74AVC8T245PW
74AVC8T245PW
    NEXPERIA(安世)
    TSSOP24_7.8X4.4MM
    74AVC8T245PW
74AVC8T245PW 数据手册
74AVC8T245 8-bit dual supply translating transceiver with configurable voltage translation; 3-state Rev. 5 — 27 December 2012 Product data sheet 1. General description The 74AVC8T245 is an 8-bit, dual supply transceiver that enables bidirectional level translation. It features two 8-bit input-output ports (An and Bn), a direction control input (DIR), a output enable input (OE) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 0.8 V and 3.6 V making the device suitable for translating between any of the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins An, OE and DIR are referenced to VCC(A) and pins Bn are referenced to VCC(B). A HIGH on DIR allows transmission from An to Bn and a LOW on DIR allows transmission from Bn to An. The output enable input (OE) can be used to disable the outputs so the buses are effectively isolated. The device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both An and Bn are in the high-impedance OFF-state. 2. Features and benefits  Wide supply voltage range:  VCC(A): 0.8 V to 3.6 V  VCC(B): 0.8 V to 3.6 V  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114E Class 3B exceeds 8000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101C exceeds 1000 V  Maximum data rates:  380 Mbit/s ( 1.8 V to 3.3 V translation)  260 Mbit/s ( 1.1 V to 3.3 V translation)  260 Mbit/s ( 1.1 V to 2.5 V translation)  210 Mbit/s ( 1.1 V to 1.8 V translation)  150 Mbit/s ( 1.1 V to 1.5 V translation)  100 Mbit/s ( 1.1 V to 1.2 V translation) 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state       Suspend mode Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 3.6 V IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 74AVC8T245PW 40 C to +125 C TSSOP24 74AVC8T245BQ 40 C to +125 C DHVQFN24 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5  5.5  0.85 mm SOT815-1 4. Functional diagram B1 B2 21 VCC(A) OE DIR Fig 1. B3 20 B4 19 B5 18 B6 17 B7 16 B8 15 14 VCC(B) 22 2 3 4 5 6 7 8 9 A1 A2 A3 A4 A5 A6 A7 10 A8 001aai472 Logic symbol 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 2 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state DIR OE A1 B1 VCC(B) VCC(A) to other seven channels Fig 2. 001aai473 Logic diagram (one channel) 5. Pinning information 5.1 Pinning terminal 1 index area 1 74AVC8T245 24 VCC(B) VCC(A) 74AVC8T245 VCC(A) 1 24 VCC(B) DIR 2 A1 3 23 VCC(B) 22 OE A2 4 21 B1 A3 5 20 B2 A4 6 19 B3 A5 7 18 B4 A6 8 17 B5 A7 9 16 B6 A8 10 15 B7 GND 11 14 B8 GND 12 13 GND DIR 2 A1 3 23 VCC(B) 22 OE A2 4 21 B1 A3 5 20 B2 A4 6 19 B3 A5 7 18 B4 A6 8 17 B5 A7 9 16 B6 GND(1) A8 10 15 B7 GND 13 14 B8 GND 12 GND 11 001aai490 Transparent top view 001aai489 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 3. Pin configuration TSSOP24 74AVC8T245 Product data sheet Fig 4. Pin configuration DHVQFN24 All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 3 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description VCC(A) 1 supply voltage A (An, OE and DIR inputs are referenced to VCC(A)) DIR 2 direction control A1 to A8 3, 4, 5, 6, 7, 8, 9, 10 data input or output GND[1] 11 ground (0 V) GND[1] 12 ground (0 V) GND[1] 13 ground (0 V) B1 to B8 21, 20, 19, 18, 17, 16, 15, 14 data input or output OE 22 output enable input (active LOW) VCC(B) 23 supply voltage B (Bn inputs are referenced to VCC(B)) VCC(B) 24 supply voltage B (Bn inputs are referenced to VCC(B)) [1] All GND pins must be connected to ground (0 V). 