ATPA4V.J12APB
ATPA4V.J12APB
    FACOM
    FACOM - ATPA4V.J12APB - Screwdriver Set, 12 Pieces of 3 Bits Phillips Screw, 3 Tips Pozidriv & 4 Tor...
ATPA4V.J12APB 数据手册
12PCS SET WITH 50MM BIT SLEEVE E.612 AND 4V E-PROTWIST HANDLE Description: ● 4V E-Protwist handle. ● Speed: drives screws up to 4x faster vs a manual screwdriver. ● More efficiently, healthier approach to work. ● 300 Rpm for high speed screw fastening up to 0,9Nm. ● Provides reduced fatigue in low torque applications. ● Compact tool to transport easily. ● E-Protwist is portable and can be used easily. ● Electric screwdriver take less space to operate. ● Bi-material handle and protwist ergonomic design. ● Fast charging ( UCB-C) ; 70 minsaves your precious time. ● 3-stage LED battery charge indicator ( green – amber – red). ● 5 bulb LED workspace illumination. ● Forward & reverse push buttons. ● Quick change solution for bits. ● IP 54 rating for advanced water and chemical resistance. ● E.612 SET OF 10 BITS 50 MM LONG WITH GROOVE ● Drive 1/4" - 6.35 mm. ● Including: ● - 3 bits for Phillips® screws: EP.601T - EP.602T (x2). ● - 3 bits for Pozidriv®: ED.601T ED.602T (x2). ● - 4 Torx® bits: T10 - T20 - T25 - T30. © FACOM 2020 ● Supplied in compact high strength and chemical resistant polyamide case. Length L [mm] ATPA4V.J12APB © FACOM 2020 170 Diameter Weight Connection [mm] [kg] [in] 36 0.671 1/4
ATPA4V.J12APB 价格&库存
很抱歉,暂时无法提供与“ATPA4V.J12APB”相匹配的价格&库存,您可以联系我们找货
ATPA4V.J12APB
  • 1+1099.37837
库存:54
