GBU10005
THRU
GBU1010
Technical Data
Data Sheet N1770, Rev. A
GBU10005 THRU GBU1010
Single-Phase 10.0A Glass Passivated Bridge Rectifier
Features
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Plastic material-UL flammability 94V-0
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
GBU
Circuit Diagram
Mechanical Data
Case: GBU, Molded plastic
Terminals: Plated leads solderable per MIL-STD-202,
Method 208
Polarity: as marked on case
Mounting Position: Any
Lead Free: For RoHS / Lead Free Version
Maximum Ratings:@TA=25°C unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Type Number
Symbol
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VDC
RMS Reverse Voltage
VRMS
Average forward rectified output current
(Note 1)
@TA = 40°C
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
GBU
10005
50
35
GBU
1001
5
3
GBU
1002
GBU
1004
GBU
1006
GBU
1008
GBU
1010
Units
100
1
200
2
400
4
600
6
800
8
1000
1
V
70
7
140
1
280
2
420
4
560
5
700
1
V
IO
10
A
IFSM
200
A
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
GBU10005
THRU
GBU1010
Technical Data
Electrical Characteristics:@TA=25°C unless otherwise specified
Type Number
Symbol
GBU
10005
GBU
1001
GBU
1002
GBU
1004
GBU
1006
GBU
1008
GBU
1010
Units
VF
1.0
1.1
V
Peak Reverse Current
@TA = 25°C
At Rated DC Blocking Voltage @TA = 125°C
IRM
5.0
500
µA
Typical Junction Capacitance(per leg)
(Note 2)
CJ
70
pF
Forward Voltage (per element)
@IF =5A
@IF =10A
* Pulse width < 300 µs, duty cycle < 2%
Thermal-Mechanical Specifications:@TA=25°C unless otherwise specified
Type Number
Symbol
Typical Thermal Resistance (per leg)
Operating and Storage Temperature Range
GBU
10005
GBU
1001
GBU
1002
GBU
1004
GBU
1006
GBU
1008
GBU
1010
Units
RθJA
RθJL
25
2.2
°C/W
TJ, TSTG
-55 to +150
°C
Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C.
Ratings and Characteristics Curves
GBU10005
THRU
GBU1010
Technical Data
Ordering Information
Marking Diagram
Device
Package
Plating
Shipping
GBU10005
THRU
GBU1010
GBU
(Pb-Free)
Pure Sn
20pcs / tube
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
Where XXXXX is YYWWL
SSG
YY
WW
L
GBU10005
= SSG
= Year
= Week
= Lot Number
= Type Number
Cautions:Molding resin
Epoxy resin UL:94V-0
GBU10005
THRU
GBU1010
Technical Data
Mechanical Dimensions GBU (Inches/Millimeters)
GBU10005
THRU
GBU1010
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations.
很抱歉,暂时无法提供与“GBU1006TB”相匹配的价格&库存,您可以联系我们找货
