AT5.5X150
AT5.5X150
    FACOM
    FACOM - AT5.5X150 - Screwdriver, Slotted, 150 mm Blade, 5.5 mm Tip, 259 mm Overall, PROTWIST Series
AT5.5X150 数据手册
AT5.5X150 | AT - PROTWIST® screwdrivers for slotted head screws - milled blades Standards: NF ISO 2380-1, NF ISO 2380-2, ISO 2380-1, ISO 2380-2, DIN ISO 2380-1, DIN ISO 2380-2, ASME B107.600 Description: ● Round shank for access in holes. ● Extra-long shank up to 300 mm for difficult and remote access. ● Inline Hardening Process – +100% Tip Life and +100% Bar Strength. ● Handle Material - Softer for more Comfort and still Chemical Resistant. ● Blade " tri-coating " treatment (ZincNickel-Chromium) - 4x Corrosion Resistance. ● Handle ‘Channel’ - +10% Torque. ● Laser Marking - gives virtually Permanent Marking. ● CNC tip machining - gives better Screw Fit increasing Torque Transfer and Reducing Wear. © FACOM 2020 AT5.5X150 A [mm] 5.5 Diameter [mm] 30.0 Diameter D1 [mm] 5.5 Length L1 [mm] 150.0 Length L [mm] 259.0 Length L2 [mm] 109.0 Thickness E [mm] 1.0 Width [mm] 5.5 Weight [g] 91.0 © FACOM 2020
AT5.5X150 价格&库存
很抱歉,暂时无法提供与“AT5.5X150”相匹配的价格&库存,您可以联系我们找货
AT5.5X150
    • 1+57.48438
    库存:68