6. Functional description Table 3. Function table[1] Input/output[3] Supply voltage Input VCC(A), VCC(B) OE[2] DIR[2] An[2] Bn 0.8 V to 3.6 V L L An = Bn input 0.8 V to 3.6 V L H input Bn = An 0.8 V to 3.6 V H X Z Z GND[3] X X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. [2] The An, DIR and OE input circuit is referenced to VCC(A); The Bn input circuit is referenced to VCC(B). [3] If at least one of VCC(A) or VCC(B) is at GND level, the device goes into suspend mode. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC(A) Min Max Unit supply voltage A 0.5 +4.6 V VCC(B) supply voltage B 0.5 +4.6 V 50 - mA 0.5 +4.6 V IIK input clamping current VI input voltage IOK output clamping current VO output voltage Conditions VI < 0 V [1] 50 - mA [1][2][3] 0.5 VCCO + 0.5 V [1] VO < 0 V Active mode 0.5 +4.6 V IO output current VO = 0 V to VCC - 50 mA ICC supply current per VCC(A) or VCC(B) pin - 100 mA Suspend or 3-state mode 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 4 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit IGND ground current per GND pin 100 - mA Tstg storage temperature 65 +150 C - 500 mW Tamb = 40 C to +125 C total power dissipation Ptot [4] [1] The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] VCCO is the supply voltage associated with the output port. [3] VCCO + 0.5 V should not exceed 4.6 V. [4] For TSSOP24 package: Ptot derates linearly at 5.5 mW/K above 60 C. For DHVQFN24 package: Ptot derates linearly at 4.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC(A) supply voltage A VCC(B) supply voltage B 0.8 3.6 V VI input voltage 0 3.6 V VO output voltage 0 VCCO V 0 3.6 V Active mode [1] Suspend or 3-state mode Tamb ambient temperature t/V input transition rise and fall rate VCCI = 0.8 V to 3.6 V [1] VCCO is the supply voltage associated with the output port. [2] VCCI is the supply voltage associated with the input port. [2] Min Max Unit 0.8 3.6 V 40 +125 C - 5 ns/V 9. Static characteristics Table 6. Typical static characteristics at Tamb = 25 C[1][2] At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH HIGH-level output voltage Conditions IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V VOL LOW-level output voltage VI = VIH or VIL II input leakage current DIR, OE input; VI = 0 V or 3.6 V; VCC(A) = VCC(B) = 0.8 V to 3.6 V IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCC(A) = VCC(B) = 3.6 V IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V 74AVC8T245 Product data sheet Min Typ Max Unit - 0.69 - V - V VI = VIH or VIL - 0.07 - 0.025 0.25 A [3] - 0.5 2.5 A suspend mode A port; VO = 0 V or VCCO; VCC(A) = 3.6 V; VCC(B) = 0 V [3] - 0.5 2.5 A suspend mode B port; VO = 0 V or VCCO; VCC(A) = 0 V; VCC(B) = 3.6 V [3] - 0.5 2.5 A All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 5 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 6. Typical static