Rhino™ 6000+
PC-connected or portable labeling tool that saves you time and money
It’s packed with time-saving shortcuts for labeling any installation quickly and professionally.
Create labels up to 24mm width
Transfer files including barcodes from DYMO ID™ software* on PC to the Rhino 6000+ for easy editing on the job
Meets key ANSI and TIA/EIA-606-B industry labeling standards
xclusive, one-touch “Hot Keys” automatically size, space and format label text for electrical and patch
E
panels, terminal and 110 blocks, wire and cable flags, horizontal and vertical wraps, vertical and fixedlength applications including 5-line print capability
• Print 8 barcode types including Code 39, Code 128, Codabar, UPC A/E, EAN 8/13, PDF 417,
code 39 mod 43 variant and QR code
• Symbol library includes more than 250 pre-programmed industry symbols, terms, fractions and
punctuation marks
• Always use authentic DYMO® Industrial RhinoTM labels for guaranteed high-quality output
• For more features download the free DYMO ID™ software for PC and use it to create labels even faster
* Works with 32- and 64-bit Windows® 7 or later.
DYMO ID
No ink or
toner required
REACH
RoHS
Reach compliant
RoHS compliant
Bring the tough, portable Rhino™ 6000+ to any jobsite
Quick Specs
Single Kit includes:
• Rhino 6000+ Printer
• Rechargeable Battery Pack
• AC Adapter
• USB cable
• Carry Case
• Quick start guide
2122967
75 x 137.16 x 246.38 mm
Weight (excluding battery)
1.81 kg
Mac /PC Compatible
PC only
Accepts Label Sizes
6mm, 9mm, 12mm, 19mm, 24mm
Tape Platform
IND
Resolution
180 dpi
Printing System
Thermal Transfer
Print Speed
10.16 mm/sec
Barcodes
Yes
Cutter Type
Electronic
Batteries
Rechargeable (included)
AC Adapter
Yes (included)
Networking
No
Country of Origin
China
• Industrial Rhino white Vinyl 9 mm
and Flexible Nylon 24 mm tapes
Item
Number
Unit Dimensions (H x W x L)
Description
RH6000+ ABC 24MM CASE UK
Unit
Length
(cm)
Width
(cm)
Height
(cm)
Weight
(kg)
QTY
EAN
45.0
10.2
34.9
6.9
1
3026981229671
Customer
Price
Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
www.DYMO.com
Rhino 6000+ | Authentic Labels
100% recycled material used
for external cassette
REACH
Reach
compliant
RoHS
RoHS
compliant
MADE IN
EUROPE
DYMO® high quality labels
are made in Belgium
BELGIUM
IND Vinyl
Ideal for both indoor and outdoor applications. Available in
the widest range of colors that meet OSHA, ANSI and ISO
color standards.
• UL recognized component to UL 969
• REACH / RoHS compliant
• Temperature rating: -40°C to 80°C
IND Permanent Polyester
Professional, polished finish ideal for panels, blocks, faceplates,
shelves, bins, beams and more.
• For flat surfaces only
• Temperature rating: -40°C to 150°C
IND Flexible Nylon
Specifically designed for curved surfaces and wire and cable
marking.
• Temperature rating: -10°C to 80°C
• Authentic DYMO® labels are made in Belgium, Europe
IND Heat-Shrink Tube
For high-end cable identification. A 3:1 shrink ratio helps ensure a
secure fit on wires and cables.
• Meets MIL-M-81531, MIL-STD-202G, SAE-DTL-23053/5
(Class 1 & 3)
• UL recognized as a component to UL 224
• Temperature rating: -55°C to 135°C
Rhino™ Industrial Labels
6mm
9mm
12mm
19mm
24mm
A
18443
18444
18445
1805430
A
18432
18433
1805431
A
18435
18436
18436
A
1805416
1805437
1805435
1805436
1805432
A
1805414
1805420
A
1805243
1805417
A
1805422
Length
IND VINYL
A
5.5m
IND PERMANENT POLYESTER
A
A
5.5m
A
1805442
18482
18483
18484
1734523
18508DMO
622289
622290
1805441
18485
18486
18487
18488
18489
1734524
18490
18491
1734525
18051
18053
18055
18057
1805443
18052
18054
18056
18058
1805444
IND FLEXIBLE NYLON
A
A
3.5m
IND HEAT-SHRINK TUBE
A
A
1.5m
Country of Origin: Belgium
This information is being provided for general information purposes and the compliance
standards and certifications referenced herein are based on current standards which are subject to change.
© 2021 Newell Brands
很抱歉,暂时无法提供与“1734523”相匹配的价格&库存,您可以联系我们找货
