ATXRP10X75
ATXRP10X75
    FACOM
    FACOM - ATXRP10X75 - Tamper Proof Screwdriver, 10IP Tip, 75 mm Blade, 184 mm Overall, PROTWIST Serie...
ATXRP10X75 数据手册
ATXRP10X75 | ATXRP - PROTWIST® screwdrivers for Tamper Resistant Torx Plus® screws Description: ● Compliant with Tamper Resistant Torx Plus® specifications. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 ATXRP10X75 A [mm] 2.74 Diameter [mm] 30.0 Diameter D1 [mm] 3.0 Length L1 [mm] 75.0 Length L [mm] 184.0 Length L2 [mm] 109.0 Weight [g] 50.0 Resistorx Number ["] IPR10 © FACOM 2020
ATXRP10X75 价格&库存
很抱歉,暂时无法提供与“ATXRP10X75”相匹配的价格&库存,您可以联系我们找货
