1868810
1868810
    DYMO
    DYMO - 1868810 - Label Printer Tape, Black On White, 12 mm Width, 2.7 m Length, XTL Series - Label P...
1868810 数据手册
Industrial Labelling Solution SIMPLIFIES THE MOST COMPLEX LABELLING. DY_1363833_XTL Brochure_EMEA_V4.indd 1 29/06/15 10:34 PM WE BET YOU’VE NEVER EXPERIENCED INDUSTRIAL LABELLING THIS SIMPLE. Jobsite tested and packed with features, the DYMO® XTL™ 300 and XTL 500 label makers help simplify industrial labelling for a more efficient, frustration-free experience. By incorporating cues from today’s technology, XTL label makers offer a familiarity that makes using them easy. That’s why over 80% of people who used an XTL label maker for eight weeks without any training said it performed better than their current label maker*. Built to meet your needs, DYMO XTL label makers offer the flexibility to print continuous tape, pre-sized labels, heat-shrink tubes and small format safety signage all from the same label maker. A full range of durable XTL labels are also available in a variety of materials and colours that fit with OSHA, ANSI and ISO colour standards for workplace communication and safety. Read on to see how XTL label makers are redefining simplicity. LIFE-LIKE ON SCREEN PRINT PREVIEW and colour display shows exactly how labels will look when applied to cables, pipes, panels, and more * Based on in-field use study DY_1363833_XTL Brochure_EMEA_V4.indd 2 29/06/15 10:34 PM BUILT-IN LABEL APPLICATIONS simply select an application from the Home screen to get started quickly TOUCH SCREEN helps make label creation easier and faster (available only on XTL 500) PRE-LOADED LABEL TEMPLATES create labels 3x faster* and ensure perfect formatting to save time. Also includes pre-set layouts for almost 100 patch panel models to eliminate size and spacing guesswork. ADDITIONAL FEATURES INCLUDE: 1 3-Year Limited Warranty + 1 additional year upon 5 Durable built-in cutter for fast label production registering online 2 3 Maximised print area helps reduce label waste PC-connectivity to easily transfer labels to and from DYMO ID software for jobsite editing and printing 4 FREE DYMO ID software adds even more capability to your XTL label maker 6 Impact-resistant rubber bumpers and wipe-clean keypad withstands harsh environments 7 On-screen label indicator automatically detects and displays the loaded label 8 Customisable printer settings eliminate unnecessary menus and steps dymo.com * when compared to creating labels on an XTL label maker without templates DY_1363833_XTL Brochure_EMEA_V4.indd 3 29/06/15 10:34 PM DYMO® ID - ACHIEVING LABELLING SIMPLICITY JUST GOT EASIER. Using DYMO ID is easy thanks to a uniform experience that integrates the same great features found on your XTL™ label maker and packs them into a powerful PC-based software package. Once you've used an XTL label maker, learning to use DYMO ID will be a breeze. Available as a free download from dymo.com, DYMO ID will provide you with the functionality you need to tackle even the most complex labelling. QUICKLY IMPORT DATA to create a series of labels in just a few steps to eliminate manual entry, saving time and increasing productivity OVER 200 PRE-LOADED SYMBOLS & IMAGES or simply add a custom image to enhance communication and meet industry standards SHEET LABELS Quickly print XTL label maker Laminated Wire/Cable Wrap sheet labels directly to a laser printer QUICK CUSTOMISATION & UPGRADES Simply plug your