characteristics at Tamb = 25 C[1][2] …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IOFF A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V - 0.1 1 A B port; VI or VO = 0 V to 3.6 V; VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V - 0.1 1 A power-off leakage current CI input capacitance DIR, OE input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V - 1.5 - pF CI/O input/output capacitance A and B port; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V - 4.3 - pF [1] VCCO is the supply voltage associated with the output port. [2] VCCI is the supply voltage associated with the data input port. [3] For I/O ports, the parameter IOZ includes the input leakage current. Table 7. Static characteristics [1][2] At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage 40 C to +85 C Conditions 40 C to +125 C Unit Min Max Min Max VCCI = 0.8 V 0.70VCCI - 0.70VCCI - V VCCI = 1.1 V to 1.95 V 0.65VCCI - 0.65VCCI - V VCCI = 2.3 V to 2.7 V 1.6 - 1.6 - V VCCI = 3.0 V to 3.6 V 2 - 2 - V VCC(A) = 0.8 V 0.70VCC(A) - 0.70VCC(A) - V VCC(A) = 1.1 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCC(A) = 2.3 V to 2.7 V 1.6 - 1.6 - V VCC(A) = 3.0 V to 3.6 V 2 - 2 - V - 0.30VCCI - 0.30VCCI V VCCI = 1.1 V to 1.95 V - 0.35VCCI - 0.35VCCI V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V data input DIR, OE input VIL LOW-level input voltage data input VCCI = 0.8 V DIR, OE input 74AVC8T245 Product data sheet VCC(A) = 0.8 V - 0.30VCC(A) - 0.30VCC(A) V VCC(A) = 1.1 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCC(A) = 2.3 V to 2.7 V - 0.7 - 0.7 V VCC(A) = 3.0 V to 3.6 V - 0.8 - 0.8 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 6 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 7. Static characteristics …continued[1][2] At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH VOL 40 C to +85 C Conditions 40 C to +125 C Unit Min Max Min Max VCCO  0.1 - VCCO  0.1 - V IO = 3 mA; VCC(A) = VCC(B) = 1.1 V 0.85 - 0.85 - V IO = 6 mA; VCC(A) = VCC(B) = 1.4 V 1.05 - 1.05 - V IO = 8 mA; VCC(A) = VCC(B) = 1.65 V 1.2 - 1.2 - V IO = 9 mA; VCC(A) = VCC(B) = 2.3 V 1.75 - 1.75 - V IO = 12 mA; VCC(A) = VCC(B) = 3.0 V 2.3 - 2.3 - V - 0.1 - 0.1 V IO = 3 mA; VCC(A) = VCC(B) = 1.1 V - 0.25 - 0.25 V IO = 6 mA; VCC(A) = VCC(B) = 1.4 V - 0.35 - 0.35 V IO = 8 mA; VCC(A) = VCC(B) = 1.65 V - 0.45 - 0.45 V IO = 9 mA; VCC(A) = VCC(B) = 2.3 V - 0.55 - 0.55 V IO = 12 mA; VCC(A) = VCC(B) = 3.0 V - 0.7 - 0.7 V - 1 - 5 A HIGH-level VI = VIH or VIL output voltage IO = 100 A; VCC(A) = VCC(B) = 0.8 V to 3.6 V LOW-level VI = VIH or VIL output voltage IO = 100 A; VCC(A) = VCC(B) = 0.8 V to 3.6 V II input leakage current DIR, OE input; VI = 0 V or 3.6 V; VCC(A) = VCC(B) = 0.8 V to 3.6 V IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCC(A) = VCC(B) = 3.6 V [3] - 5 - 30 A suspend mode A port; VO = 0 V or VCCO; VCC(A) = 3.6 V; VCC(B) = 0 V [3] - 5 - 30 A suspend mode B port; VO = 0 V or VCCO; VCC(A) = 0 V; VCC(B) = 3.6 V [3] - 5 - 30 A A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V - 5 - 30 A B port; VI or VO = 0 V to 3.6 V; VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V - 5 - 30 A IOFF power-off leakage current 