192A.16VE
192A.16VE
    FACOM
    FACOM - 192A.16VE - Cutter, Diagonal, 160 mm, 2 mm, 192A.VE Series
192A.16VE 数据手册
192A.16VE | 192A.VE - 1,000 Volt insulated highperformance diagonal cutters Description: ● For your safety, all pliers are tested individually at 10,000 volts for 10 seconds, at the end of the manufacturing cycle. ● New head design to increase durability and cutting capacity ● Cutting edges designed to cleanly cut all types of wire: soft wires and modern materials to a maximum piano wire specification of: - 192A.16VE : 2.0mm 210 kg/mm² - 192A.18VE : 2.2mm 205 kg/mm² ● High mechanical advantage due to off-set rivet and cutting edge geometry reducing effort. ● High durability carbon alloy steel, with induction hardened cutting edges. ● Bi-Material ergonomic grips resistant to chemical agents. - Return spring. Tether ready (Tether point adds 10mm to nominal length). ● Varnish finish to help prevent rusting. 192A.16VE Diameter D Maxi [mm] 2.0 Length L [mm] 160.0 © FACOM 2020 Thickness E [mm] 10.0 Head Height C [mm] 18.0 Head Width B [mm] 24.0 © FACOM 2020
192A.16VE 价格&库存
很抱歉,暂时无法提供与“192A.16VE”相匹配的价格&库存,您可以联系我们找货
