D110-DSS110
D110-DSS110
    PINGWEI(平伟)
    SMF(SOD-123FL)
    电压:100V 电流:1A
D110-DSS110 数据手册
DSS110 规格书 DSS110 1.0 AMP. SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS SOD-123FL FEATURES ·For surface mounted application ·High current capability ·Low forward voltage drop ·Low power loss, high efficiency ·High surge current capability ·High temperature soldering guaranteed: 250℃/10 seconds at terminals. MECHANICAL DATA ·Case: JEDEC SOD-123FL,molded plastic over passivated chip ·Terminals:Solder Plated, solderable per MIL-STD-750, Method 2026 ·Polarity: Color band denotes cathode end ·Weight: 0.006 ounces, 0.02 gram ·Mounting position: Any Dimensions in millimeters MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%. SYM BOL Type Number marking Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward rectified Current at TL =100°C DSS110 units D110 VRRM VRMS VDC 100 V 70 V 100 V IF(AV) 1.0 A IFSM 30.0 A VF 0.85 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) Maximum Instantaneous forward Voltage at 1.0 A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =100°C Typical Junction Capacitance (Note 1) Typical thermal resistance (Note 2) Storage Temperature Range Operation Temperature Range 0.1 IR 5.0 CJ R(JA) TSTG TJ Note: 1. Measured at 1MHz and applied reverse voltage of 4.0 volts d.c. 2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas 1 mA 28 pF 180 °C /W -55 to +150 °C -55 to +150 °C DSS110 规格书 RATING AND CHARACTERISTIC CURVES (DSS110 DSS110)) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 1.0 0.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1 0.1 TJ=25℃ Pulse Width=300us 1% Duty Cycle .01 200 .6 .4 .2 LEAD TEMPERTURE,(℃) .8 1.0 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 10 8.3ms Single Half Sine-Wave (JEDEC Method) 30 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 40 20 10 1.0 TJ=25℃ 0.1 .01 0 0 10 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 2 140
D110-DSS110 价格&库存
很抱歉,暂时无法提供与“D110-DSS110”相匹配的价格&库存,您可以联系我们找货
