HF18N50
HF18N50
    HL(豪林)
    TO-220F
HF18N50 数据手册
H F18N50 500V N-Channel MOSFET FEATURES ⚫ Fast switching ⚫ 100% avalanche tested ⚫ Improved dv/dt capability APPLICATIONS ⚫ Switch Mode Power Supply (SMPS) ⚫ Uninterruptible Power Supply (UPS) ⚫ Power Factor Correction (PFC) Device Marking and Package Information Device Package Marking HF18N50 TO-220F HF18N50 Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDSS 500 V ID 18 A IDM 72 A VGSS ±30 V EAS 980 mJ IAS 14 A EAR 3.92 mJ PD 98 W TJ, Tstg -55~+150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Case RthJC 1.27 Thermal Resistance, Junction-to-Ambient RthJA 62.5 Drain-Source Voltage (VGS = 0V) Continuous Drain Current Pulsed Drain Current (note1) Gate-Source Voltage Single Pulse Avalanche Energy (note2) Avalanche Current (note1) Repetitive Avalanche Energy (note1) Power Dissipation (TC = 25ºC) Operating Junction and Storage Temperature Range Thermal Resistance Parameter ºC/W 1 V4.2 H F18N50 Specifications TJ = 25ºC, unless otherwise noted Value Parameter Symbol Test Conditions Unit Min. Typ. Max. -- Static Drain-Source Breakdown Voltage V(BR)DSS VGS = 0V, ID = 250µA 500 -- Zero Gate Voltage Drain Current IDSS VDS = 500V, VGS = 0V, TJ = 25ºC -- -- Gate-Source Leakage IGSS VGS = ±30V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 3.0 -- 4.0 V Drain-Source On-Resistance (Note3) RDS(on) VGS = 10V, ID = 9A -- 0.26 0.32 Ω -- 2367 -- -- 228 -- 1 V μA Dynamic Input Capacitance Ciss VGS = 0V, VDS = 25V, f = 1.0MHz Output Capacitance Coss Reverse Transfer Capacitance Crss -- 15 -- Total Gate Charge Qg -- 53.4 -- Gate-Source Charge Qgs -- 10 -- Gate-Drain Charge Qgd -- 20 -- Turn-on Delay Time td(on) -- 51.3 -- Turn-on Rise Time tr -- 36.5 -- Turn-off Delay Time td(off) -- 232 -- -- 61 -- -- -- 18 -- -- 72 -- -- 1.4 V -- 497 -- ns -- 4 -- μC Turn-off Fall Time VDD =400V, ID = 18A, VGS = 10V VDD = 250V, ID =18A, RG = 25 Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25 ºC Pulsed Diode Forward Current ISM Body Diode Voltage VSD Reverse Recovery Time trr Reverse Recovery Charge Qrr TJ = 25ºC, ISD = 9A, VGS = 0V VGS = 0V,IS = 18A, diF/dt =100A /μs A Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. L=10mH, VDD = 50V, RG = 25 Ω, Starting TJ = 25 ºC 3. Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 1% 2 V4.2 H F18N50 Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics (TJ = 25ºC) Figure 2. Body Diode Forward Voltage 35 102 ID, Drain Current (A) 25 20 IS, Source Current (A) 20V 10V 8V 7V 6V 5V 30 15 10 5 0 0 4 8 12 16 TJ = 150ºC 101 TJ = 25ºC 100 10-1 20 0.2 VDS, Drain-to-Source Voltage (V) 0.4 0.6 0.8 1 1.2 1.4 VSD, Source-to-Drain Voltage (V) Figure 3. Drain Current vs. Temperature Figure 4. BVDSS Variation vs. Temperature 1.2 18 VGS = 0V ID=250uA 1.15 BVDSS (Normalized) ID, Drain Current (A) 20 16 14 12 10 8 6 1.1 1.05 1 0.95 4 2 0.9 0 -50 25 50 75 100 125 TC, Case Temperature (A) 0 25 50 75 100 125 150 T C, Case Temperature (ºC) Figure 6. On-Resistance vs. Temperature RDS(on), On-Resistance (Normalized) Figure 5. Transfer Characteristics TJ = 25ºC ID, Drain Current (A) -25 150 TJ = 150ºC 3 VGS = 10V ID= 9A 2.5 2 1.5 1 0.5 0 -75 VGS, Gate-to-Source Voltage (V) -25 25 75 125 TJ, Junction Temperature (ºC) 3 V4.2 H F18N50 Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 7. Capacitance Figure 8. Gate Charge 10 VGS, Gate-to-Source Voltage (V) 104 Capacitance (pF) Ciss 103 Coss 102 Crss 101 VGS = 0V f = 1MHz 100 VDD = 100V VDD = 250V 8 VDD = 400V 6 4 2 0 0 10 20 30 40 VDS, Drain-to-Source Voltage (V) 0 10 20 30 40 50 60 Qg, Total Gate Charge (nC) Figure 9. Transient Thermal Impedance ZthJC, Thermal Impedance (K/W) 101 100 10-1 D = 0.5 D = 0.2 D = 0.1 D = 0.05 D = 0.02 D = 0.01 Single Pulse 10-2 10-3 10-6 10-5 10-4 10-3 10-2 10-1 100 101 Tp, Pulse Width (s) 4 V4.2 H F18N50 Figure A:Gate Charge Test Circuit and Waveform Figure B:Resistive Switching Test Circuit and Waveform Figure C:Unclamped Inductive Switching Test Circuit and Waveform 5 V4.2 H F18N50 TO-220F SYMBOLS A B B1 C C1 D E F G H L N Q ΦP 6 MILLIMETERS MIN MAX 9.70 15.50 8.99 4.40 2.15 2.50 0.70 0.40 1.12 3.40 12.60 2.34 3.15 3.00 10.30 16.10 9.39 4.80 2.55 2.90 0.90 0.60 1.42 3.80 13.60 2.74 3.55 3.30 V4.2
HF18N50
物料型号:HF18N50
器件简介: - 该器件是一款500V N-Channel MOSFET,具有快速开关特性。 - 经过100%的雪崩测试,提高了dv/dt能力。 - 适用于开关模式电源(SMPS)、不间断电源(UPS)和功率因数校正(PFC)。
引脚分配: - 封装类型为TO-220F。 - 器件标记为HF18N50。
参数特性: - 最大漏极-源极电压(Voss):500V - 连续漏极电流:18A - 脉冲漏极电流:72A - 栅极-源极电压(Vass):±30V - 单脉冲雪崩能量(EAS):980mJ - 雪崩电流(IAs):14A - 重复雪崩能量(EAR):3.92mJ - 功率耗散(Po):98W - 工作结温和存储温度范围(TJTstp):-55~+150°C
功能详解: - 静态特性包括漏极-源极击穿电压、栅极电流、栅极-源极阈值电压、漏极-源极导通电阻等。 - 动态特性包括输入电容、输出电容、反向传输电容、总栅极电荷、栅极-源极电荷、栅极-漏极电荷等。 - 还包括开启延迟时间、开启上升时间、关闭延迟时间、关闭下降时间等。
应用信息: - 适用于开关模式电源(SMPS)、不间断电源(UPS)和功率因数校正(PFC)。
封装信息: - 封装类型为TO-220F,提供了详细的封装尺寸,包括最小值和最大值。
HF18N50 价格&库存
很抱歉,暂时无法提供与“HF18N50”相匹配的价格&库存,您可以联系我们找货
