AEF.2.5X75
AEF.2.5X75
    FACOM
    FACOM - AEF.2.5X75 - Screwdriver, Slotted, 75 mm Blade, 2.5 mm Tip, 157 mm Overall
AEF.2.5X75 数据手册
section 18 EN -VALIDÉE 14/09/04 11:39 Page 670 GENERAL TOOLING MICRO-TECHJ SCREWDRIVERS 1. EFFICIENT The screwdriver end is designed to provide an effective pressure area in each of the three micro-engineering screwdriver positions. This end also rotates to optimize the turning motion. 6 1 2, 3. POWERFUL AND ACCURATE The body comprises a gripping surface designed for optimum torque transmission with handling accuracy. The handle is shaped fingers naturally grip the specially handle for total tool control. 4.QUICK AND EASY TO USE The ribbed cone provides a maximum grip for fast pre-tightening. Blade clearance gives a clear view of the job in hand. 2 3 5. A LARGE CHOICE OF BLADES A selection of over 50 high-precision steel or ceramic fixed or replaceable blades. 6. EASY IDENTIFICATION Micro-tech tools are colour-coded by size for instant selection of the correct tool. 4 5 Finger tip grip area Watch makers grip area ▼ SMALL SCREWDRIVER • Screw-lock chuck. • Burnished blade. F AE.1,2X35 AE.1,5X35 AEP.000X35 AEP.00X35 7d mm 1,2 x 35 1,5 x 35 2,0 x 35 2,5 x 35 9 mm 117 117 117 117 j p p p p d8 mm 17 x 82 17 x 82 17 x 82 17 x 82 D g 11,5 11,5 11,5 11,5 ▼ MICRO-TECHJ SCREWDRIVERS FOR SLOTTED HEADS • Revolving end. • Chromed blade, burnished tip. F AEF.1,5X35 AEF.1,8X35 AEF.2X35 AEF.2X75 AEF.2,5X35 AEF.2,5X75 AEF.3X75 AEF.3,5X75 AEF.4X75 7d mm 1,5 x 35 1,8 x 35 2,0 x 35 2,0 x 75 2,5 x 35 2,5 x 75 3,0 x 75 3,5 x 75 4,0 x 75 670 - F05 9 mm 117 117 117 157 117 157 168 168 168 j p p p p p p p p p d8 mm 17 x 82 17 x 82 17 x 82 17 x 82 17 x 82 17 x 82 21 x 93 21 x 93 21 x 93 D g 12,1 13,2 13,5 14,5 13,3 14,5 21,2 24,7 26,4 On-line catalogue available on www.facom.com Full palm grip area
AEF.2.5X75
PDF文档中提到的物料型号是FACOM品牌的螺丝刀。
这些螺丝刀的设计特点包括: 1. 高效:螺丝刀头设计提供了在三个微工程螺丝刀位置中的有效压力区域,并能旋转以优化转动动作。
2. 强大且精确:手柄设计有握持面,以实现最佳的扭矩传递和操作精度。
3. 快速且易于使用:肋状锥形提供最大的握持力,以快速预紧固。
4. 提供超过50种高精密钢制或陶瓷固定或可替换刀片的选择。
5. 易于识别:Micro-tech工具按尺寸彩色编码,便于快速选择正确工具。
具体的螺丝刀型号包括: - AE.1,2X35:1.2x35规格,长度117mm,头部尺寸17x82mm,重量11.5g。
- AE.1,5X35:1.5x35规格,长度117mm,头部尺寸17x82mm,重量11.5g。
- AEF.1,5X35:1.5x35规格,长度117mm,头部尺寸17x82mm,重量12.1g。
- AEF.2X35:2.0x35规格,长度117mm,头部尺寸17x82mm,重量13.5g。
还有其他型号如AEF.2X75、AEF.2,5X35、AEF.3X75等,具有不同的规格和尺寸。
FACOM的在线目录可以在www.facom.com上找到。
AEF.2.5X75 价格&库存
很抱歉,暂时无法提供与“AEF.2.5X75”相匹配的价格&库存,您可以联系我们找货
AEF.2.5X75
    • 1+68.01108
    库存:6
