ATXR30X125
ATXR30X125
    FACOM
    FACOM - ATXR30X125 - Tamper Proof Screwdriver, T30 Tip, 125 mm Blade, 245 mm Overall, PROTWIST Serie...
ATXR30X125 数据手册
ATXR30X125 | ATXR - PROTWIST® screwdrivers for Resistorx® screws Description: ● Compliant with Resistorx® specifications. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 ATXR30X125 A [mm] 5.49 Diameter [mm] 36.0 Diameter D1 [mm] 6.0 Length L1 [mm] 125.0 Length L [mm] 245.0 Length L2 [mm] 120.0 Weight [g] 126.0 Resistorx Number ["] TT30 © FACOM 2020
ATXR30X125 价格&库存
很抱歉,暂时无法提供与“ATXR30X125”相匹配的价格&库存,您可以联系我们找货
