6A2
6A2
    PINGWEI(平伟)
    R-6
6A2 数据手册
6A05 THRU 6A10 6.0AMPS . SILICON RECTIFIERS R-6 FEATURE .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed: 260°C /10sec/ 0.375" lead length at 5 lbs tension 1.0(25.4) MIN. .360(9.1) DIA. .340(8.6) + .360(9.1) .340(8.6) MECHANICAL DATA .Terminal: Plated axial leads solderable per MIL-STD 202E, method 208C .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Mounting position: any - 1.0(25.4) MIN. .052(1.3) DIA. .048(1.2) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% SYM BOL Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) lead length at TA =55°C 6A05 6A1 6A2 6A4 6A6 6A8 6A10 units 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V 50 100 200 400 600 800 1000 V VRRM VRMS VDC IF(AV) 6.0 A IFSM 200.0 A VF 1.0 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 6.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =100°C Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Storage Temperature Operation JunctionTemperature 5.0 IR 200.0 CJ R(JA) TSTG TJ 100 pF 40 °C/W -55 to +150 °C -55 to +150 °C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted. - 357 - µA RATING AND CHARACTERISTIC CURVES (6A05 THRU 6A10) FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 100 3.0 Single Phase Half Wave 60Hz Resistive or inductive Load INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 6.0 10 TJ=25℃ Pulse Width=300μs 1% Duty Cycle 1.0 .1 5 7 0.9 .1 INSTANEOUS FORWARD VOLTAGE,(V) AMBIENT TEMPERTURE,(℃) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,(A) 400 300 8.3ms Single Half Sine-Wave (JEDEC Method) 200 100 INSTANEOUS REVERSE CURRENT,( μ A) 100 TJ=25℃ PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz - 358 -
很抱歉,暂时无法提供与“6A2”相匹配的价格&库存,您可以联系我们找货