XTL into a PC and use DYMO ID software to customize your preferences and keep it up to date DYMO ID WORKS WITH THE FOLLOWING: • XTL 300 Label Maker • XTL 500 Label Maker • XTL Laminated Wire/Cable Wrap Sheet Labels • Works with Windows®7 and later Available as a FREE download from www.dymo.com DY_1363833_XTL Brochure_EMEA_V4.indd 4 29/06/15 10:34 PM Selection Guide XTL™ 300 XTL™ 500 Printing System Thermal Transfer Thermal Transfer Max Label Width 24 mm 54 mm Labels Supported DYMO XTL DYMO XTL 71.12 mm Colour 109.22 mm Colour Touch Screen Display Print Speed (average) 23 mm/sec 28 mm/sec Keyboard QWERTY QWERTY Print DPI 300 300 Printable Lines 11 24 Code 128 (Auto), Code 39, Code 39 Mod 43, EAN8, EAN13, UPC-A, Codabar, PDF-417, QR Code Code 128 (Auto), Code 39, Code 39 Mod 43, EAN8, EAN13, UPC-A, Codabar, PDF-417, QR Code Yes Yes Manual, Replaceable Auto, Replaceable Barcodes Supported Serialization Cutter Power Supply Rechargeable Lithium Polymer Battery or AC Adapter Rechargeable Lithium Polymer Battery or AC Adapter Memory 41 MB 41 MB Warranty 3 + 1 Year Limited 3 + 1 Year Limited YES YES DYMO ID, free download DYMO ID, free download Windows® 7 and later Windows® 7 and later PC Connectivity Software Compatibility Pack Contents • DYMO XTL 300 Label Maker • AC Charging Adapter •U  SB Cable • Rechargeable Lithium Polymer Battery • (1) 24 mm x 7 m All-Purpose Vinyl, Black/White • Lanyard • Quick Start Guide • Software Download Card Kit includes everything above, plus: • Carrying Case • (1) 21 mm x 39 mm Laminated Wire/Cable Wrap, Black/White, 150 labels • DYMO XTL 500 Label Maker • Carrying Case • AC Charging Adapter • USB Cable • Rechargeable Lithium Polymer Battery • (1) 54 mm x 7 m All-Purpose Vinyl, Black/White • (1) 38 mm x 39 mm Laminated Wire/Cable Wrap Black/White, 150 labels • Quick Start Guide • Software Download Card LABEL APPLICATIONS 110 & Terminal Blocks ✓ Arc Flash ✓ ✓ Asset Tracking ✓ ✓ Breaker ✓ ✓ Cable Wrap ✓ ✓ Distribution Panel ✓ ✓ Flag ✓ ✓ General Label ✓ ✓ Heat-Shrink Tube ✓ ✓ Materials Management ✓ ✓ Patch Panel ✓ ✓ Pipe Marking Quick Label Safety ✓ ✓ ✓ ✓ dymo.com DY_1363833_XTL Brochure_EMEA_V4.indd 5 29/06/15 10:34 PM MORE VERSATILITY. THE RIGHT LABEL DELIVERING VERSATILITY AND DURABILITY, NO MATTER WHAT THE TASK. DYMO XTL™ labels are durable and made for a variety of surfaces. Whether you are labelling to OSHA, ISO and ANSI colour standards or labelling in harsh conditions, DYMO XTL labels have you covered. Jobsite-tested and UL-recognised, these labels won’t smear or fade. Compatible with DYMO XTL label makers. ONE LABEL SYSTEM. COUNTLESS APPLICATIONS. RECOMMENDED APPLICATIONS: DYMO XTL 300 General Idendification Barcodes (1D and 2D) Asset Tracking Wire and Cable Identification Networking Components Identification Facilities Identification DYMO XTL 500 General Idendification Barcodes (1D and 2D) Asset Tracking Data Communications Identification MRO / Facilities Identification & Communication DY_1363833_XTL Brochure_EMEA_V4.indd 6 29/06/15 10:34 PM XTL LABELS Industrial-strength labels withstand the toughest conditions – moisture, chemicals, a wide range of temperatures, UV light and more. • Durable thermal transfer printing technology – label text won’t smear or fade • Easy-to-peel split back design and pre-sized labels make applying labels quick and easy ALL-PURPOSE VINYL PERMANENT FLAT SURFACE • Moisture, chemical and UV resistance makes vinyl ideal for indoor/outdoor