HA9N90
HA9N90
    HL(豪林)
    TO-3P-3
    900V N沟道 MOSFET,电流:9.0A,耐压:900V
HA9N90 数据手册
HA9N90 Apr 2009 BVDSS = 900 V RDS(on) typ 5ȍ HA9N90 ID = 9.0 A 900V N-Channel MOSFET TO-3P FEATURES ‰ Originative New Design 1 2 3 ‰ Superior Avalanche Rugged Technology ‰ Robust Gate Oxide Technology 1.Gate 2. Drain 3. Source ‰ Very Low Intrinsic Capacitances ‰ Excellent Switching Characteristics ‰ Unrivalled Gate Charge : 55 nC (Typ.) ‰ Extended Safe Operating Area ‰ Lower RDS(ON) 25ȍ 7\S #9GS=10V ‰ 100% Avalanche Tested Absolute Maximum Ratings Symbol TC=25୅ unless otherwise specified Parameter Value Units 900 V VDSS Drain-Source Voltage ID Drain Current – Continuous (TC = 25ఁ͚ 9.0 A Drain Current – Continuous (TC = 100ఁ͚ 5.7 A IDM Drain Current – Pulsed 36 A VGS Gate-Source Voltage ρͤ͡ V EAS Single Pulsed Avalanche Energy (Note 2) 900 mJ IAR Avalanche Current (Note 1) 9.0 A EAR Repetitive Avalanche Energy (Note 1) 28 mJ dv/dt Peak Diode Recovery dv/dt (Note 3) 4.0 V/ns PD Power Dissipation (TC = 25ఁ͚ ͞ ͵ΖΣΒΥΖ͑ΒΓΠΧΖ͑ͣͦఁ 280 W TJ, TSTG Operating and Storage Temperature Range TL Maximum lead temperature for soldering purposes, 1/8” from case for 5 seconds (Note 1) 2.22 W/ఁ -55 to +150 ఁ 300 ఁ Thermal Resistance Characteristics Symbol Parameter RșJC Junction-to-Case RșCS Case-to-Sink RșJA Junction-to-Ambient Typ. Max. -- 0.45 0.24 -- -- 40 Units ఁ͠Έ 1 Symbol Parameter HA9N90 Electrical Characteristics TC=25 qC unless otherwise specified Test Conditions Min Typ Max Units V On Characteristics VGS RDS(ON) Gate Threshold Voltage VDS = VGS, ID = 250 Ꮃ 2.5 -- 4.5 Static Drain-Source On-Resistance VGS = 10 V, ID = 4.5 A -- 1.25 1.4 VGS = 0 V, ID = 250 Ꮃ 900 -- -- V ID = 250 Ꮃ͑͝΃ΖΗΖΣΖΟΔΖΕ͑ΥΠͣͦఁ -- 0.99 -- ·͠ఁ VDS = 900 V, VGS = 0 V -- -- 10 Ꮃ VDS = 720 V, TC = 125ఁ -- -- 100 Ꮃ ‫ש‬ Off Characteristics BVDSS Drain-Source Breakdown Voltage ԩBVDSS Breakdown Voltage Temperature Coefficient /ԩTJ IDSS Zero Gate Voltage Drain Current IGSSF Gate-Body Leakage Current, Forward VGS = 30 V, VDS = 0 V -- -- 100 Ꮂ IGSSR Gate-Body Leakage Current, Reverse VGS = -30 V, VDS = 0 V -- -- -100 Ꮂ -- 2550 3310 Ꮔ -- 210 270 Ꮔ -- 18 23 Ꮔ -- 60 120 Ꭸ -- 145 290 Ꭸ -- 120 240 Ꭸ -- 90 180 Ꭸ -- 55 70 Οʹ -- 16 -- Οʹ -- 21 -- Οʹ Dynamic Characteristics Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance VDS = 25 V, VGS = 0 V, f = 1.0 MHz Switching Characteristics td(on) Turn-On Time tr Turn-On Rise Time td(off) Turn-Off Delay Time tf Turn-Off Fall Time Qg Total Gate Charge Qgs Gate-Source Charge Qgd VDS = 450 V, ID = 9.0 A, RG = 25 ‫ש‬ ͙ͿΠΥΖ͚͑ͥͦ͝ VDS = 720V, ID = 9.0 A, VGS = 10 V ͙ͿΠΥΖ͚͑ͥͦ͝ Gate-Drain Charge Source-Drain Diode Maximum Ratings and Characteristics IS Continuous Source-Drain Diode Forward Current -- -- 9.0 ISM Pulsed Source-Drain Diode Forward Current -- -- 36 VSD Source-Drain Diode Forward Voltage IS = 9.0 A, VGS = 0 V -- -- 1.4 V trr Reverse Recovery Time -- 660 -- Ꭸ Qrr Reverse Recovery Charge IS = 9.0 A, VGS = 0 V diFGW $ȝV(Note 4) -- 7.8 -- ȝ& A Notes ; 1. Repetitive Rating : Pulse width limited by maximum junction temperature 2. L=21mH, IAS=9.0A, VDD=50V, RG=25:, Starting TJ =25qC 3. ISD”$GLGW”$ȝV9DD”%9DSS , Starting TJ =25 qC 4. Pulse Test : Pulse Width ”ȝV'XW\&\FOH” 5. Essentially Independent of Operating Temperature 2 HA9N90 Typical Characteristics VGS 15.0 V 10.0 V 8.0 V 7.0 V 6.5 V 6.0 V Bottom : 5.5 V Top : ID, Drain Current [A] 1 10 ID, Drain Current [A] 1 10 0 10 o 150 C -55oC o 25 C 0 10 䈜㻌㻺㼛㼠㼑㼟㻌㻦 ȝ V3XOVH7HVW 2. TC = 25 䉝 -1 10 䈜㻌㻺㼛㼠㼑㼟㻌㻦 1. VDS = 50V ȝ V3XOVH7HVW -1 10 -1 0 10 2 1 10 10 4 6 8 10 VGS, Gate-Source Voltage [V] VDS, Drain-Source Voltage [V] Figure 1. On Region Characteristics Figure 2. Transfer Characteristics IDR, Reverse Drain Current [A] RDS(ON)>ȍ @ Drain-Source On-Resistance 3.0 2.5 VGS = 10V 2.0 VGS = 20V 1.5 1 10 0 10 25䉝 150 䉝 䈜㻌㻺㼛㼠㼑㼟㻌㻦 1. VGS = 0V ȝ V3XOVH7HVW 䈜㻌㻺㼛㼠㼑㻌㻦㻌㼀J = 25 䉝 -1 0 5 10 15 20 25 30 0.2 0.4 0.6 0.8 1.0 1.2 1.4 ID, Drain Current [A] VSD, Source-Drain voltage [V] Figure 3. On Resistance Variation vs Drain Current and Gate Voltage Figure 4. Body Diode Forward Voltage Variation with Source Current and Temperature 3500 3000 Ciss 2000 Coss 1500 䈜㻌㻺㼛㼠㼑㼟㻌㻦 1. VGS = 0 V 2. f = 1 MHz 1000 Crss 500 12 Ciss = Cgs + Cgd (Cds = shorted) Coss = Cds + Cgd Crss = Cgd 2500 Capacitance [pF] 10 VDS = 180V VGS, Gate-Source Voltage [V] 1.0 10 VDS = 450V VDS = 720V 8 6 4 2 䈜㻌㻺㼛㼠㼑㻌㻦㻌㻵D = 9A 0 -1 10 0 0 10 1 10 0 10 20 30 40 50 60 VDS, Drain-Source Voltage [V] QG, Total Gate Charge [nC] Figure 5. Capacitance Characteristics Figure 6. Gate Charge Characteristics 3 (continued) 1.2 3.0 RDS(ON), (Normalized) Drain-Source On-Resistance BVDSS, (Normalized) Drain-Source Breakdown Voltage HA9N90 Typical Characteristics 1.1 1.0 䈜㻌㻺㼛㼠㼑㼟㻌㻦 1. VGS = 0 V 2. ID ȝ $ 0.9 0.8 -100 -50 0 50 100 150 2.5 2.0 1.5 1.0 䈜㻌㻺㼛㼠㼑㼟㻌㻦 1. VGS = 10 V 2. ID = 4.5 A 0.5 0.0 -100 200 -50 0 50 100 150 200 o o TJ, Junction Temperature [ C] TJ, Junction Temperature [ C] Figure 7. Breakdown Voltage Variation vs Temperature Figure 8. On-Resistance Variation vs Temperature 10 Operation in This Area is Limited by R DS(on) 2 10 10 Ps ID, Drain Current [A] 1 ms 10 ms DC 0 10 -1 䈜㻌㻺㼛㼠㼑㼟㻌㻦 o 1. TC = 25 C o 2. TJ = 150 C 3. Single Pulse 10 0 10 6 4 2 -2 10 1 2 10 0 25 3 10 10 50 75 100 125 150 TC, Case Temperature [ 䉝㼉 VDS, Drain-Source Voltage [V] Figure 9. Maximum Safe Operating Area Zș -&(t), Thermal Response ID, Drain Current [A] 8 100 Ps 1 10 Figure 10. Maximum Drain Current vs Case Temperature D=0.5 0.2 -1 10 䈜㻌㻺㼛㼠㼑㼟㻌㻦 1. Zș -&(t) = 0.45 䉝㻛㼃 㻌㻹㼍㼤㻚 2. Duty Factor, D=t1/t2 3. TJM - TC = PDM * Zș -&(t) 0.1 0.05 PDM 0.02 0.01 -5 10 t1 single pulse -2 10 -4 10 -3 10 -2 10 -1 10 t2 0 10 1 10 t1, Square Wave Pulse Duration [sec] Figure 11. Transient Thermal Response Curve 4 HA9N90 Fig 12. Gate Charge Test Circuit & Waveform .ȍ 12V VGS Same Type as DUT Qg 200nF 10V 300nF VDS VGS Qgs Qgd DUT 3mA Charge Fig 13. Resistive Switching Test Circuit & Waveforms RL VDS VDS 90% VDD RG ( 0.5 rated VDS ) Vin DUT 10V 10% td(on) tr td(off) t on tf t off Fig 14. Unclamped Inductive Switching Test Circuit & Waveforms BVDSS 1 EAS = ---- LL IAS2 -------------------2 BVDSS -- VDD L VDS VDD ID BVDSS IAS RG 10V ID (t) DUT VDS (t) VDD tp Time 5 HA9N90 Fig 15. Peak Diode Recovery dv/dt Test Circuit & Waveforms DUT + VDS _ IS L Driver RG VGS VGS ( Driver ) Same Type as DUT VDD • dv/dt controlled by RG • IS controlled by pulse period Gate Pulse Width D = -------------------------Gate Pulse Period 10V IFM , Body Diode Forward Current IS ( DUT ) di/dt IRM Body Diode Reverse Current VDS ( DUT ) Body Diode Recovery dv/dt Vf VDD Body Diode Forward Voltage Drop 6 HA9N90 Package Dimension {vTZw 7
HA9N90 价格&库存
很抱歉,暂时无法提供与“HA9N90”相匹配的价格&库存,您可以联系我们找货
