1812754
1812754
    FRIWO
1812754 数据手册
The Secondary Adapter Plug System In addition to the standardized low voltage plugin connections such as coaxial (in accordance with DIN 45323) and jack connectors (in accordance with DIN 45318) FRIWO also provides customized connecting cables. The wire diameter which is generally used in this case ranges from 0.25 to 1.5 mm². Both flat and round cables can be used. FRIWO has its own plug system with self cleaning fork contacts and the corresponding sockets for or PWB installation. This plug connection is available in 2 or 3 contact design. In addition to the safe contact and the self cleaning of the fork contacts this system also provides the advantage of extremely small dimensions. The illustrated low voltage plugs only represent one section of the comprehensive range. Customized designs, special versions and conditions and other dimensions can be obtained upon request. Universal jacks 16.5 mm 12 mm 14.5 mm 12 mm 7.2 mm Device connector Texas sockets Coaxial plugs & male jacks Phone connectors (on request) 7 mm 14 mm 8.2 mm 12 mm 10 mm 10 mm 11 mm 11 mm 14 mm Texas sockets Designation Contacts Housing inst. 2pin Circuit board inst. 2pin Coaxial plugs Order No. Outside Ø 1323938 1321609 3.5 4.0 5.5 5.5 5.5 5.5 5.5 5.0 Texas plug Order No. Designation Plug 1812758 Male jacks 24 Outside Ø Length mm Order No. 2.5 3.5 13 14 1812756 1812757 Inside Ø 1.3 1.7 2.1 2.1 2.1 2.5 2.5 1.95 Length mm Order No. 9.5 11.0 9.5 11.5 14.0 9.5 11.5 DIN 45323 1812748 1812749 1812750 1812751 1812752 1812753 1812754 1812755
1812754 价格&库存
很抱歉,暂时无法提供与“1812754”相匹配的价格&库存,您可以联系我们找货