use • For labelling panels, blocks, faceplates, shelves, bins, beams and more • Wide range of colours that fit with OSHA, ANSI and ISO colour standards to enhance workplace communication and safety • For labelling flat surfaces, a glossy finish leaves a professional look • UL recognised as a component to UL 969 • UL recognised as a component to UL 969 FLEXIBLE CABLE WRAPS HEAT-SHRINK TUBES • For labelling wires, cables and rounded surfaces, flexible nylon material is designed to conform and stick • Tear-proof material resists damage when pulled through tight spaces or conduits (CONTINUOUS AND PRE-SIZED) • Heat-Shrink Tubes provide insulation when shrunk down and ensure a secure fit on wires and cables with a 3:1 shrink ratio • UL recognised as a component to UL 969 • Meets MIL-M-81531, MIL-STD-202G, SAE-DTL23053/5 (Class 1 & 3) LAMINATED WIRE/CABLE WRAPS • UL recognised as a component to UL 224 • Pre-sized wire/cable wraps with laminated overwrap protect printed areas from oil, chemicals, moisture, abrasion and fading • Also available in sheet label formats for high-volume installations • UL recognised as a component to UL 969 PRE-SIZED SAFETY LABELS • Specific labels with coloured headers including labels pre-printed with DANGER and NOTICE headers for on-demand printing of small format safety signage PRE-SIZED LABELS • Ideal for flat surface labelling like barcodes, faceplates, shelves, bins, beams and more • Pre-Sized labels help facilitate batch label printing to improve productivity • UL recognised as a component to UL 969 • UL recognised as a component to UL 969 dymo.com DY_1363833_XTL Brochure_EMEA_V4.indd 7 29/06/15 10:34 PM XTL LABELS: A VISUAL GUIDE LABEL WIDTHS ALL-PURPOSE VINYL COLOURS 12 mm A A A A A A A A A A A A A 19 mm 24 mm PRE-SIZED LABELS 38 mm 54 mm 1868666 1868665 12 mm x 12 mm 12 mm x 25 mm 1868667 12 mm x 38 mm PRE-SIZED HEAT-SHRINK TUBE PRE-SIZED SAFETY LABELS NOTICE 1868733 / 24 mm x 47 mm Black on White LAMINATED WIRE/CABLE WRAPS A-01 1868715 / 51 mm x 102 mm 1868708 / 38 mm x 39 mm 1868716 / 51 mm x 102 mm PERMANENT FLAT SURFACE A-01 A-02 A-03 1868736 / 9 mm Black on White DY_1363833_XTL Brochure_EMEA_V4.indd 8 A-04 A-05 A-06 12 mm DRILL BITS 1868740 / 12 mm Black on Clear 29/06/15 10:34 PM Surface THE RIGHT LABEL FOR THE RIGHT APPLICATION. All-Purpose Vinyl Permanent Flat Surface Flexible Cable Wrap Flat ✓ ✓ ✓ Wires & Cables ✓ ✓ Curved ✓ ✓ Flag ✓ ✓ Textured ✓ ✓ ✓ -40° to 60° C -40° to 60° C -40° to 60° C Outdoor ✓ ✓ UV Light ✓ ✓ Oil ✓ Water Chemical Industry Standards & Ratings Resistance Heat/Cold Colour UL Recognised as acomponent to ✓ ✓ Max 125° C Laminated Wire/Cable Wraps Pre-Sized Labels Pre-Sized Safety Labels ✓ ✓ ✓ ✓ -40° to 60° C -40° to 60° C ✓ ✓ ✓ ✓ -40° to 60° C ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ UL 969 ✓ Coloured headers to comply with OSHA, ANSI, ISO colour standards OSHA, ANSI, ISO colour standards UL 969 UL 969 UL 224 UL 969 UL 969 UL 969 ✓ ✓ ✓ MIL-M-8153 MIL-STD-202G SAEDTL-230535 (Class 1 & 3) MIL-Spec & SAE RoHS Heat-Shrink Tube (continuous & pre-sized) ✓ ✓ ✓ ✓ dymo.com DY_1363833_XTL Brochure_EMEA_V4.indd 9 29/06/15 10:34 PM CONTINUOUS & PRE-SIZED LABELS All-Purpose Vinyl Text Colour on Label Colour Flexible Cable Wrap Permanent Flat Surface Heat-Shrink Tube (continuous) Length 6 mm 9 mm 12 mm 19 mm 24 mm 38 mm 54 mm ABC 7m - - 1868741 1868742 1868743 1868744 1868745 ABC 7m - - 1868746 1868747 1868748 1868749 1868750 ABC 7m - - 