ATX25X100
ATX25X100
    FACOM
    FACOM - ATX25X100 - Screwdriver, Torx, T25, 100 mm Blade, 220 mm Overall, PROTWIST Series
ATX25X100 数据手册
ATX25X100 | ATX - PROTWIST® screwdrivers for Torx® screws Description: ● Compliant with Torx® specifications. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 ATX25X100 A [mm] 4.4 Diameter D1 [mm] 5.0 Length L1 [mm] 100.0 Length L [mm] 220.0 Length L2 [mm] 120.0 Weight [g] 113.0 Torx Tip Number ["] T25 © FACOM 2020
ATX25X100 价格&库存
很抱歉,暂时无法提供与“ATX25X100”相匹配的价格&库存,您可以联系我们找货