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 7 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 7. Static characteristics …continued[1][2] At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter ICC 40 C to +85 C Conditions 40 C to +125 C Unit Min Max Min Max VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V - 10 - 55 A VCC(A) = 1.1 V to 3.6 V; VCC(B) = 1.1 V to 3.6 V - 8 - 50 A VCC(A) = 3.6 V; VCC(B) = 0 V - 8 - 50 A VCC(A) = 0 V; VCC(B) = 3.6 V 2 - 12 - A VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V - 10 - 55 A VCC(A) = 1.1 V to 3.6 V; VCC(B) = 1.1 V to 3.6 V - 8 - 50 A VCC(A) = 3.6 V; VCC(B) = 0 V 2 - 12 - A VCC(A) = 0 V; VCC(B) = 3.6 V supply current A port; VI = 0 V or VCCI; IO = 0 A B port; VI = 0 V or VCCI; IO = 0 A - 8 - 50 A A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI; VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V - 20 - 70 A A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI; VCC(A) = 1.1 V to 3.6 V; VCC(B) = 1.1 V to 3.6 V - 16 - 65 A [1] VCCO is the supply voltage associated with the output port. [2] VCCI is the supply voltage associated with the data input port. [3] For I/O ports, the parameter IOZ includes the input leakage current. Table 8. VCC(A) Typical total supply current (ICC(A) + ICC(B)) VCC(B) Unit 0V 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 0V 0 0.1 0.1 0.1 0.1 0.1 0.1 A 0.8 V 0.1 0.1 0.1 0.1 0.1 0.3 1.6 A 1.2 V 0.1 0.1 0.1 0.1 0.1 0.1 0.8 A 1.5 V 0.1 0.1 0.1 0.1 0.1 0.1 0.4 A 1.8 V 0.1 0.1 0.1 0.1 0.1 0.1 0.2 A 2.5 V 0.1 0.3 0.1 0.1 0.1 0.1 0.1 A 3.3 V 0.1 1.6 0.8 0.4 0.2 0.1 0.1 A 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 8 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 10. Dynamic characteristics Table 9. Typical dynamic characteristics at VCC(A) = 0.8 V and Tamb = 25 C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7; for wave forms see Figure 5 and Figure 6 Symbol Parameter Conditions VCC(B) 0.8 V tpd [1] 1.8 V 2.5 V 3.3 V 14.4 7.0 6.2 6.0 5.9 6.0 ns Bn to An 14.4 12.4 12.1 11.9 11.8 11.8 ns OE to An 16.2 16.2 16.2 16.2 16.2 16.2 ns OE to Bn 17.6 10.0 9.0 9.1 8.7 9.3 ns OE to An 21.9 21.9 21.9 21.9 21.9 21.9 ns OE to Bn 22.2 11.1 9.8 9.4 9.4 9.6 ns enable time ten 1.5 V propagation delay An to Bn disable time tdis 1.2 V Unit tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. Table 10. Typical dynamic characteristics at VCC(B) = 0.8 V and Tamb = 25 C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7; for wave forms see Figure 5 and Figure 6 Symbol Parameter tpd [1] Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V propagation delay An to Bn 14.4 12.4 12.1 11.9 11.8 11.8 ns Bn to An 14.4 7.0 6.2 6.0 5.9 6.0 ns OE to An 16.2 5.9 4.4 4.2 3.1 3.5 ns OE to Bn 17.6 14.2 13.7 13.6 13.3 13.1 ns OE to An 21.9 6.4 4.4 3.5 2.6 2.3 ns OE to Bn 22.2 17.7 17.2 17.0 16.8 16.7 ns enable time ten VCC(A) 0.8 V disable time tdis Conditions tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 9 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 C [1][2] Voltages are referenced to GND (ground = 0 V). Symbol Parameter power dissipation capacitance CPD [1] Conditions VCC(A) = VCC(B) Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V