18764-R1
18764-R1
    DYMO
18764-R1 数据手册
Rhino labels Rhino labels TM TM RHINO tapes are developed for harsh environments and provide resistance against abrasion, different temperatures, chemicals, solvents, water and UV. DYMO offers several specific materials depending on the application, all with a strong adhesive and carefully chosen ribbon for high print quality and resistance. S-CODE RHINO PRODUCT COLOUR PCK FLEXIBLE NYLON – Curved or flat surfaces. Wires & cables, patch panels, machinery, equipment, bins, etc (L=3,5m) S0718100 S0718120 S0773840 S0718080 S0718090 S0773850 FULL BACKSLIT FOR EASY PEEL 12 mm flexible nylon tape 19 mm flexible nylon tape 24 mm flexible nylon tape 12 mm flexible nylon tape 19 mm flexible nylon tape 24 mm flexible nylon tape white white white yellow yellow yellow 1/5 1/5 1/5 1/5 1/5 1/5 white white white white metallized metallized metallized clear 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 NEW! NEW! PERMANENT POLYESTER – Flat surfaces. Equipment, bins, patch panels, etc (L=5,5m) Smooth 4 4 4 4 – – n/a Flat 4 4 4 4 – – n/a S0718240 S0718210 S0718220 S0773830 S0718170 S0718180 S0718200 S0718160 FLEXIBLE NYLON COLOURED VINYL PERMANENT POLYESTER CLEAR POLYESTER HEAT SHRINK TUBE SELF-LAM. VINYL NON-ADHESIVE TAG (INSERT) Surface Applications 56 9 mm permanent polyester tape 12 mm permanent polyester tape 19 mm permanent polyester tape 24 mm permanent polyester tape 9 mm permanent polyester tape 12 mm permanent polyester tape 19 mm permanent polyester tape 9 mm clear polyester tape NEW! Textured 4 4 4 4 – – n/a VINYL – All surfaces. Ideal for outdoor and colour-coding applications. Warning messages, wires, patch panels, equipment, machinery, etc (L=5,5m) Powder coated 4 4 4 4 – – n/a S0718440 S0718450 S0718470 S0718480 S0718490 S0718500 S0718510 S0718520 S0718530 S0718550 S0718560 S0718570 S0718580 S0718600 S0718620 Curved 4 4 – – – – n/a Wire & Cable 4 4 – – 4 4 n/a 4 – 4 4 4 4 n/a n/a Resistancy Heat Water – 4 4 4 4 4 UV 4 4 4 4 4 4 n/a Chemicals – 4 4 4 4 4 n/a Oils – 4 4 4 4 4 n/a INDOOR 4 4 4 4 4 4 4 OUTDOOR – 4 4 4 4 4 4 RHINO tapes include specific material depending on the application. They all feature super strong adhesives that stick and last in harsh environments, attached to flat, curved, textured and highly-textured surfaces. FLEXIBLE NYLON TAPE is specifically designed for wire and cable marking. PERMANENT POLYESTER TAPE can be used on a variety of flat, textured or highly textured surfaces and has an excellent solvent and chemical resistance. CLEAR PERMANENT POLYESTER with the sharp printed black characters integrate very nicely the structure and background of the application. COLOURED VINYL TAPE combines flexibility, a strong adhesive and a high chemical resistance which makes this tape suitable for many type of applications where colour is requested. HEAT SHRINK TUBING is a non-adhesive yet permanent polyolefin solution to identify and protect your wire and cables at the same time. Flame retardant and 3:1 shrink ratio. NON-ADHESIVE TAG: ideally to be used as an insert for label holders. NEW! SELF-LAMINATING VINYL LABELS protect your printed area from exposure (to oil, solvents, water and abrasion) ideal for wire and cable marking. 9 mm coloured vinyl tape 12 mm coloured vinyl tape 19 mm coloured vinyl tape 9 mm coloured vinyl tape 12 mm coloured vinyl tape 19 mm coloured vinyl tape 9 mm coloured vinyl tape 12 mm coloured vinyl tape 19 mm coloured vinyl tape 9 mm coloured vinyl tape 12 mm coloured vinyl tape 19 mm coloured vinyl tape 9 mm coloured vinyl tape 12 mm coloured vinyl tape 19 mm coloured vinyl tape HEAT SHRINK TUBE – Wire and cable. (L=1,5m) Cable Diameter S0718260 S0718280 S0718300 S0718330 S0718270 S0718290 S0718310 S0718340 Min 1,18 mm  Min 1,73 mm  Min 2,97 mm  Min 4,64 mm  Min 1,18 mm  Min 1,73 mm  Min 2,97 mm  Min 4,64 mm  6 mm heat shrink tube 9 mm heat shrink tube 12 mm heat shrink tube 19 mm heat shrink tube 6 mm heat shrink tube 9 mm heat shrink tube 12 mm heat shrink tube 19 mm heat shrink tube Max 2,33mm Max 3,73mm Max 5,13mm Max 8,70mm Max 2,33mm Max 3,73mm Max 5,13mm Max 8,70mm yellow yellow yellow orange orange orange red red red green green green white white white 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 white white white white yellow yellow yellow yellow 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 white white white white yellow yellow yellow yellow 1/5 1/5 1/5 1/5 1/5 1/5 1/5 1/5 57 NON-ADHESIVE – Insert. Label holders, Patch panels, distribution blocks, faceplates, etc (L=5,5m) S0718350 S0718360 S0718380 S0718390 S0718400 S0718410 S0718420 S0718430 6 mm non-adhesive tag 9 mm non-adhesive tag 12 mm non-adhesive tag 19 mm non-adhesive tag 6 mm non-adhesive tag 9 mm non-adhesive tag 12 mm non-adhesive tag 19 mm non-adhesive tag SELF-LAMINATING VINYL – Wire and cable. Protects vital information (L=5,5m) S0773860 24 mm self-laminating tape NEW! white 1/5
18764-R1 价格&库存
很抱歉,暂时无法提供与“18764-R1”相匹配的价格&库存,您可以联系我们找货
