701001290
30071701001291
50071701001295
1868755
54 mm
A
071701001344
30071701001345
50071701001349
1868760
54 mm
A
071701001399
30071701001390
50071701001394
1868765
54 mm
A
071701001443
30071701001444
50071701001448
1868770
54 mm
A
071701001498
30071701001499
50071701001493
1868775
54 mm
A
071701001542
30071701001543
50071701001547
1868780
54 mm
A
071701001597
30071701001598
50071701001592
1868785
54 mm
A
071701001641
30071701001642
50071701001646
1868790
54 mm
A
071701001696
30071701001697
50071701001691
1868795
54 mm
A
071701001740
30071701001741
50071701001745
1868800
54 mm
A
071701001795
30071701001796
50071701001790
1868805
54 mm
A
071701001849
30071701001840
50071701001844
DISTRIBUTED BY:
Newell Europe Sàrl
WWW.DYMO.COM
很抱歉,暂时无法提供与“1868771”相匹配的价格&库存,您可以联系我们找货