A port: (direction An to Bn); output enabled 0.2 0.2 0.2 0.3 0.4 0.5 pF A port: (direction An to Bn); output disabled 0.2 0.2 0.2 0.3 0.4 0.5 pF A port: (direction Bn to An); output enabled 9 9 10 10 11 13 pF A port: (direction Bn to An); output disabled 0.6 0.6 0.6 0.7 0.7 0.8 pF B port: (direction An to Bn); output enabled 9 9 10 10 11 13 pF B port: (direction An to Bn); output disabled 0.6 0.6 0.6 0.7 0.7 0.8 pF B port: (direction Bn to An); output enabled 0.2 0.2 0.2 0.3 0.4 0.5 pF B port: (direction Bn to An); output disabled 0.2 0.2 0.2 0.3 0.4 0.5 pF CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. [2] fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL =  . 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 10 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 12. Dynamic characteristics for temperature range 40 C to +85 C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7; for wave forms see Figure 5 and Figure 6. Symbol Parameter Conditions VCC(B) Unit 1.2 V  0.1 V 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V Min Max Min Max Min Max Min Max Min Max 0.5 9.0 0.5 6.7 0.5 5.8 0.5 4.9 0.5 4.8 VCC(A) = 1.1 V to 1.3 V tpd propagation delay An to Bn Bn to An 0.5 9.0 0.5 8.5 0.5 8.3 0.5 8.0 0.5 7.8 ns tdis disable time OE to An 0.5 11.8 0.5 11.8 0.5 11.8 0.5 11.8 0.5 11.8 ns OE to Bn 0.5 12.3 0.5 9.5 0.5 9.4 0.5 8.0 0.5 8.9 ns OE to An 1.1 14.4 1.1 14.4 1.1 14.4 1.1 14.4 1.1 14.4 ns OE to Bn 1.1 14.2 1.1 10.4 1.1 9.0 1.0 7.7 1.0 7.3 ns propagation delay An to Bn 0.5 8.5 0.5 5.6 0.5 4.7 0.5 4.4 0.5 4.1 ns Bn to An 0.5 6.7 0.5 5.6 0.5 5.3 0.5 5.2 0.5 5.0 ns disable time OE to An 0.5 8.6 0.5 8.6 0.5 8.6 0.5 8.6 0.5 8.6 ns OE to Bn 0.5 11.2 0.5 8.4 0.5 7.6 0.5 7.2 0.5 7.8 ns OE to An 1.1 8.7 1.1 8.7 1.1 8.7 1.1 8.7 1.1 8.7 ns OE to Bn 1.1 12.8 1.1 8.1 1.1 7.1 1.0 5.6 1.0 5.2 ns enable time ten ns VCC(A) = 1.4 V to 1.6 V tpd tdis enable time ten VCC(A) = 1.65 V to 1.95 V propagation delay An to Bn 0.5 8.3 0.5 5.3 0.5 4.5 0.5 3.8 0.5 3.5 ns Bn to An 0.5 5.8 0.5 4.7 0.5 4.5 0.5 4.3 0.5 4.1 ns tdis disable time OE to An 0.5 7.1 0.5 7.1 0.5 7.1 0.5 7.1 0.5 7.1 ns OE to Bn 0.5 10.9 0.5 7.8 0.5 6.9 0.5 6.0 0.5 5.8 ns ten enable time OE to An 1.0 6.8 1.0 6.8 1.0 6.8 1.0 6.8 1.0 6.8 ns OE to Bn 1.1 12.4 1.1 8.2 1.0 6.7 0.5 5.1 0.5 4.5 ns propagation delay An to Bn 0.5 8.0 0.5 5.2 0.5 4.3 0.5 3.3 0.5 2.9 ns Bn to An 0.5 4.9 0.5 4.4 0.5 3.8 0.5 3.3 0.5 3.1 ns disable time OE to An 0.5 5.1 0.5 5.1 0.5 5.1 0.5 5.1 0.5 5.1 ns OE to Bn 0.5 10.4 0.5 7.1 0.5 6.3 0.5 5.1 0.5 5.2 ns tpd VCC(A) = 2.3 V to 2.7 V tpd tdis enable time ten OE to An 0.5 4.8 0.5 4.8 0.5 4.8 0.5 4.8 0.5 4.8 ns OE to Bn 1.1 11.9 1.1 7.9 0.5 6.4 0.5 4.6 0.5 4.0 ns 0.5 7.8 0.5 5.0 0.5 4.1 0.5 3.1 0.5 2.7 ns VCC(A) = 3.0 V to 3.6 V tpd propagation delay An to Bn Bn to An 0.5 4.8 0.5 4.1 0.5 3.5 0.5 2.9 0.5 2.7 ns tdis disable time OE to An 0.5 4.9 0.5 4.9 0.5 4.9 0.5 4.9 0.5 4.9 ns OE to Bn 0.5 10.1 0.5 6.9 0.5 6.0 0.5 4.8 0.5 5.0 ns OE to An 0.5 4.0 0.5 4.0 0.5 4.0 0.5 4.0 0.5 4.0 ns OE to Bn 1.1 11.7 1.1 7.8 0.5 6.2 0.5 4.5 0.5 3.9 ns enable time ten [1] tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 11 