AT.J8PB
AT.J8PB
    FACOM
    FACOM - AT.J8PB - Screwdriver Set, Slotted, Phillips, Pozidriv, 8 Piece
AT.J8PB 数据手册
AT.J8PB Pro-Twist Screwdriver Set - 8 piece Description: • • • • • • Content; AT4x100 – 4mm x 100mm Slotted Screwdriver AT5.5x100 – 5.5mm x 100mm Slotted Screwdriver ATF6.5x150 – 6.5mm x 150 mm Slotted Screwdriver ATF8x150 – 8mm x 150mm Slotted Screwdriver ATD1x100 – PZ1 x 100mm Pozi-Drive® Screwdriver ATD2x125 – PZ2 x 125mm Pozi-Drive® Screwdriver ATP1x100 – PH1 x 100mm Phillips® Screwdriver ATP2x125 – PH2 x 125mm Phillips® Screwdriver Inline Hardening Process – +100% Tip Life and +100% Bar Strength. Handle Material - Softer for more Comfort and still Chemical Resistant. Blade " tri-coating " treatment (Zinc-NickelChromium) - 4x Corrosion Resistance. Handle ‘Channel’ - +10% Torque. Laser Marking - gives virtually Permanent Marking. CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear.
AT.J8PB 价格&库存
很抱歉,暂时无法提供与“AT.J8PB”相匹配的价格&库存,您可以联系我们找货
AT.J8PB
    • 1+476.81836
    库存:23
