440.5H
440.5H
    FACOM
440.5H 数据手册
440.5H | 440 - Metric combination wrenches Standards: NF ISO 691, NF ISO 7738, NF ISO 3318, NF ISO 1711-1, E74306, ISO 691, ISO 7738, ISO 3318, ISO 1711-1, DIN ISO 691, DIN 1711-1, DIN 3113, ASME B107.100 Description: ● Standard wrench for all common applications. ● High mechanical performance combined with compact design complying with aeronautical standards. ● Ring head: - Ring clearance (E dimension) designed for better access to serial-mounted or embedded screws. - OGV® profile 12-point ring for powerful tightening while protecting the nut. Suffix H = 6 sided ring. - Ring head with 15° angle. ● Open end head: - Open end with 15° angle. - Open end head-handle geometry optimized for increased accessibility. ● Metric dimensions: 4 to 41 mm. ● Satin chrome finish. © FACOM 2020 440.5H A [mm] 5.0 Length L [mm] 115.0 Thickness E [mm] 3.1 Thickness E1 [mm] 6.0 Thickness E2 [mm] 3.6 Head Width B [mm] 13.3 Head Width B1 [mm] 9,2 Weight [Kg] 0.016 © FACOM 2020
440.5H 价格&库存
很抱歉,暂时无法提供与“440.5H”相匹配的价格&库存,您可以联系我们找货
440.5H
    • 1+51.63181
    库存:87