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Table 13. Dynamic characteristics for temperature range 40 C to +125 C [1] Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7; for wave forms see Figure 5 and Figure 6 Symbol Parameter Conditions VCC(B) Unit 1.2 V  0.1 V 1.5 V  0.1 V 1.8 V  0.15 V 2.5 V  0.2 V 3.3 V  0.3 V Min Max Min Max Min Max Min Max Min Max 0.5 9.9 0.5 7.4 0.5 6.4 0.5 5.4 0.5 5.3 VCC(A) = 1.1 V to 1.3 V tpd propagation delay An to Bn Bn to An 0.5 9.9 0.5 9.4 0.5 9.2 0.5 8.8 0.5 8.6 ns tdis disable time OE to An 0.5 13.0 0.5 13.0 0.5 13.0 0.5 13.0 0.5 13.0 ns OE to Bn 0.5 13.6 0.5 10.5 0.5 10.4 0.5 8.8 0.5 9.8 ns OE to An 1.1 15.9 1.1 15.9 1.1 15.9 1.1 15.9 1.1 15.9 ns OE to Bn 1.1 15.7 1.1 11.5 1.1 9.9 1.0 8.5 1.0 8.1 ns An to Bn 0.5 9.4 0.5 6.2 0.5 5.2 0.5 4.9 0.5 4.6 ns Bn to An 0.5 7.4 0.5 6.2 0.5 5.9 0.5 5.8 0.5 5.5 ns enable time ten ns VCC(A) = 1.4 V to 1.6 V propagation delay tpd disable time tdis enable time ten OE to An 0.5 9.5 0.5 9.5 0.5 9.5 0.5 9.5 0.5 9.5 ns OE to Bn 0.5 12.4 0.5 9.3 0.5 8.4 0.5 8.0 0.5 8.6 ns OE to An 1.1 9.6 1.1 9.6 1.1 9.6 1.1 9.6 1.1 9.6 ns OE to Bn 1.1 14.1 1.1 9.0 1.1 7.9 1.0 6.2 1.0 5.8 ns VCC(A) = 1.65 V to 1.95 V propagation delay An to Bn 0.5 9.2 0.5 5.9 0.5 5.0 0.5 4.2 0.5 3.9 ns Bn to An 0.5 6.4 0.5 5.2 0.5 5.0 0.5 4.8 0.5 4.6 ns tdis disable time OE to An 0.5 7.9 0.5 7.9 0.5 7.9 0.5 7.9 0.5 7.9 ns OE to Bn 0.5 12.0 0.5 8.6 0.5 7.6 0.5 6.6 0.5 6.4 ns ten enable time OE to An 1.0 7.5 1.0 7.5 1.0 7.5 1.0 7.5 1.0 7.5 ns OE to Bn 1.1 13.7 1.1 9.1 1.0 7.4 0.5 5.7 0.5 5.0 ns propagation delay An to Bn 0.5 8.8 0.5 5.8 0.5 4.8 0.5 3.7 0.5 3.2 ns Bn to An 0.5 5.4 0.5 4.9 0.5 4.2 0.5 3.7 0.5 3.5 ns disable time OE to An 0.5 5.7 0.5 5.7 0.5 5.7 0.5 5.7 0.5 5.7 ns OE to Bn 0.5 11.5 0.5 7.9 0.5 7.0 0.5 5.7 0.5 5.8 ns tpd VCC(A) = 2.3 V to 2.7 V tpd tdis enable time ten OE to An 0.5 5.3 0.5 5.3 0.5 5.3 0.5 5.3 0.5 5.3 ns OE to Bn 1.1 13.1 1.1 8.7 0.5 7.1 0.5 5.1 0.5 4.4 ns 0.5 8.6 0.5 5.5 0.5 4.6 0.5 3.5 0.5 3.0 ns VCC(A) = 3.0 V to 3.6 V tpd propagation delay An to Bn Bn to An 0.5 5.3 0.5 4.6 0.5 3.9 0.5 3.2 0.5 3.0 ns tdis disable time OE to An 0.5 5.4 0.5 5.4 0.5 5.4 0.5 5.4 0.5 5.4 ns OE to Bn 0.5 11.2 0.5 7.6 0.5 6.6 0.5 5.3 0.5 5.5 ns OE to An 0.5 4.4 0.5 4.4 0.5 4.4 0.5 4.4 0.5 4.4 ns OE to Bn 1.1 12.9 1.1 8.6 0.5 6.9 0.5 5.0 0.5 4.3 ns enable time ten [1] tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 12 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 11. Waveforms VI VM An, Bn input GND tPHL tPLH VOH VM Bn, An output VOL 001aai475 Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. The data input (An, Bn) to output (Bn, An) propagation delay times VI OE input VM GND tPLZ tPZL VCCO output LOW-to-OFF OFF-to-LOW VM VX VOL tPZH tPHZ VOH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs enabled outputs disabled 001aai474 Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Table 14. Enable and disable times Measurement points Supply voltage Input[1] Output[2] VCC(A), VCC(B) VM VM VX VY 0.8 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH  0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH  0.3 V [1] VCCI is the supply voltage associated with the data input port. [2] VCCO is the supply voltage associated with the output port. 