187A.18VE
187A.18VE
    FACOM
    FACOM - 187A.18VE - Combination Pliers, 1.8 mm Jaw Opening, 185 mm Length
187A.18VE 数据手册
187A.18VE | 187A.VE - 1,000 Volt insulated combination pliers Standards: NF ISO 5746, ISO 5746, DIN ISO 5746, ASME B107.500, NF EN 60900, EN 60900, DIN EN 60900 Description: ● For your safety, all pliers are tested individually at 10,000 volts for 10 seconds, at the end of the manufacturing cycle. ● Serrated flat and and oval pipe/cable gripping surfaces combined with a high perfomance cutting edges. ● Cutting edges designed to cleanly cut all types of wire: soft wires and modern materials to a maximum piano wire specification of: - 187A.16VE : 1.8mm 215 kg/mm² - 187A.18VE : 2.0mm 210 kg/mm² ● High mechanical advantage due to off-set rivet and cutting edge geometry reducing effort. ● High durability carbon alloy steel, with induction hardened cutting edges. ● Bi-Material ergonomic grips resistant to chemical agents featuring: - Return spring - Tether ready (Tether point adds 10mm to nominal lenght) ● Varnish finish to help prevent rusting. © FACOM 2020 187A.18VE Length L [mm] 185.0 Thickness E [mm] 10.0 Head Height C [mm] 36.0 Head Width B [mm] 23.0 © FACOM 2020
187A.18VE 价格&库存
很抱歉,暂时无法提供与“187A.18VE”相匹配的价格&库存,您可以联系我们找货
187A.18VE
    • 1+305.58364
    库存:23
