ATP.J5VE
ATP.J5VE
    FACOM
    FACOM - ATP.J5VE - Screwdriver Set, 5 Pieces, PROTWIST Series
ATP.J5VE 数据手册
ATP.J5VE | AT.VE - Sets of PROTWIST® 1,000 Volt insulated screwdrivers Description: ● For improved safety, each screwdriver is tested individually at 10,000 Volt for 10 seconds VDE approved. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. ATP.J5VE CONTENT SET [] 3.5mm, 4mm, 5.5mm, PH1, PH2 Weight [g] 430.0 © FACOM 2020
ATP.J5VE 价格&库存
很抱歉,暂时无法提供与“ATP.J5VE”相匹配的价格&库存,您可以联系我们找货
