187A.16CPE
187A.16CPE
    FACOM
    FACOM - 187A.16CPE - Combination Plier, 1.8 mm Jaw Opening, 1.65 mm Length
187A.16CPE 数据手册
187A.16CPE | 187A.CPE - Combination pliers Description: ● Serrated flat and and oval pipe/cable gripping surfaces combined with a high perfomance cutting edges. ● Cutting edges designed to cleanly cut all types of wire: soft wires and modern materials to a maximum piano wire specification of: - 187A.16CPE : 1.8mm 215 kg/mm² - 187A.18CPE : 2.0mm 210 kg/mm² - 187A.20CPE : 2.2mm 205 kg/mm² - 187AP.20CPE : 2.2mm 205 kg/mm² ● 187AP features nail & screw gripping channels ● High Mechanical advantage due to off-set rivet and cutting edge geometry reducing effort. ● High durability Carbon alloy steel, with induction hardened cutting edges. ● Bi-Material ergonomic grips resistant to chemical agents featuring: - Return spring - Tether ready point (Tether point adds 10mm to nominal lenght) ● Chrome finish for corrosion resistance ● Made in France. 187A.16CPE Length L [mm] © FACOM 2020 165.0 Thickness E [mm] 9.5 Head Height C [mm] 34.0 Head Width B [mm] 21.0 Weight [g] 195.0 Piano Diameter [mm] 1.8 © FACOM 2020
187A.16CPE 价格&库存
很抱歉,暂时无法提供与“187A.16CPE”相匹配的价格&库存,您可以联系我们找货
187A.16CPE
    • 1+264.82388
    库存:37
