190A.16VE
190A.16VE
    FACOM
    FACOM - 190A.16VE - Cutter, End, 160 mm, 2 mm, 190A.VE Series
190A.16VE 数据手册
190A.16VE | 1,000 Volt insulated high-performance end cutters Description: ● Cutting edges designed to cleanly cut all types of wire: soft wires and modern materials to a maximum piano wire specification of: - 190A.16VE: 2.0mm 210 kg/mm² ● High mechanical advantage due to off-set rivet and cutting edge geometry reducing effort. ● High durability Carbon alloy steel, with induction hardened cutting edges. ● Bi-Material ergonomic grips resistant to chemical agents. - Positive return spring - Tether ready tether point (Tether point adds 10mm to nominal length) 190A.16VE A [mm] 6.5 Length L [mm] 160.0 Thickness E [mm] 11.5 Head Height C [mm] 6.5 Head Width B [mm] 28.0 Height H [mm] 23.0 © FACOM 2020
190A.16VE 价格&库存
很抱歉,暂时无法提供与“190A.16VE”相匹配的价格&库存,您可以联系我们找货