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 13 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state tW VI 90 % negative pulse VM VM 10 % 0V tf tr tr tf VI 90 % positive pulse VM VM 10 % 0V tW VEXT VCC VI RL VO G DUT RT RL CL 001aae331 Test data is given in Table 15. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Fig 7. Table 15. Load circuit for switching times Test data Supply voltage Input VCC(A), VCC(B) VI[1] t/V[2] Load CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ[3] 0.8 V to 1.6 V VCCI 1.0 ns/V 15 pF 2 k open GND 2VCCO 1.65 V to 2.7 V VCCI  1.0 ns/V 15 pF 2 k open GND 2VCCO 3.0 V to 3.6 V VCCI  1.0 ns/V 15 pF 2 k open GND 2VCCO [1] VCCI is the supply voltage associated with the data input port. [2] dV/dt  1.0 V/ns [3] VCCO is the supply voltage associated with the output port. 74AVC8T245 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 14 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 12. Typical propagation delay characteristics 001aai476 24 tpd (ns) (1) (2) (3) (4) (5) (6) tpd (ns) (1) 20 001aai477 21 17 16 12 13 (2) (3) (4) (5) (6) 8 4 9 0 20 40 60 0 20 CL (pF) 40 60 CL (pF) a. Propagation delay (An to Bn); VCC(A) = 0.8 V b. Propagation delay (An to Bn); VCC(B) = 0.8 V (1) VCC(B) = 0.8 V. (1) VCC(A) = 0.8 V. (2) VCC(B) = 1.2 V. (2) VCC(A) = 1.2 V. (3) VCC(B) = 1.5 V. (3) VCC(A) = 1.5 V. (4) VCC(B) = 1.8 V. (4) VCC(A) = 1.8 V. (5) VCC(B) = 2.5 V. (5) VCC(A) = 2.5 V. (6) VCC(B) = 3.3 V. (6) VCC(A) = 3.3 V. Fig 8. Typical propagation delay versus load capacitance; Tamb = 25 C 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 15 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 001aai478 7 001aai491 7 (1) tPLH (ns) tPHL (ns) (2) 5 (1) 5 (3) (2) (3) (4) (4) (5) (5) 3 3 1 1 0 20 40 60 0 20 40 CL (pF) a. LOW to HIGH propagation delay (An to Bn); VCC(A) = 1.2 V b. HIGH to LOW propagation delay (An to Bn); VCC(A) = 1.2 V 001aai479 7 60 CL (pF) 001aai480 7 (1) tPLH (ns) tPHL (ns) (1) 5 5 (2) (3) (2) (3) (4) (5) 3 (4) (5) 3 1 1 0 20 40 60 0 CL (pF) 20 40 60 CL (pF) c. LOW to HIGH propagation delay (An to Bn); VCC(A) = 1.5 V d. HIGH to LOW propagation delay (An to Bn); VCC(A) = 1.5 V (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. Fig 9. Typical propagation delay versus load capacitance; Tamb = 25 C 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 16 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 001aai481 7 (1) tPLH (ns) 001aai482 7 tPHL (ns) 5 (1) 5 (2) (3) (2) (3) (4) 3 (4) (5) 3 (5) 1 1 0 20 40 60 0 20 40 CL (pF) a. LOW to HIGH propagation delay (An to Bn); VCC(A) = 1.8 V b. HIGH to LOW propagation delay (An to Bn); VCC(A) = 1.8 V 001aai483 7 tPLH (ns) 60 CL (pF) 001aai486 7 tPHL (ns) (1) 5 (1) 5 (2) (2) (3) (3) (4) 3 3 (4) (5) (5) 1 1 0 20 40 60 0 CL (pF) 20 40 60 CL (pF) c. LOW to HIGH propagation delay (An to Bn); VCC(A) = 2.5 V d. HIGH to LOW propagation delay (An to Bn); VCC(A) = 2.5 V (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. Fig 10. Typical propagation delay versus load capacitance; Tamb = 25 C 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 17 