1734821
1734821
    DYMO
    DYMO - 1734821 - Label Printer Tape, Self-Laminating, Black on White, 5 m x 24 mm, Vinyl
1734821 数据手册
        Tech hnical Data SSheet          DYMO O Industrrial Self‐Laminatting Tapee    Descriptio on    This is aa flexible top‐ccoated thermal transfer printtable clear mattte vinyl film coated  with a permanent pre essure sensitivve acrylic adhessive. This tape  is mainly used d for  es. This tape is  halogen free. wrapping electrical caables and wire   DYMO Pa art Numbers     21  173482   Available Colors & Size es  Print Color    Black  Tape e Color Avaiilable Widths ((in, mm)  White ¼, 6m mm; ½, 12mm    Certifications and & Sttandards Adh herence  - To th he best of our company’s kno owledge we deeclare that ourr products meeet the most reccent  standards of the European Directives consideriing REACH and d ROHS. None of the substan nces  ntified as “subsstance of conce ern“ has been  and will be con ntained in the product(s), listted on  iden this Technical Dataa Sheet, to a hiigher level thann mentioned in n the European Directives  H and ROHS.   conssidering REACH   Physical P Properties  - Tota al Thickness: 15 57 µm +/‐ 10%  - Thickness face matterial: 80 µm + +/‐ 10%  - Dimensional Stabillity (%):    MD: 0.7 75 observed on n an aluminum m panel at 70°C  (158°F) for 24 4 hrs.   TD: 0.75 5 observed on an aluminum ppanel at 70°C ((158°F) for 24 hrs.    Adhesive Properties  Adhesio on to Surfaces  Surfacce (N/25mm)    Stainless Steel       Glass  PVC  Textured ABS   Polypropylene Film   Steel Computer Casing 20 mins.  10 9 11 7 9 7 224 hrs. h 14 14 13 8 10 8 Test M Method  PSTC‐‐1    Last Up pdated 11/29//2011        Tech hnical Data SSheet     m²  - Tackk (ASTM D 2979):  380gm/cm   Temperatture Stability          Applicaation & Servicee Temperaturess  Servicce Temp.  °C Appliccation Minimum  Servicce Minimum  Servicce Maximum  10 ‐40 80 °F 50 ‐40 176   Chemical Resistance (PPrinted with the Rhino 6000)  Chem mical    Fuel       Gasoline  Isopro opyl alcohol  Ethan nol  Water   Skydrrol* LD‐4 Ethyl acetate  Exxso ol*** D40  White e spirit  General degreaser  Nafta  Sabessto**  Aceto one  Papan nicolau og. 6  Hemaatoxylin (stain)  Xylene  # of rub bs Result Test Meth hod  30x 30x 15x 5x 30x 5x 5x 30x No visiblee effect Slight pri nt removal Printing ggone Printing ggone No visiblee effect  Printing ggone Printing ggone Moderatee print removaal Moderatee print removaal Moderatee print removaal Moderatee print removaal Printing ggone Printing ggone Printing ggone No visiblee effect Printing ggone Crockmetter,  900g weigght/arm  # of rub bs Result Test Meth hod  30x 30x 30x No visiblee effect No visiblee effect  Slight pri nt removal Crockmetter,  900g weigght/arm  Time Result Test Meth hod  30x  30x  30x 10x 3x 30x 30x 30x   Abrasion Resistance (PPrinted with the Rhhino 6000)    Abrassive Object    Pencil eraser  Polysttyrene pin  Sandp paper    UV Light R Resistance  UV ligght stability off:    Last Up pdated 11/29//2011        Tech hnical Data SSheet   Label  30 dayss Adhessive  30 dayss No visiblee effect on text  and backkground    No loss oof wrapping  propertiees  Constant UV  osure in  light expo Suntesterr    Humidity Resistance  - Printted labels adhe ered to alumin num surface foor 30 days at 455°C (113°F), 85 5% Relative Humidity  with h no visible effe ect on text or b background; noo loss of wrapp ping propertiess    Shelf life of label casse ette  - Two years stored aat 21°C (69.8°FF) and 50% Relaative Humidityy    Notice  - This product is nott developed to be used on huumans, animals and/or in direct food  conttact.      mark from Solutia (hydraulic engine o oil)  *Skydrol is a registered tradem emark from Wurth h (brake fluid clean ner)  ** Sabesto is a registered trade 40 is a registered ttrademark from ExxxonMobil Chemiccals (de aromatize d hydrocarbon fluuids)  *** Exxsol D4       All of the de escriptive inform mation, performaance data, and rrecommendationns for the use off DYMO productts shall be used o only as  a guide an nd do not reflectt the specificatio on or specificatio on range for anyy particular propperty of the prod duct. Furnishing such  information n is an attempt to o assist you and in no event willl constitute a waarranty of any kiind by DYMO or DYMO distributtors. All  purchasers of DYMO products shall be resp ponsible for inde ependently dete rmining the suittability of the maaterial for the pu urpose  for which it is purchaseed.    Last Up pdated 11/29//2011
1734821 价格&库存
很抱歉,暂时无法提供与“1734821”相匹配的价格&库存,您可以联系我们找货
    • 1+492.41829
    库存:15
