www.msksemi.com
AZ4208-01F-MS
Semiconductor
Compiance
Feature
80W peak pulse power per line (tP = 8/20μs)
Replacement for MLV(0402)
Bidirectional configurations
Response time is typically < 1ns
Low clamping voltage
RoHS compliant
Transient protection for data lines to
IEC61000-4-2(ESD) ±30KV(air), ±30KV(contact);
DFN1006P2X
IEC61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 2 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Applications
Cellular phones
Portable devices
Digital cameras
Power supplies
Electrical characteristics per line@25℃ (unless otherwise specified)
Parameter
Symbol
Peak Reverse Working Voltage
Breakdown Voltage
Reverse Leakage Current
Maximum Reverse Peak Pulse
Conditions
Min.
Typ.
Max.
Units
8
V
13.0
V
1.0
μA
VRWM
VBR
It = 1mA
IR
9.0
11.0
VRWM = 5V T=25℃
5.0
IPP
A
Clamping Voltage
VC
IPP=1A
13
V
Clamping Voltage
VC
IPP=3A
15
V
Clamping Voltage
VC
IPP=5A
17
V
15
pF
Junction Capacitance
Cj
VR=0V f = 1MHz
13
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Peak Pulse Power (tp=8/20μs)
Ppp
80
W
Operating Temperature
TJ
-55 to +150
Storage Temperature
TSTG
-55 to +150
www.msksemi.com
AZ4208-01F-MS
Semiconductor
Compiance
Electrical Parameter
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @
VRWM
IT
Test Current
VBR
Breakdown Voltage @ IT
11.2
IR(nA)
11.0
10.8
12
8
4
10.6
10.4
-55
+25
+150
50
75
100
125
Temperature (ºC)
Temperature (ºC)
Fig .Typical Breakdown Voltage vs. Temperature
Fig .Typical Leakage Current vs. Temperature
150
30
Pulse waveform: tp=8/20us
24
VC-Clamping Voltage (V)
Breakdown Voltage (V) (VZ @ IZ)
11.4
18
12
6
4
6
8
IPP-Peak pulse current (A)
Fig Clamping voltage vs. Peak pulse current
www.msksemi.com
AZ4208-01F-MS
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
A
Dim
B
C
R
D
E
MIN
Millimeters
MAX
MIN
MAX
A
0.0125
0.02
0.32
0.52
B
0.000
0.002
0.00
0.05
C
0.037
0.043
0.95
1.080
D
0.022
0.027
0.55
0.680
E
0.016
0.024
0.40
0.60
F
0.008
0.012
0.20
0.30
H
R
F
Inches
0.015Typ.
0.001
0.40Typ.
0.005
0.05
0.15
H
1.20
0.50
0.60
0.70
NOTES:
1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES).
2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY.
CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR
COMPANY'S MANUFACTURING GUIDELINES ARE MET.
REEL SPECIFICATION
P/N
PKG
AZ4208-01F-MS
DFN1006P2X
QTY
12000
www.msksemi.com
AZ4208-01F-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“AZ4208-01F-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45900
- 100+0.36569
- 300+0.31904
- 1000+0.28404
- 5000+0.22691
- 12000+0.21287
