AT6.5X35
AT6.5X35
    FACOM
    FACOM - AT6.5X35 - Screwdriver, Slotted, 35 mm Blade, 6.5 mm Tip, 91 mm Overall, PROTWIST Series
AT6.5X35 数据手册
AT6.5X35 | AT - PROTWIST® screwdrivers for slotted head screws - short blades Standards: NF ISO 2380-1, NF ISO 2380-2, ISO 2380-1, ISO 2380-2, DIN ISO 2380-1, DIN ISO 2380-2, ASME B107.600 Description: ● Short round blade and ball handle for use in confined spaces. ● Inline Hardening Process – +50% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 AT6.5X35 A [mm] 6.5 Diameter [mm] 36.0 Diameter D1 [mm] 6.5 Length L1 [mm] 35.0 Length L [mm] 91.0 Length L2 [mm] 56.0 Thickness E [mm] 1.2 Width [mm] 6.5 Weight [g] 46.0 © FACOM 2020
AT6.5X35 价格&库存
很抱歉,暂时无法提供与“AT6.5X35”相匹配的价格&库存,您可以联系我们找货