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 001aai485 7 tPLH (ns) 001aai484 7 tPHL (ns) (1) 5 (1) 5 (2) (2) (3) (3) 3 3 (4) (4) (5) (5) 1 1 0 20 40 60 0 CL (pF) 20 40 60 CL (pF) a. LOW to HIGH propagation delay (An to Bn); VCC(A) = 3.3 V b. HIGH to LOW propagation delay (An to Bn); VCC(A) = 3.3 V (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. Fig 11. Typical propagation delay versus load capacitance; Tamb = 25 C 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 18 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 13. Package outline TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 12 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 REFERENCES IEC JEDEC JEITA MO-153 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 12. Package outline SOT355-1 (TSSOP24) 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 19 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state DHVQFN24: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5 x 5.5 x 0.85 mm B D SOT815-1 A A E A1 c detail X terminal 1 index area C e1 terminal 1 index area e y1 C v M C A B w M C b 2 y 11 L 12 1 e2 Eh 24 13 23 14 X Dh 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 e2 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 5.6 5.4 4.25 3.95 3.6 3.4 2.25 1.95 0.5 4.5 1.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT815-1 --- --- --- EUROPEAN PROJECTION ISSUE DATE 03-04-29 Fig 13. Package outline SOT815-1 (DHVQFN24) 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 20 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 14. Abbreviations Table 16. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 17. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC8T245 v.5 20121227 Product data sheet - 74AVC8T245 v.4 Modifications: 74AVC8T245 v.4 Modifications: • Table 4: conditions ICC and IGND changed (errata). 20111208 • Product data sheet - 74AVC8T245 v.3 Legal pages updated. 74AVC8T245 v.3 20110928 Product data sheet - 74AVC8T245 v.2 74AVC8T245 v.2 20090428 Product data sheet - 74AVC8T245 v.1 74AVC8T245 v.1 20080711 Product data sheet - - 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 21 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AVC8T245 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 22 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74AVC8T245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 December 2012 © NXP B.V. 2012. All rights reserved. 23 of 24 74AVC8T245 NXP Semiconductors 8-bit dual supply translating transceiver; 3-state 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Typical propagation delay characteristics . . 15 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 19 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 21 Legal information. . . . . . . . . . . . . . . . . . . . . . . 22 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 22 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Contact information. . . . . . . . . . . . . . . . . . . . . 23 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2012. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 27 December 2012 Document identifier: 74AVC8T245
74AVC8T245PW 价格&库存
很抱歉,暂时无法提供与“74AVC8T245PW”相匹配的价格&库存,您可以联系我们找货
