405.12MT
405.12MT
    FACOM
405.12MT 数据手册
? FI16_FOND+TXT F/EN 12/02/01 HELP 15:50 HOME Page 2 1/2 PR 1 + 12 REF S.1.. 3 148516 402608 INDEX 1.....Z INDEX a b c... ®»" HH -T-ETCEC O O R R IC IC M M MM OO séneed sliig CC FA "F«A nel. rae nsgpeécdiae spsio m d m te a a g ronfeaslss.ion ic e d s fe o le r p c A dUen e déewitahv ddeévveeloloppep t d e n e a u ç n co 400 MICRO-TECH ® TOOLS WITH DEDICATED FEATURES p to optimize gripping, cutting or handling small components. p Efficient storage for instant selection of the correct tool. p Antistatic tools providing electrostatic discharge protection (ESD). P ACCORDING TO CUT CUTTING EDGES AXIAL CUT ishirt thcehroig g n in e s o m o m ers ue ChC oenicéslepctrlioniq tr c c le in e p Un The Facom range offers three types. Choose the one best suited to your needs. ILLUSTRATION FEATURES WIRE TYPE Cutting edges are treated to achieve maximum strength and precision cutting of a wide range of materials, from piano wire to copper. Cu YES Cu-Ni alloy YES Mild steel 30 HRc YES OPERATION – Production work. Customer service (hi-fi) – Day-to-day use. Machine-tools – Maintenance. Automotive Domestic appliances Hard steel 50 HRc APPLICATION YES – Hard materials. Piano wire SEMI-FLUSH CUT Micro-chamfered cutting edges ensure high cutting capacity with clean finish. Precision is maintained throughout a long service life even in intensive use. Suitable for semi-hard wire. Cu YES Cu-Ni alloy YES FLUSH CUT 16 Mild steel 30 HRc Hard steel 50 HRc YES NO – High-frequency apparatus. Cu-Ni alloy YES – Maximum precision equipment. 30 HRc Hard steel 50 HRc Micro-engineering (hi-fi, labs) – Semi-hard materials. YES Mild steel Telephone exchanges Video and laser – Batch electronics. Cu Piano wire 16-2 Computers – Wiring. Piano wire This range is designed to give a through-cut without crushing the wire. Clean-cut ends allow reliable soldering, without damage to electronic components from arcing. Suitable for soft wire only. – Clean cut in intensive use NO – Cut-back before soldering. NO – Electrostatically sensitive components. Defence Aerospace Aviation Laboratory lp. 8 ? FI16_FOND+TXT F/EN 12/02/01 HELP HOME 15:50 PR Page 3 1/2 1 REF S.1.. + 12 INDEX 1.....Z 3 148516 402608 INDEX a b c... P ACCORDING TO PROFILE* • Bullet nose for strength d Cu wire (mm) 1 1,5 F NOSE DESIGN 0 405.8 MT-C-E 405.MT-C-E 405.10 MT-C-E 0,5 0,2 —> 1 405.10 RMT-RC-RE d max Fe wire 30 HRc 1 0,3 —> 1,4 0,7 0,8 0,4 —> 2,0 0,3 —> 1,1 0,3 —> 1,2 405.12 RMT-RC-RE* 0,4 — > 1,5 408.MT 0,4 — > 1,5 0,4 406.8-MT-C-E 0,7 0,1 — > 1,3 435.MT-C-E 0,1 — > 1,3 0,1 — > 1,2 415.MT-C-E 0,8 1,0 0,3 — > 2,0 0,1 — > 1,1 0,7 0,3 — > 1,5 0,1 — > 1,0 0,1 — > 0,8 • Angled nose for accuracy • End nose for reach 0,3 — > 1,6 416.RMT-RC* 0,1— > 0,9 407.8 MT-C-E 0,1 — > 0,8 407.MT-C-E • Pointed nose for control 1,0 435.RMT-RC-RE* 416.12 MT-C-E • Bullet nose for strength 0,7 0,7 0,7 416.PMT-C-E 0,1 — > 1,3 426.MT-E 0,1— > 1,2 427.MT-C-E 1 0,8 0,5 0,4 0,7 0,5 0,1 — > 1,3 425.MT-C-E 417.PMT-C-E 0,6 0,7 0,1 — > 1,1 416.MT-C-E 0,5 1 0,5 406.RMT-RC-RE* 415.RMT-RC*-RE* • Pointed nose for control 0,8 0,4 0,1 — > 1 406.MT-C-E 436.MT-E 0,5 1,0 • End nose for reach • Bullet nose for strength d max piano wire 0,5 0,3 —> 1,3 405.12MT-C-E 405.RMT-C-E 2 0,1 — > 0,8 0,2-->0,6 429.MT-C-E 0,2 — > 1,0 430.MT 0,2— > 1,0 418.MT 0,1 –> 0,6 428.MT 0,1 — > 0,8 16-3 1 1 ? FI16_FOND+TXT F/EN 12/02/01 HELP HOME 15:50 PR Page 4 1/2 1 12 + REF S.1.. 