1805430
1805430
    DYMO
1805430 数据手册
Rhino™ 6000+ PC-connected or portable labeling tool that saves you time and money It’s packed with time-saving shortcuts for labeling any installation quickly and professionally. • • • • Create labels up to 24mm width Transfer files including barcodes from DYMO ID™ software* on PC to the Rhino 6000+ for easy editing on the job Meets key ANSI and TIA/EIA-606-B industry labeling standards  xclusive, one-touch “Hot Keys” automatically size, space and format label text for electrical and patch E panels, terminal and 110 blocks, wire and cable flags, horizontal and vertical wraps, vertical and fixedlength applications including 5-line print capability • Print 8 barcode types including Code 39, Code 128, Codabar, UPC A/E, EAN 8/13, PDF 417, code 39 mod 43 variant and QR code • Symbol library includes more than 250 pre-programmed industry symbols, terms, fractions and punctuation marks • Always use authentic DYMO® Industrial RhinoTM labels for guaranteed high-quality output • For more features download the free DYMO ID™ software for PC and use it to create labels even faster * Works with 32- and 64-bit Windows® 7 or later. DYMO ID No ink or toner required REACH RoHS Reach compliant RoHS compliant Bring the tough, portable Rhino™ 6000+ to any jobsite Quick Specs Single Kit includes: • Rhino 6000+ Printer • Rechargeable Battery Pack • AC Adapter • USB cable • Carry Case • Quick start guide 2122967 75 x 137.16 x 246.38 mm Weight (excluding battery) 1.81 kg Mac /PC Compatible PC only Accepts Label Sizes 6mm, 9mm, 12mm, 19mm, 24mm Tape Platform IND Resolution 180 dpi Printing System Thermal Transfer Print Speed 10.16 mm/sec Barcodes Yes Cutter Type Electronic Batteries Rechargeable (included) AC Adapter Yes (included) Networking No Country of Origin China ® • Industrial Rhino white Vinyl 9 mm and Flexible Nylon 24 mm tapes Item Number Unit Dimensions (H x W x L) Description RH6000+ ABC 24MM CASE UK Unit Length (cm) Width (cm) Height (cm) Weight (kg) QTY EAN 45.0 10.2 34.9 6.9 1 3026981229671 Customer Price Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries. www.DYMO.com Rhino 6000+ | Authentic Labels ™ 100% recycled material used for external cassette REACH Reach compliant RoHS RoHS compliant MADE IN EUROPE DYMO® high quality labels are made in Belgium BELGIUM IND Vinyl Ideal for both indoor and outdoor applications. Available in the widest range of colors that meet OSHA, ANSI and ISO color standards. • UL recognized component to UL 969 • REACH / RoHS compliant • Temperature rating: -40°C to 80°C IND Permanent Polyester Professional, polished finish ideal for panels, blocks, faceplates, shelves, bins, beams and more. • UL recognized component to UL 969 • REACH / RoHS compliant • For flat surfaces only • Temperature rating: -40°C to 150°C IND Flexible Nylon Specifically designed for curved surfaces and wire and cable marking. • UL recognized component to UL 969 • REACH / RoHS compliant • Temperature rating: -10°C to 80°C • Authentic DYMO® labels are made in Belgium, Europe IND Heat-Shrink Tube For high-end cable identification. A 3:1 shrink ratio helps ensure a secure fit on wires and cables. • Meets MIL-M-81531, MIL-STD-202G, SAE-DTL-23053/5 (Class 1 & 3) • UL recognized as a component to UL 224 • REACH / RoHS compliant • Temperature rating: -55°C to 135°C Rhino™ Industrial Labels 6mm 9mm 12mm 19mm 24mm A - 18443 18444 18445 1805430 A - - 18432 18433 1805431 A - - 18435 18436 18436 A - - 1805416 - - - 1805437 1805435 1805436 1805432 A - - 1805414 1805420 - A - - 1805243 1805417 - A - - - 1805422 - Length IND VINYL A 5.5m IND PERMANENT POLYESTER A A 5.5m A 1805442 18482 18483 18484 1734523 - 18508DMO 622289 622290 - 1805441 18485 18486 18487 - - - 18488 18489 1734524 - - 18490 18491 1734525 18051 18053 18055 18057 1805443 18052 18054 18056 18058 1805444 IND FLEXIBLE NYLON A A 3.5m IND HEAT-SHRINK TUBE A A 1.5m Country of Origin: Belgium This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. © 2021 Newell Brands Microsoft and Windows are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries.
1805430 价格&库存
很抱歉,暂时无法提供与“1805430”相匹配的价格&库存,您可以联系我们找货
    • 1+485.46185
    库存:40
