ATP1X100
ATP1X100
    FACOM
    FACOM - ATP1X100 - Screwdriver, Phillips, #1 Tip, 100 mm Blade Length, 209 mm OVL
ATP1X100 数据手册
ATP1X100 | ATP - PROTWIST® screwdrivers for Phillips® screws - round blades Standards: NF ISO 8764-1, NF ISO 8764-2, ISO 8764-1, ISO 8764-2, DIN ISO 8764-1, DIN ISO 8764-2, ASME B107.600 Description: ● Extra-long blade up to 400 mm for difficult and remote access. ● Inline Hardening Process – +50% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. ATP1X100 Diameter [mm] 30.0 Diameter D1 [mm] 4.5 Length L1 [mm] 100.0 © FACOM 2020 Length L [mm] 209.0 Length L2 [mm] 109.0 Weight [g] 76.0 Phillips Tip Number ["] PH1 © FACOM 2020
ATP1X100 价格&库存
很抱歉,暂时无法提供与“ATP1X100”相匹配的价格&库存,您可以联系我们找货
ATP1X100
    • 1+60.60854
    库存:412