3 148516 402608 INDEX 1.....Z INDEX a b c... ® MICRO-TECH ELECTRONICS PLIERS QQQ DIAGONAL CUTTERS WITH BULLET NOSE FOR STRENGTH The bullet nose offers greater resilience compared with other profiles. The increased cutting capacity and long service life is useful in a wide variety of applications. AXIAL CUT All materials, any application. SEMI-FLUSH CUT Clean, long-life cut in semi-hard materials. FLUSH CUT Smooth cut for sound soldered connections. ■ Slim-joint models for precision W ISO 9654 • Suitable for miniature electronic components. D 60g. F 405.8MT 406.8MT 407.8MT Cut h H i Cu-Ni wire d mm 0,2 - 1 0,1 - 1 0,1 - 1 Piano wire Fe wire 30 HRc d mm d mm & 0,5 & & & & 9 110 8,5 6 ■ Compact models for manoeuvrability W ISO 9654 • Slimmer bullet-nose profile combines cutting performance with manoeuvrability. • Available with offcut retaining system. Models 405.MT and 405.RMT are suitable for cutting piano wire d 0,4 mm. D 60g. F 405.MT 405.RMT 406.MT 406.RMT 407.MT Cut h h H H i Cu-Ni wire d mm 0,3 - 1,3 0,3 - 1,1 0,1 - 1,3 0,1 - 1,1 0,1 - 1,3 Fe wire 30 HRc Piano wire d mm d mm 0,7 0,4 0,6 0,4 0,7 & 0,6 & & & Offcut retainer 9,5 • • 110 10,5 7 ■ Stocky models for versatility W ISO 9654 • Clean cut in a variety of materials from copper to piano wire up to d 0,5 mm. • Available with offcut retaining system. D 60g. 16 F Cut 405.10MT 405.10RMT h h Cu-Ni wire d mm 0,3 - 1,4 0,3 - 1,2 Fe wire 30 HRc d mm 0,8 0,7 Piano wire 0,5 0,5 Offcut retainer 11,5 110 • 10,5 7 16-4 ? FI16_FOND+TXT F/EN 12/02/01 HELP HOME 15:50 PR Page 5 1/2 1 12 REF S.1.. + 3 148516 402608 INDEX 1.....Z INDEX a b c... ■ Long-reach models for accessibility W ISO 9654 • Up to 1,5 to 2 mm more reach than standard cutting pliers. • Available with offcut retaining system. D 60g. F 435.MT 435.RMT 425.MT Cut H H i Cu-Ni wire d mm 0,1 - 1,3 0,1 - 1,1 0,1 - 1,3 Fe wire 30 HRc d mm 0,7 0,7 & Offcut retainer • 13 110 10,5 7 ■ Slim-nose model with back clearance W ISO 9654 • For cutting behind components and reaching under obstacles such as coil or resistor. D 60g. F 436.MT 426.MT Cut H i Cu-Ni wire d mm 0,1 - 1,2 0,1 - 1,2 Fe wire 30 HRc d mm 0,7 & Offcut retainer 13 110 10,5 7 5,5 ■ Heavy-duty models for power W ISO 9654 • For tough applications and repetitive work on a wide range of materials. • Piano wire: 405.12MT up to 0,8 mm; 405.12RMT up to 0,6 mm. • Available with offcut retaining system. D 95g. F 405.12MT 405.12RMT 415.MT 415.RMT Cut h h H H Cu-Ni wire d mm 0,4 - 2,0 0,4 -1,5 0,3 - 2,0 0,3 - 1,5 Fe wire 30 HRc d mm 1,0 0,9 0,9 0,8 Piano wire 0,8 0,6 & & Offcut retainer • • 16-5 ? FI16_FOND+TXT F/EN 12/02/01 HELP 15:50 HOME Page 6 PR 1/2 1 12 + REF S.1.. 