E.306A135J
E.306A135J
    FACOM
E.306A135J 数据手册
TORQUE CONTROL Electronic torque wrenches Series E.306A For accurate torquing, control and traceability! AVAILABLE NOVEMBER 2009 IN UK PERFORMANCE: • High Performance even under intensive use: accurate to ± 2% ±1 digit. • Can be preset to 9 torque values. • USB connection allows storage of 250 values. ERGONOMIC: • LEDs remain visible, even where access is difficult. • Ultra simple to use: self test and reset when switched on. • Visual and audible indications (LEDs and beeper). The ultra-simple operation and affordable price make this the ideal tool for both workshop and laboratory. INNOVATIONS 2009 Clés électronique Electronic indicating à lecture torquede wrenches couple 8 • ISO 6789 - DIN EN ISO 6789 – NF EN ISO 6789. • Accuracy: - ± 2% from 20% to 100% of full scale reading. • Measuring mode: peak or tracking. F E.306A30R E.306A135J E.306A135S E.306A200S E.306A340S • Measuring units N.m, ft.lb ; in.lb ; Kg.cm. • 9x12 or 14x18 end fittings. • Numbered and supplied with a calibration certificate ISO 6789 and supplied in a foam-lined plastic case. Electronic torque wrench 3148518349536 3148518349611 3148518349703 3148518349888 3148518349963 30 Nm 135 Nm 135 Nm 200 Nm 340 Nm Torque testers Torque testing available to all! FAST AND SIMPLE: Nm Min -max 1,5 - 30 6,7 - 135 7 - 135 10 - 200 17 - 340 End fitting L Ratchet Length 9 x 12 9 x 12 9 x 12 14 x 18 14 x 18 1/4" 3/8" 1/2" 1/2" 1/2" R.372 J.372V S.372V S.382V S.382V 390 mm 415 mm 415 mm 530 mm 650 mm Series E.2000 AVAILABLE NOVEMBER 2009 IN UK • Very easy to use with minimum adjustment to avoid errors. • For anything from a quick test before using a wrench up to an ISO6789 calibration certificate. • 3 testers to cover a large torque range from 2 to 1000 Nm. www.facom.com
E.306A135J 价格&库存
很抱歉,暂时无法提供与“E.306A135J”相匹配的价格&库存,您可以联系我们找货
