www.msksemi.com
ESD9B5.0ST5G
Semiconductor
Compiance
Feature
80W peak pulse power per line (tP = 8/20μs)
SOD-923 package
Replacement for MLV(0402)
Bidirectional configurations
Response time is typically < 1ns
Low clamping voltage
RoHS compliant
Transient protection for data lines to
EC61000-4-2(ESD) ±30KV(air), ±30KV(contact );
IEC61000-4-4 (EFT) 40A (5/50ns)
Applications
Cellular phones
SOD-923
Portable devices
Digital cameras
Power supplies
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 1 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Electronics Parameter
Symbol
Parameter
VRWM
Peak Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
PPP
Peak Pulse Power
CJ
Junction Capacitance
IF
Forward Current
VF
Forward Voltage @ IF
IPP
VC VBR VRW M
IT
IR
I
IR
IT
VRW M VBR VC
V
IPP
www.msksemi.com
ESD9B5.0ST5G
Semiconductor
Compiance
Electrical characteristics per line@25℃ (unless otherwise specified)
Parameter
Symbol
Conditions
Min.
VRWM
Breakdown Voltage
VBR
It = 1mA
IR
VRWM = 5V T=25℃
IPP
Clamping Voltage
VC
IPP=1A
8
V
Clamping Voltage
VC
IPP=3A
13
V
Clamping Voltage
VC
IPP=5A
15
V
Cj
VR=0V f = 1MHz
15
pF
5.6
Typ.
Max.
Units
5
V
7.8
V
1.0
μA
6.7
A
5
12
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Peak Pulse Power (tp=8/20μs)
Ppp
80
W
Operating Temperature
TJ
-55 to +150
Storage Temperature
TSTG
-55 to +150
Typical Characteristics
100
80
80
60
% Of Rated Power
IPP – Peak Pulse Current - % of
IPP
tf=8μs
100
tP =20μs( IPP /2)
40
40
10
15
t - Time -μs
Fig 1.Pulse Waveform
25
30
50
75
100
125
150
TL – Lead Temperature - ℃
Fig 2.Power Derating Curve
www.msksemi.com
ESD9B5.0ST5G
Semiconductor
Compiance
7.1
6.9
12
IR(nA)
Breakdown Voltage (V) (VZ @ IZ)
7.3
8
6.7
4
6.5
6.3
-55
+25
50
Temperature (ºC)
75
100
125
150
Temperature (ºC)
Fig 3.Typical Breakdown Voltage vs. Temperature
Fig 4.Typical Leakage Current vs. Temperature
Pulse waveform: tp=8/20us
Peak Pulse Power (W)
VC-Clamping Voltage (V)
16
12
8
4
4
6
IPP-Peak pulse current (A)
Fig 5. Clamping voltage vs. Peak pulse current
8
100
10
1
1
10
100
1000
Pulse Duration(us)
Fig 6. Non-Repetitive Peak Pulse Power vs. Pulse time
www.msksemi.com
ESD9B5.0ST5G
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Dim
Millimeters
Inches
Min
Nom
Max
Min
Nom
Max
A
0.36
0.40
0.43
0.014
0.016
0.017
b
0.15
0.20
0.25
0.006
0.008
0.010
c
0.07
0.12
0.17
0.003
0.005
0.007
D
0.75
0.80
0.85
0.030
0.031
0.033
E
0.55
0.60
0.65
0.022
0.024
0.026
HE
0.95
1.00
1.05
0.037
0.039
0.041
L
0.05
0.10
0.15
0.002
0.004
0.006
Dimensions: Millimeters
REEL SPECIFICATION
P/N
PKG
QTY
ESD9B5.0ST5G
SOD-923
8000
www.msksemi.com
ESD9B5.0ST5G
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“ESD9B5.0ST5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19196
- 200+0.15873
- 600+0.14026
- 2000+0.12918
- 8000+0.08650
- 16000+0.08126
- 国内价格
- 1+0.41910
- 500+0.13970
- 4000+0.09306
- 8000+0.07634