3 148516 402608 INDEX 1.....Z INDEX a b c... QQQ DIAGONAL CUTTERS WITH POINTED NOSE FOR CONTROL The pointed nose is ideal where clearance is restricted and allows better visibility of the wire being cut. SEMI-FLUSH CUT Clean, long-life cut in semi-hard materials. FLUSH CUT Smooth cut for sound soldered connections. ■ Pointed models W ISO 9654 • Taper nose for improved accessibility. • Available with offcut retaining system. D 60g. F 416.MT 416.RMT Cut H H Cu-Ni wire d mm 0,1 - 1,0 0,1 - 0,9 Fe wire 30 HRc d mm 0,5 0,5 Offcut retainer 10,5 110 • 10,5 7 ■ Pointed slim-nose models for manoeuvrability W ISO 9654 • Slots in and around printed-circuit components, allowing good visibility. D 60g. F 416.PMT 417.PMT Cut H i Cu-Ni wire d mm 0,1 - 0,8 0,1 - 0,8 Fe wire 30 HRc d mm 0,4 & Offcut retainer 9,5 110 10,5 10,5 7 ■ 416.12MT Heavy-duty taper nose W ISO 9654 • • • • Suitably sized for production applications. Semi-flush cut. Cu-Ni wire d 0,3 to 1,6 mm. Fe wire 30 HRc up to d 0,7 mm. D 95g. 16 16 125 16 8 16-6 ? FI16_FOND+TXT F/EN HELP 12/02/01 15:50 HOME Page 7 PR 1/2 1 12 + REF S.1.. 3 148516 402608 INDEX 1.....Z INDEX a b c... ANGLED-NOSE CUTTING PLIERS FOR PRECISION • Ideal for use on printed circuits, electronic modules and hybrid circuits. • Designed for cutting right up against the board in the minutest spaces. • Flush cutting edges. ■ 427.MT 30° cutters • • • • Cutting edges at 30° with back clearance. Flush cut. Cu-Ni wire d 0,2 to 0,6 mm. 1 Fe wire 30 HRc. D 65g. 23 7 30 120 11 6 ■ 429.MT 70° cutters W ISO 9654 • • • • Wide edges at 70° with large back clearance. Flush cut. Cu-Ni wire d 0,2 to 1,0 mm. 1 Fe wire 30 HRc. D 60g. 12 110 70 11,5 7 12 ■ 430.MT 70° narrow cutters W ISO 9654 • Narrow edges at 70° with back clearance. • Flush cut. • Cu-Ni wire d 0,2 to 1,0 mm. • 1 Fe wire 30 HRc. . 60g. D 10 70 7 110 13 7 16-7 FLUSH CUT Smooth cut for clean soldered connections. ? FI16_FOND+TXT F/EN HELP 12/02/01 15:50 HOME Page 8 1/2 PR 1 12 + REF S.1.. 3 148516 402608 INDEX 1.....Z INDEX a b c... QQQ END CUTTERS FOR FRONT ACCESS • End cutting edges allow vertical access. • Extended profile reaches wires or components on crowded boards. ■ 418.MT End cutters W ISO 9654 • Long, narrow nose for vertical access. • Flush cut. • Cu-Ni wire d 0,1 to 0,6 mm. • 1 Fe wire 30 HRc. D 75g. 2,7 21 120 10,5 7 ■ 428.MT End cutters with adjustable stop W ISO 9654 • Similar to 418 but with 0 to 4 mm adjustment for precision cut at set distance from board. • Flush cut. • Cu-Ni wire d 0,1 to 0,6 mm. • 1 Fe wire 30 HRc. D 75g. 21 120 2,7 7 10,5 ■ 408.MT Heavy-duty end cutters W ISO 9654 • • • • Long nose for vertical access. Axial cut. Cu-Ni wire d 0,4 to 1,5 mm. Fe wire 30 HRc d up to 0,5 mm. D 100g. 16 39 150 4.5 17 10 16-8 AXIAL CUT All materials, any application. FLUSH CUT Smooth cut for sound soldered connections. ? FI16_FOND+TXT F/EN 12/02/01 HELP 15:50 HOME Page 9 PR 1/2 1 12 + REF S.1.. 3 148516 402608 QQQ CUTTING PLIERS FOR DIL, DIP AND CMS COMPONENTS • Ideal for use on printed circuits, electronic modules and hybrid circuits. • Designed for cutting right up against the board in very tight spaces. • Flush cutting edges. ■ 417.SPMT Diagonal cutters for DIP-SMD components • Designed to slot in the 0,65 mm gap between lugs of DIP components. The slender nose of this tool precludes its use for other purposes. • Flush cut. • Cu-Ni wire d 0,1 to 0,6 mm. D 60g. 10,5 110 10,5 7 ■ 437.MT Diagonal cutters for DIP components • Pointed, slim nose allows