ATP3X150VE
ATP3X150VE
    FACOM
    FACOM - ATP3X150VE - Screwdriver, Phillips, #3 Tip, 150 mm Blade Length, 275 mm OVL
ATP3X150VE 数据手册
ATP3X150VE | ATP.VE - PROTWIST® 1,000 Volt insulated screwdrivers for Phillips® head screws Description: ● For improved safety, each screwdriver is tested individually at 10,000 Volt for 10 seconds VDE approved. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 ATP3X150VE Diameter [mm] 40.0 Diameter D1 [mm] 8.0 Length L [mm] 275.0 Length L1 [mm] 150.0 Length L2 [mm] 125.0 Length L3 [mm] 18.0 Thickness E [mm] 8.0 Weight [g] 195.0 Phillips Tip Number ["] PH3 © FACOM 2020
ATP3X150VE 价格&库存
很抱歉,暂时无法提供与“ATP3X150VE”相匹配的价格&库存,您可以联系我们找货
