ATP2X400
ATP2X400
    FACOM
    FACOM - ATP2X400 - Phillips Screwdriver, #2 Tip, 400 mm Blade, 520 mm Overall, PROTWIST Series
ATP2X400 数据手册
ATP2X400 | ATP - PROTWIST® screwdrivers for Phillips® screws - round blades Standards: NF ISO 8764-1, NF ISO 8764-2, ISO 8764-1, ISO 8764-2, DIN ISO 8764-1, DIN ISO 8764-2, ASME B107.600 Description: ● Extra-long blade up to 400 mm for difficult and remote access. ● Inline Hardening Process – +50% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 ATP2X400 Diameter [mm] 36.0 Diameter D1 [mm] 6.0 Length L1 [mm] 400.0 Length L [mm] 520.0 Length L2 [mm] 120.0 Weight [g] 186.0 Phillips Tip Number ["] PH2 © FACOM 2020
ATP2X400 价格&库存
很抱歉,暂时无法提供与“ATP2X400”相匹配的价格&库存,您可以联系我们找货