full access to DIP or SMD components. • Flush cut. • Cu-Ni wire d 0,1 to 0,6 mm. D 40g. 118 ■ 419.MT Inverted 45° cutters • Designed to reach DIP pins from behind on crowded boards. • Flush cut. • Cu-Ni wire d 0,1 to 0,5 mm. D 50g. 23 6,5 114,5 11 ■ 434.MT 45° cutters • • • • Cutting pliers angled at 45°. Nose aligning pin. Flush cut. Cu-Ni wire d 0,1 to 0,3 mm. D 40g. 4 115 16-9 INDEX 1.....Z INDEX a b c... ? FI16_FOND+TXT F/EN 12/02/01 HELP 15:51 HOME PR Page 10 1/2 1 REF S.1.. + 12 3 148516 402608 INDEX 1.....Z INDEX a b c... QQQ FLAT-NOSE GRIPPING PLIERS • These pliers serve all professional needs in laboratory, production and maintenance applications. • Smooth, rectangular-section jaws with contoured inside edges to protect components. • Matt black non-reflective finish. Leaf spring. ■ 401.MT Extended-nose pliers 5 1 48 14 160 W ISO 9655 8 • For extra power. D 80g. ■ 421.MT Rigid long-nose pliers 5 33 1 11 130 W ISO 9655 D 70g. 7 ■ 420.MT 21 Shaping pliers 1 9 125 W ISO 9655 7 • Very slim nose. D 60g. ■ 431.MT Short-nose pliers W ISO 9655 20 1 9 135 6 • Slim joint for precision work. D 55g. ■ 431.LMT 35 Snipe-nose pliers 1 9 135 W ISO 9655 6 • Slim joint for precision work. D 80g. ■ 443.12MT 16 19 8 Mini combination pliers • Side wire-cutter, capacity up to d 1,7 mm in Cu, d 1 mm in mild steel. • Stocky serrated nose, with tube-grip. • Matt black anti-glare finish. D 80g. 12 1 5 16-10 115 ? FI16_FOND+TXT F/EN 12/02/01 HELP 15:51 HOME PR Page 11 1/2 1 REF S.1.. + 12 3 148516 402608 INDEX 1.....Z INDEX a b c... QQQ HALF-ROUND NOSE GRIPPING PLIERS • These pliers serve all professional needs in laboratory, production and maintenance applications. • Smooth, half-round jaws with contoured inside edges to protect components. ■ 442.MT "Telephone" pliers 42 3,8 W ISO 9655 14 10 150 8 • • • • Long stocky nose with fine end serrations. Side cutter. Cu wire max. d 2 mm. Fe wire 30 HRc max. d 1 mm. D 88g. ■ 402.MT Extended-nose pliers 48 1,5 14 8 W ISO 9655 • For extra power. D 76g. 160 ■ 422.MT Rigid long-nose pliers W ISO 9655 D 70g. 33 0,5 7 11 130 ■ 432.MT 26 Short-nose pliers 9 W ISO 9655 6 • Slim joint. D 55g. 120 ■ 432.LMT 35 Snipe-nose pliers W ISO 9655 • Slim joint for precision work. D 65g. 1,6 9 140 ■ 403.MT 45 14 Extended-nose 40° pliers 155 W ISO 9655 8 • For extra power. D 75g. 40 16-11 • Matt black non-reflective finish. Leaf spring. ? FI16_FOND+TXT F/EN HELP 12/02/01 15:51 HOME PR Page 12 1/2 1 12 + REF S.1.. 3 148516 402608 INDEX 1.....Z INDEX a b c... ■ 423.MT Rigid-nose 60° pliers W ISO 9655 D 70g. 1,4 11 25 7 60 125 ■ 433.LMT Thin-nose 45° pliers W ISO 9655 • Slim joint for precision work. D 75g. 1,6 9 35 6 45 135 QQQ ROUND-NOSE GRIPPING PLIERS • These pliers serve all professional needs in laboratory, production and maintenance applications. • Ideal for curling and shaping wire. • Smooth and very slim round jaws, excellent for handling small wiring. ■ 404.MT Stocky pointed-nose pliers W ISO 9655 • Powerful forming tool ideal for loops. D 63g. 1 25 14 8 125 ■ 424.MT Rigid short-nose pliers W ISO 9655 D 55g. 16 2 22 11 7 120 16-12 lp. 8
405.12MT 价格&库存
很抱歉,暂时无法提供与“405.12MT”相匹配的价格&库存,您可以联系我们找货
405.12MT
    • 1+567.36667
    库存:195
