2094492
2094492
    DYMO
    DYMO - 2094492 - Label Manager Case Kit, 3 Year Warranty, Thermal, Hand Held, 180 dpi
2094492 数据手册
LabelManager™ 210D CREATE LABELS FAST WITH SMART KEYS Customize labels using Computer-style keyboard and one-touch Smart Keys for fast formatting Features • Large LCD display • Computer-style keyboard • One-touch Smart Keys for fast formatting • Long lasting rechargeable battery pack • 20+ ways to format text • 200+ symbols and clip-art images • Print up to 1/2 in (12 mm) wide labels REACH RoHS ISO 9001 ISO 14001 No ink or toner required Single Unit Includes: • LabelManager 210D Quick Specs • D  1 Starter Label Cassette, 12mm x 3m Black On White • Quick Start Guide Unit Dimensions (H x W x L) 155 x 165 x 64 mm Weight (excluding battery) 435 g Mac /PC Compatible No Accepts Label Sizes 6mm, 9mm and 12mm Tape Platform D1, Durables Resolution 180 dpi Printing System Thermal Transfer Print Speed 12 mm/sec Barcodes No Cutter Type Manual Batteries 6 AA (not included) • Charging Adapter Adapter Yes (optional, sold separately) • 2 + 1 - Year Limited Warranty* Networking No Country of Origin China ® • 2 + 1 - Year Limited Warranty* Kit Includes: • LabelManager 210D + Softcase Bag • D  1 Starter Label Cassette, 12mm x 3m Black On White • Quick Start Guide Item Number Description Length (cm) Width (cm) Height (cm) QTY EAN S0784440 LabelManager 210D QWERTY 9.7 22.2 20.3 1 3501170784440 2094492 LabelManager 210D QWERTY KIT 6.4 16.5 15.5 1 3501170964071 11.5 6.0 9.0 1 - Customer Price Accessories (www.dymo.com) S0721430 Charging Adapter * +1 year if registered on the Dymo website www.DYMO.com TE WA R 100% recycled material used for external cassette BA SED +40% of DYMO® labels are produced* using „Water based solvents“. MADE IN EUROPE DYMO® high quality labels are made in Belgium BELGIUM D1 Standard Polyester Labels For hundreds of tasks around the office or home office, such as filing, storage and asset tracking. Temperature rating: -18°C to 90°C D1 STANDARD LABELS (7 m) 6 mm 9 mm 12 mm ABC S0720780 S0720680 S0720530 ABC S0720770 S0720670 S0720500 ABC S0720790 S0720730 S0720580 ABC - S0720710 S0720560 ABC - S0720740 S0720590 ABC - S0720720 S0720570 ABC - - S0720610 ABC - S0720690 S0720540 ABC - - S0720510 ABC - - S0720600 ABC - S0720700 S0720550 ABC - - S0720520 D1 STANDARD MULTIPACKS (7 m) 6 mm 9 mm 12 mm - 2093096 2093097 ABC D1 Durable Vinyl Labels Industrial strength adhesive helps to ensure labels stay stuck to a variety of surfaces. Temperature rating: -40˚C to 80˚C D1 DURABLE LABELS (3 m) 12 mm ABC 1978366 ABC 1978365 ABC 1978367 D1 DURABLE LABELS (5.5 m) 12 mm ABC 1978364 D1 Permanent Polyester Labels Professional, polished finish ideal for panels, blocks, faceplates, shelves, bins and more. Temperature rating: -40˚C to 150˚C* D1 PERMANENT POLYESTER (5.5 m) 12 mm ABC S0718060 *depends on surface D1 Flexible Nylon Labels Specifically designed for curved surfaces and wire and cable marking. Temperature rating: -40˚C to 60˚C D1 FLEXIBLE NYLON (3.5 m) 12 mm ABC S0718040 The DYMO® high quality labels are made in Belgium © 2021 Newell Brands This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change.
2094492
1. 物料型号:型号为EL817,是一款光隔离集成电路。
2. 器件简介:EL817是一种光隔离集成电路,用于实现输入和输出之间的电气隔离,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有8个引脚,其中1脚为输出,2脚为参考地,3脚为输入,4脚为输出,5脚为参考地,6脚为输出,7脚为参考地,8脚为Vcc。
4. 参数特性:工作电压范围为3.3V至5.5V,隔离电压为2.5kV,响应时间为1us。
5. 功能详解:EL817内部包含光发射器和光接收器,可以实现电信号的光电转换和隔离。
6. 应用信息:EL817广泛应用于工业控制、医疗设备、通信设备等领域。
2094492 价格&库存
很抱歉,暂时无法提供与“2094492”相匹配的价格&库存,您可以联系我们找货
