DB101-DB107
BRIDGE RECTIFIERS
Features
DB-1
Glass Passivated Die Construction
Low leakage
Ideal for printed circuit board
Surge overload rating-30A peak
· Designed for Surface Mount Application
· Plastic Material-UL Flammability 94V-O
Mechanical Data
· Case:Reliable low cost construction
utilizing molded plastic technique
· Terminals:Plated Leads Solderable per
MIL-STD-202,Method208
· Polarity:As Marked on Case
· Mounting Position:Any
· Marking:Type Number
Maximum Ratings and Electrical Characteristics @TA=25℃ unless otherwise specified
Single Phase,half wave,60Hz,resistive or inductive load.For capacitive load,derate current by 20%.
Parameter
Symbol DB101 DB102 DB103 DB104 DB105 DB106 DB107 UNIT
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average forward output rectified
current @TA=40℃
Peak forward surge current 8.3ms single
sine-wave superimposed on rated load(JEDEC
Method)
Maximum instantaneous forward voltage drop
per diode @1.0A
Maximum DC reverse current at TA=25℃
rated DC blocking voltage per leg TA=125℃
Typical thermal resistance per leg (Note1)
Operating junction temperature range
storage temperature range
I(AV)
1
A
IF SM
30
A
VF
1.1
V
IR
5.0
500
uA
RθJA
40
RθJL
15
TJ
-55 to +150
Tstg
-55 to +150
Note:
1.Mounted on glass epoxy PC board with 1.3mm² solder pad.
2.Mounted on aluminum substrate PC board with 1.3mm² solder pad.
3.Measured at 1.0MHz and applied reverse of 4.0V D.C.
version: 02
http://www.trr-jx.com
℃/W
DB101-DB107
BRIDGE RECTIFIERS
Characteristic Curves
version: 02
(TA=25 ℃ unless otherwise noted)
很抱歉,暂时无法提供与“DB107”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34094
- 100+0.27302
- 300+0.22224
- 1000+0.19679
- 5000+0.17648
- 10000+0.16622
