DTA124ECA
DTA124ECA
    HL(豪林)
    SOT-23
    DTA124ECA
DTA124ECA 数据手册
SHENZHEN HAOLIN ELECTRONICS TECHNOLOGY CO., LTD Digital transistors (built-in resistors) DTA124EE/DTA124EUA/DTA124ECA DTA124EKA/DTA124ESA DIGITAL TRANSISTOR (PNP) Features 1) Built-in bias resistors enable the configuration of an inverter circuit without connecting external input resistors (see equivalent circuit). 2) The bias resistors consist of thin-film resistors with complete isolation to allow negative biasing of the input. They also have the advantage of almost completely eliminating parasitic effects. 3) Only the on/off conditions need to be set for operation, making device design easy. PIN CONNENCTIONS AND MARKING DTA124EE SOT-523 DTA124EUA Addreviated symbol: 15 DTA124ESA TO-92S Addreviated symbol: 15 DTA114ECA DTA124ECA DTA124EKA SOT-23-3L SOT-323 Addreviated symbol: 15 SOT-23 Addreviated symbol: 15 Absolute maximum ratings(Ta=25℃) Limits (DTA124E ) Parameter Symbol Supply voltage VCC -50 V Input voltage VIN -40~10 V IO -30 IC(MAX) -100 Output current E UA 150 KA CA 200 SA Unit mA Power dissipation Pd 300 mW Junction temperature Tj 150 ℃ Storage temperature Tstg -55~150 ℃ Electrical characteristics (Ta=25℃) Parameter Input voltage Symbol Min. Typ VI(off) Max. -0.5 -3 VI(on) Unit V Conditions VCC=-5V ,IO=-100µA VO=-0.2V ,IO=-5 mA Output voltage VO(on) -0.3 V IO/II=-10mA/-0.5mA Input current II -0.36 mA VI=-5V Output current IO(off) -0.5 µA VCC=-50V ,VI=0 DC current gain GI 56 Input resistance R1 15.4 22 28.6 Resistance ratio R2/R1 0.8 1 1.2 Transition frequency fT Typical Characteristics VO=-5V ,IO=-5mA 250 KΩ MHz VO=-10V ,IO=-5mA,f=100MHz DTA124EE/EUA/EKA/ESA/ECA
DTA124ECA 价格&库存
很抱歉,暂时无法提供与“DTA124ECA”相匹配的价格&库存,您可以联系我们找货
