190.130.000
190.130.000
    ROLEC
190.130.000 数据手册
Rolec Electronic and Electrical Enclosures - aluCASE Enclosures Home About Us Enclosures Technical Service Desk News Contact aluCASE THE NEW ENCLOSURES CONCEPT! aluCASE is our latest range of IP67 die-cast enclosures. Our design team have incorporated many new and unique features in order to create a much more modern and ergonomic series of off-the-shelf enclosures. Just take a look at these new features: 1 Recessed lid for membrane keypads or control panels - No need to crop around the screws 2 Screw ports for wall mounting even when the unit is assembled - No need for wall brackets 3 Clip-on trims hide the case and wall fixings - Enclosures with visible screws now look very dated 4 When open, the lid is retained by two straps (included) - No need for separate accessories 5 Modern integrated hinge design with no visible fixings - Ugly hinges now obsolete 6 Optional keylock incorporated in the hinge assembly - Better design than traditional keylocks 7 Also available from our Distributors http://www.rolec-enclosures.co.uk/enclosures/alucase/alucase.htm (1 of 6)03/01/2007 09:52:25 Rolec Electronic and Electrical Enclosures - aluCASE Enclosures aluCASE ENCLOSURES Part No. With Plastic Trims Grey RAL 7040 (click for price!) Part No. With Anodised Aluminium Trims (click for price!) Type W 191.090.000 191.090.100 AC 090 90 191.092.000 191.092.100 AC 092 90 190.110.000 190.110.100 190.112.000 E Weight Drawings PDF or DWG Formats 120 60 102 40 580g PDF DWG 160 60 142 40 680g PDF DWG ACF 110 110 140 60 122 60 700g PDF DWG 190.112.100 ACF 112 110 200 60 182 60 880g PDF DWG 190.130.000 190.130.100 ACF 130 130 160 70 142 80 910g PDF DWG 190.132.000 190.132.100 ACF 132 130 220 70 202 80 1,130g PDF DWG 190.150.000 190.150.100 ACF 150 150 180 60 162 100 968g PDF DWG http://www.rolec-enclosures.co.uk/enclosures/alucase/alucase.htm (2 of 6)03/01/2007 09:52:25 L H D Rolec Electronic and Electrical Enclosures - aluCASE Enclosures 191.150.000 191.150.100 AC 150 150 180 90 162 100 1,216g PDF DWG 190.152.000 190.152.100 ACF 152 150 260 60 242 100 1,273g PDF DWG 191.152.000 191.152.100 AC 152 150 260 90 242 100 1,569g PDF DWG 190.170.000 190.170.100 ACF 170 170 200 60 182 120 1,096g PDF DWG 191.170.000 191.170.100 AC 170 170 200 90 182 120 1,430g PDF DWG 190.172.000 190.172.100 ACF 172 170 280 60 262 120 1,471g PDF DWG 191.172.000 191.172.100 AC 172 170 280 90 262 120 1,789g PDF DWG aluCASE ENCLOSURES With Hinge Part No. (click for price!) Type W L H D E F Weight Drawing PDF or DWG formats 190.110.111 ACF 110 S 110 140 60 122 60 9.5 700g PDF DWG 190.112.111 ACF 112 S 110 200 60 182 60 9.5 880g PDF DWG 190.130.111 ACF 130 S 130 160 70 142 80 9.5 910g PDF DWG 190.132.111 ACF 132 S 130 220 70 202 80 9.5 1,130g PDF DWG 190.150.111 ACF 150 S 150 180 60 162 100 9.5 968g PDF DWG 191.150.111 AC 150 S 150 180 90 162 100 9.5 1,216g PDF DWG 190.152.111 ACF 152 S 150 260 60 242 100 9.5 1,273g PDF DWG 191.152.111 AC 152 S 150 260 90 242 100 9.5 1,569g PDF DWG 190.170.111 ACF 170 S 170 200 60 182 120 9.5 1,096g PDF DWG 191.170.111 AC 170 S 170 200 90 182 120 9.5 1,430g PDF DWG 190.172.111 ACF 172 S 170 280 60 262 120 9.5 1,471g PDF DWG 191.172.111 AC 172 S 170 280 90 262 120 9.5 1,789g PDF DWG aluCASE ENCLOSURES