412B.10
412B.10
    FACOM
412B.10 数据手册
11 Bolt croppers and cable cutters u Mini croppers and wire cutters Small bolt cropper Sawing - Drilling - Cutting 997A.20 • Forged, hardened blades. • Cutting capacity : - Max.Piano wire d 2mm at 200kg/mmz. - Soft wire d 4mm at 60 kg/mmz. • Compact, lightweight tool with demultiplication system designed to cut hard and semi-hard wire, piano wire, bolts, rivets, pins and nails, etc. • Ergonomic hardened pressed-steel handles with adjustable, shock-absorbing end stop. • Spring-assisted opening. • Blades lock in closed position. • Bronzed blades, painted grips. E mm 4,5 F 997A.20 H mm 57 L mm 210 L1 mm 54,5 L2 mm 40 L1 L2 D g 275 H e L "Parrot nose" steel wire cutter 997A.P22 • For cutting hard wire up to 200 kg/mmz : d 2 mm using one hand. • Maximum capacity : d 8 mm. • Blades hardened to 240 kg/mmz. • 235 x 80 mm. D : 400 g. u Copper and aluminium cable cutters 412 Cable cutters 412B.10 "Compact" cable cutters, capacity 10 mm. • Integral opening spring. • Lock closed catch. • Cross proof design. 412.16 "Compact" cable cutters, capacity 16 mm. • Heavy-duty head, cross proof design. • Safety stop. 412.30-412.42 Heavy-duty cable cutters. • Powerful action, cuts without crushing electric cables. • Safety stop. F 412B.10 412.16 412.30 412.42 D min - max mm 53 - 190 80 - 370 155 - 1000 200 - 1300 r max wmmz Vmmz 45 50 75 85 185 210 400 430 E mm 10 14 16 16 L mm 170 290 600 800 412.30 A B mm mm 21 28 28 54 40 70 70 115 C mm 40 45 60 90 d mm 10 16 32 42 D g 225 670 2458 3695 412B.10 C A E L C F 412.L30 412.L42 504 Description Set of blades for 412.30 Set of blades for 412.42 www.facom.com B B A E L
412B.10 价格&库存
很抱歉,暂时无法提供与“412B.10”相匹配的价格&库存,您可以联系我们找货
412B.10
    • 1+599.61833
    库存:1
