592-9013
592-9013
    STANCOR
592-9013 数据手册
592 Series Class 2 Transformers Energy Limiting Transformers ! WARNING INPUT: ELECTROCUTION HAZARD Disconnect electric power to system at main fuse or circuit breaker box before servicing. Failure to do so could result in death or serious injury. OUTPUT: INSULATION RATING: TEMPERATURE RISE: DIELECTRIC STRENGTH: AGENCY STANDARDS: ! CAUTION FILE NOs: Do not use on circuits exceeding rating of transformer. Higher voltage will damage control and could cause personal injury or property damage. 50/60Hz (See table below) 24 VAC, 1.67 A (40 VA) Class B (130˚C) 85˚C Max. rise over 40˚C Max. ambient 1500 VRMS UL Recognized: UL-1585 CSA Certified: C22.2 #66 UL - E109254 CSA - LR67888 NOTES: 1. All dimensions in inches, unless otherwise specified. 2. All dimensions ±.062, unless otherwise specified. 3. Unit weight approximately 1.5 lbs. D MAX. 240V 208V H MAX. 24V 40 VA L O A D 120V PRIMARY 50/60 Hz MW COM W MAX. SCHEMATIC DIAGRAM .187 ±.031 DIA. (2) HOLES STANCOR Input Part No. Volts 592-9012 120 592-9013 240 592-9016 120 / 240 592-9017 208 / 240 592-9018 120 / 208 / 240 Dimensions - Inches H W D 2.25 3.69 2.25 2.25 3.69 2.25 2.25 3.69 2.25 2.25 3.69 2.25 2.25 3.69 2.25 MW 3.13 3.13 3.13 3.13 3.13 Terminations Input Output 1/4"QC 1/4"QC 1/4"QC 1/4"QC 1/4"QC 1/4"QC 1/4"QC 1/4"QC 1/4"QC 1/4"QC PART NO. 37-6226B Replaces 37-6226A 0838 www.stancor.com
592-9013 价格&库存
很抱歉,暂时无法提供与“592-9013”相匹配的价格&库存,您可以联系我们找货
