RATCHET WRENCHES
"11-in-1" ratchet wrench set
Ideal for on-site maintenance!
RATCHET WRENCHES
• The rings are securely held
in their foam compartments
even if the case is dropped
or overturned.
• Foam tray and box resistant to impact
and workshop chemicals
464.J1PB
• Place the desired ring size
in the wrench in one click
• Secure one-handed locking system
ULTRA-LIGHTWEIGHT
VIDEO
• 60% lighter than, a set of six ring wrenches.
www.facom.com
0:00 / 0:30
HQ
COMPACT
• Low profile head: 3 times
narrower than the ratchet
and socket system
Used as a passthrough wrench
on long threads
• No time wasted searching
for the required size.
• Very visible marking.
Kit
"11-in-1"
clésratchet
à cliquet
wrench
"11 enset
1"
464.J1PB
3148518240772
• 5° increments
• FACOM performance: torsional strength = ISO 1711-1 + 50%
• Comprehensive selection: 8-9-10-11-12-13-14-15-16-17-19 mm
D : 0,517 kg.
New ratchet combination wrenches
Ultra-compact, ultra-accessible, multi-application!
5°
The adaptors transform the wrench into an ultra-compact ratchet for sockets and bits.
Cliquet
Ratchet System
INNOVATIONS 2009
ULTRA-COMPACT
an ultra-compact ratchet for sockets and/or bits.
Head of height + socket:
27% more compact than the ratchet + socket.
REACH ANYWHERE
• Foam tray:
- Visual identification of missing tools,
- Holds tools securely
even upside-down.
MULTI-APPLICATION
• "Standard" configuration
• "Socket" configuration
• "Bit" configuration
Coffret multi service
Ultra-compact
multi-application
ultra compact
set
467S.BOXPB
8 9 10 11 12 13 14 mm
NNNNNNNN
• 467S 7
3148518240857
• L 1/4"
VIDEO
www.facom.com
0:00 / 0:30
4
R. 5,5 -6-7-8-9-10-11-12-13-14 mm
• L 1/4" ( 1-2-3 ' 4,5-6,5-8 § 1-2-3
10-15-20-25-30-40 3 3-4-5-6-7
• 1/4" L 55 mm Extension
• Wrench adaptor 10mm L 1/4" : 467.ADAPT10MM
D : 0,884 kg.
HQ
www.facom.com
很抱歉,暂时无法提供与“467S.BOXPB”相匹配的价格&库存,您可以联系我们找货