1868751 1868752 1868753 1868754 1868755 ABC 7m - - 1868756 1868757 1868758 1868759 1868760 ABC 7m - - 1868761 1868762 1868763 1868764 1868765 ABC 7m - - 1868766 1868767 1868768 1868769 1868770 ABC 7m - - 1868771 1868772 1868773 1868774 1868775 ABC 7m - - 1868776 1868777 1868778 1868779 1868780 ABC 7m - - 1868781 1868782 1868783 1868784 1868785 ABC 7m - - 1868786 1868787 1868788 1868789 1868790 ABC 7m - - 1868791 1868792 1868793 1868794 1868795 ABC 7m - - 1868796 1868797 1868798 1868799 1868800 ABC 7m - - 1868801 1868802 1868803 1868804 1868805 ALL-PURPOSE VINYL PERMANENT FLAT SURFACE ABC 9.1 m 1868735 1868736 1868737 - - - - ABC 9.1 m 1868738 1868739 1868740 - - - - 5.5 m - - 1868806 1868807 1868808 - - 1868809 - 1868810 - 1868811 - 1868812* FLEXIBLE CABLE WRAP ABC HEAT-SHRINK TUBE (CONTINUOUS) ABC 2.7 m *Tape length 1.8 m for #1868812 only For technical specifications on all DYMO XTL label types, please visit our website at www.dymo.com DY_1363833_XTL Brochure_EMEA_V4.indd 10 29/06/15 10:34 PM Heat-Shrink Tube (pre-sized) Pre-Sized Labels Text Colour on Label Colour Pre-Sized Safety Labels Item # Laminated Wire/Cable Wraps Laminated Wire/Cable Wraps (sheet labels) Label Width Label Length Labels / Cartridge Compatible Label Maker PRE-SIZED HEAT-SHRINK TUBE ABC 1868717 6 mm 34 mm 81 XTL 500 ABC 1868718 12 mm 34 mm 65 XTL 500 ABC 1868719 24 mm 34 mm 60 XTL 500 ABC 1868720 54 mm 34 mm 25 XTL 500 ABC 1868731 6 mm 47 mm 81 XTL 500 ABC 1868732 12 mm 47 mm 65 XTL 500 ABC 1868733 24 mm 47 mm 60 XTL 500 ABC 1868734 54 mm 47 mm 25 XTL 500 ABC 1868665 12 mm 12 mm 250 XTL 300, XTL 500 ABC 1868666 12 mm 25 mm 250 XTL 300, XTL 500 ABC 1868667 12 mm 38 mm 185 XTL 300, XTL 500 ABC 1868668 25 mm 25 mm 250 XTL 500 ABC 1868669 9 mm 25 mm 250 XTL 300, XTL 500 ABC 1868670 12 mm 19 mm 250 XTL 300, XTL 500 ABC 1868701 19 mm 25 mm 250 XTL 300, XTL 500 ABC 1868702 25 mm 51 mm 100 XTL 500 ABC 1868703 51 mm 76 mm 100 XTL 500 PRE-SIZED LABELS PRE-SIZED SAFETY LABELS (WITH COLOURED HEADERS) ABC ABC ABC DANGER ABC 1868713 51 mm 102 mm 70 XTL 500 1868714 51 mm 102 mm 70 XTL 500 1868715 51 mm 102 mm 70 XTL 500 1868716 51 mm 102 mm 70 XTL 500 LAMINATED WIRE/CABLE WRAPS ABC 1868704 21 mm 21 mm 250 XTL 300, XTL 500 ABC 1868705 21 mm 39 mm 150 XTL 300, XTL 500 ABC 1868706 21 mm 102 mm 75 XTL 300, XTL 500 ABC 1868707 38 mm 21 mm 250 XTL 500 ABC 1868708 38 mm 39 mm 150 XTL 500 ABC 1868709 38 mm 102 mm 75 XTL 500 ABC 1868710 51 mm 21 mm 250 XTL 500 ABC 1868711 51 mm 39 mm 100 XTL 500 ABC 1868712 51 mm 102 mm 70 XTL 500 LAMINATED WIRE/CABLE WRAPS (SHEET LABELS) Text Colour on Label Colour SKU # Label Width Label Length Labels/Sheet Sheets/Pack Labels/Pack ABC 1908552 24 mm 23 mm 96 27 2592 ABC 1908553 24 mm 42 mm 48 53 2544 ABC 1908554 24 mm 103 mm 16 63 1008 ABC 1908555 41 mm 23 mm 60 34 2040 ABC 1908556 41 mm 42 mm 30 34 1020 ABC 1908557 54 mm 23 mm 36 28 1008 ABC 1908558 54 mm 42 mm 18 56 1008 Windows is a registered trademark of Microsoft Corporation in the United States and other countries. DY_1363833_XTL Brochure_EMEA_V4.indd 11 29/06/15 10:34 PM dymo.com DISTRIBUTED BY/DISTRIBUÉ PAR: NEWELL EUROPE SARL, CHEMIN DE BLANDONNET, 101214 VERNIER, SWITZERLAND | REPRESENTED IN THE EU BY / REPRESENTE EN UE PAR: NWL BELGIUM SERVICES BVBA, INDUSTRIEPARK-NOORD 30, 9100 SINT-NIKLAAS – BELGIUM DY_1363833_XTL Brochure_EMEA_V4.indd 12 © 2015 Newell Rubbermaid Europe LLC 29/06/15 10:34 PM
1868810 价格&库存
很抱歉,暂时无法提供与“1868810”相匹配的价格&库存,您可以联系我们找货
