1868736
1868736
    DYMO
    DYMO - 1868736 - Label Printer Tape, Adhesive, Black on White, 9.1 m
1868736 数据手册
XTL Labels TM Permanent Flat Surface • For labeling panels, blocks, faceplates, shelves, bins, beams and more • Glossy finish that leaves your work looking professional • Constructed polyester material and coated with industrial-grade adhesive • Available in smaller widths down to 6 mm to fit in tight spaces • Easy-to-peel split back design makes applying labels quick and easy • Durable thermal transfer printing technology – label text won’t smear or fade • RoHS compliant Quick Specs Item Number Width Color Unit 1868735 1868738 1868736 6 mm 6 mm 9 mm A A A Label Widths 6, 9, 12 mm Tape Platform XTL Printer Compatibility XTL 300, XTL 500 Label Length 9.1 m Printing System Thermal Transfer Temperature Rating -40°C to 60°C UL Recognized Component to UL 969 Country of Origin Belgium Material Polyester Length (mm) Width (mm) Height (mm) Weight (kg) QTY EAN 72 35 120 0.052 1 071701001146 Shelf 215 76 126 0.35 6 30071701001147 Case 400 230 145 2.07 30 50071701001141 Pallet 1200 800 1165 155.41 63 – Unit 72 35 120 0.052 1 071701001177 Shelf 215 76 126 0.35 6 30071701001178 Case 400 230 145 2.07 30 50071701001172 Pallet 1200 800 1165 155.41 63 – Unit 72 35 120 0.05 1 071701001153 Shelf 215 76 126 0.38 6 30071701001154 Case 400 230 145 2.20 30 50071701001158 Pallet 1200 800 1165 163.91 63 – DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC XTL Labels TM Item Number 1868739 1858737 1868740 Width 9 mm 12 mm 12 mm Length (mm) Width (mm) Height (mm) Weight (kg) QTY EAN Unit 72 35 120 0.05 1 071701001184 Shelf 215 76 126 0.38 6 30071701001185 Case 400 230 145 2.20 30 50071701001189 Pallet 1200 800 1165 163.91 63 – Color A A A Unit 72 35 120 0.06 1 071701001160 Shelf 215 76 126 0.40 6 30071701001161 50071701001165 Case 400 230 145 2.34 30 Pallet 1200 800 1165 172.42 63 – Unit 72 35 120 0.06 1 071701001191 Shelf 215 76 126 0.40 6 30071701001192 Case 400 230 145 2.34 30 50071701001196 Pallet 1200 800 1165 172.42 63 – DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. ©2015 Newell Europe LLC
1868736 价格&库存
很抱歉,暂时无法提供与“1868736”相匹配的价格&库存,您可以联系我们找货
