1N4007R
1N4007R
    PINGWEI(平伟)
    DO-41(DO-204AL)
    1N4007R
1N4007R 数据手册
1N4007R 1.0AMP . SILICON RECTIFIERS DO-41 FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10sec/ 0.375" lead length at 5 lbs tension .787(20.0) MIN. .107(2.7) .080(2.0) + .205(5.2) .166(4.2) MECHANICAL DATA .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Mounting position: any DIA. - .787(20.0) MIN. .032(0.8) .025(0.65) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TA =55°C SYM BOL 1N 4007R units VRRM VRMS VDC 1000 V 700 V 1000 V IF(AV) 1.0 A IFSM 30.0 A VF VF 1.0 V 1.3 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 1.0A DC Maximum Forward Voltage at 3.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =100°C Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Storage Temperature Operation JunctionTemperature 5.0 IR 100.0 CJ R(JA) TSTG TJ 15 pF 75 °C/W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted. - 341 - µA RATING AND CHARACTERISTIC CURVES (1N4007R) Single Phase Half Wave 60Hz Resistive or inductive Load FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE TJ=25℃ Pulse Width=300μs 1% Duty Cycle .5 AMBIENT TEMPERTURE,(℃) 8 1.1 FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 100 8.3ms Single Half Sine-Wave (JEDEC Method) 1.4 INSTANEOUS FORWARD VOLTAGE,(V) TJ=25℃ - 342 - 1.7
1N4007R 价格&库存
很抱歉,暂时无法提供与“1N4007R”相匹配的价格&库存,您可以联系我们找货
