ATDVE.J6PB
ATDVE.J6PB
    FACOM
    FACOM - ATDVE.J6PB - Screwdriver Set, Slotted, Pozidriv, 6 Piece
ATDVE.J6PB 数据手册
ATDVE.J6PB - PROTWIST® VDE SCREWDRIVER SET – SLOTTED AN POZI-DRIVE® Description: • • • • • • Content; AT2.5x75VE – 2.5mm x 75mm Slotted Screwdriver 1000V VDE AT3.5x75VE – 3.5mm x 75mm Slotted Screwdriver 1000V VDE AT4x100VE – 4mm x 100mm Slotted Screwdriver 1000V VDE AT5.5x125VE – 5.5mm x 125mm Slotted Screwdriver 1000V VDE ATD1x100VE – PZ1 x 100mm Pozi-Drive® Screwdriver 1000V VDE ATD2x125VE – PZ2 x 125mm Pozi-Drive® Screwdriver 1000V VDE For improved safety, each screwdriver is individually tested are 10,000 Volts for 10 seconds VDE approved Inline hardening process - +100% tip life and +100% bar strength Handle Material – softer for more comfort while retaining chemical resistance Handle “Channel” - +10% torque Laser Marking – gives near permanent size identification CNC tip machining – gives better screw fit increasing torque transfer and reducing wear
ATDVE.J6PB 价格&库存
很抱歉,暂时无法提供与“ATDVE.J6PB”相匹配的价格&库存,您可以联系我们找货
