ATXR15X75
ATXR15X75
    FACOM
    FACOM - ATXR15X75 - Tamper Proof Screwdriver, T15 Tip, 75 mm Blade, 185 mm Overall, PROTWIST Series
ATXR15X75 数据手册
ATXR15X75 | ATXR - PROTWIST® screwdrivers for Resistorx® screws Description: ● Compliant with Resistorx® specifications. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 ATXR15X75 A [mm] 3.26 Diameter [mm] 30.0 Diameter D1 [mm] 3.5 Length L1 [mm] 75.0 Length L [mm] 185.0 Length L2 [mm] 110.0 Weight [g] 61.0 Resistorx Number ["] TT15 © FACOM 2020
ATXR15X75 价格&库存
很抱歉,暂时无法提供与“ATXR15X75”相匹配的价格&库存,您可以联系我们找货