With Hinge & Integrated Keylock http://www.rolec-enclosures.co.uk/enclosures/alucase/alucase.htm (3 of 6)03/01/2007 09:52:25 Rolec Electronic and Electrical Enclosures - aluCASE Enclosures Part No. (click for price!) Type W L H D E F Weight Drawing PDF or DWG formats 190.110.115 ACF 110 ST 110 140 60 122 60 9.5 700g PDF DWG 190.112.115 ACF 112 ST 110 200 60 182 60 9.5 880g PDF DWG 190.130.115 ACF 130 ST 130 160 70 142 80 9.5 910g PDF DWG 190.132.115 ACF 132 ST 130 220 70 202 80 9.5 1,130g PDF DWG 190.150.115 ACF 150 ST 150 180 60 162 100 9.5 968g PDF DWG 191.150.115 AC 150 ST 150 180 90 162 100 9.5 1,216g PDF DWG 190.152.115 ACF 152 ST 150 260 60 242 100 9.5 1,273g PDF DWG 191.152.115 AC 152 ST 150 260 90 242 100 9.5 1,569g PDF DWG 190.170.115 ACF 170 ST 170 200 60 182 120 9.5 1,096g PDF DWG 191.170.115 AC 170 ST 170 200 90 182 120 9.5 1,430g PDF DWG 190.172.115 ACF 172 ST 170 280 60 262 120 9.5 1,471g PDF DWG 191.172.115 AC 172 ST 170 280 90 262 120 9.5 1,789g PDF DWG TECHNICAL DATA & OPTIONS Enclosure Die-cast aluminium: EN AC-44300 DIN EN 1706 (GD AL Si 12 / DIN 1725) Lid screws Captive screws in stainless steel 1.4567 Lid support straps PP (polypropylene) http://www.rolec-enclosures.co.uk/enclosures/alucase/alucase.htm (4 of 6)03/01/2007 09:52:25 Rolec Electronic and Electrical Enclosures - aluCASE Enclosures Clip-on Trims Plastic version - POM (polyoxymethylene) Grey RAL 7040 Aluminium version - Anodised Enclosure temperature range As per gasket type fitted. Ingress Protection IP 67 / DIN EN 60529:2000 IP 66 Gasket (Standard) Forprene gasket (siliconfree) (-40ºC to +150ºC). EMC Gasket (On request) Option 'EMV'* - EMC gasket fitted into the enclosure lid. Maintains IP 66 protection. (-30ºC to +100ºC). * - On request at extra cost. Internal mounting M5 threaded pillars in the lid and the base for mounting your assemblies. Condensation Glands - IP 67 (on request) Gortex condensation glands can be fitted to the cases on request. These are especially useful when there is a large variance in the operating temperature over a short period, which can result in condensation on the inside of the enclosure. These glands ventilate the case while maintaining IP67 protection. Finish / colour Standard - Window grey RAL 7040 Option 'K' - Chromatizing before painting* Option 'L' - Corrosion proof coating RAL 5009* Other options- stove-finished structured paint, special colours * * - at extra cost. Modifications We can supply the enclosures ready for your assemblies by drilling, milling, engraving, painting, silk-screen printing, adding inserts and much more. Just ask us for a quotation. More about customising... Request a catalogue return to enclosures index http://www.rolec-enclosures.co.uk/enclosures/alucase/alucase.htm (5 of 6)03/01/2007 09:52:25 Request a sample Rolec Electronic and Electrical Enclosures - aluCASE Enclosures Home About Us Enclosures Technical Service Desk News Contact CALL (01489) 583858 Legal notice: copyright © 2000-2005 OKW Enclosures Ltd, UK. All rights reserved. Rev:2005.09.27 Rolec ® is the registered trademark of Rolec Gehäuse-Systeme GmbH, Germany. http://www.rolec-enclosures.co.uk/enclosures/alucase/alucase.htm (6 of 6)03/01/2007 09:52:25
190.130.000 价格&库存
很抱歉,暂时无法提供与“190.130.000”相匹配的价格&库存,您可以联系我们找货
