74HC4520PW-Q100J
74HC4520PW-Q100J
    NEXPERIA(安世)
    NEXPERIA - 74HC4520PW-Q100J - Counter, Binary, Synchronous, Up, 69 MHz, 15 Count, 2 V to 6 V Supply,...
74HC4520PW-Q100J 数据手册
74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter Rev. 3 — 9 October 2020 Product data sheet 1. General description The 74HC4520-Q100; 74HCT4520-Q100 are dual 4-bit internally synchronous binary counters with two clock inputs (nCP0 and nCP1). They have buffered outputs from all 4 bit positions (nQ0 to nQ3), and an asynchronous master reset input (nMR). The counter advances on either the LOW-to-HIGH transition of nCP0 when nCP1 is HIGH. It also advances on the HIGH-to-LOW transition of nCP1 if nCP0 is LOW. Either nCP0 or nCP1 may be used as the clock input to the counter. The other clock input may be used as a clock enable input. A HIGH on nMR resets the counter (nQ0 to nQ3 = LOW) independent of nCP0 and nCP1. Inputs include clamp diodes. It enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Wide supply voltage range from 2.0 V to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Input levels: • For 74HC4520-Q100: CMOS level • For 74HCT4520-Q100: TTL level ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) 3. Applications • • • Multistage synchronous counting Multistage asynchronous counting Frequency dividers Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter 4. Ordering information Table 1. Ordering information Type number Package 74HC4520D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT4520D-Q100 74HC4520PW-Q100 -40 °C to +125 °C 5. Functional diagram 1Q0 3 1 1CP0 1Q1 4 2 1CP1 1Q2 5 1Q3 6 7 1MR 2Q0 11 9 2CP0 2Q1 12 10 2CP1 2Q2 13 2Q3 14 15 2MR 001aae698 Fig. 1. Functional diagram 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 0 1 2 nCP0 nCP1 nMR 3 4 nQ0 nQ1 nQ2 nQ3 001aae707 Fig. 2. Timing diagram 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 2 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter nQ0 FF1 CP nCP1 nQ1 Q FF2 CP RD Q nCP0 nQ2 Q FF3 CP RD Q nQ3 Q FF4 CP RD Q Q RD Q nMR aaa-015608 Fig. 3. Logic diagram for one counter 6. Pinning information 6.1. Pinning 74HC4520 74HCT4520 1CP0 1 16 VCC 1CP1 2 15 2MR 1Q0 3 14 2Q3 1Q1 4 13 2Q2 1Q2 5 12 2Q1 1Q3 6 11 2Q0 1MR 7 10 2CP1 GND 8 9 2CP0 74HC4520 1CP0 1 16 VCC 1CP1 2 15 2MR 1Q0 3 14 2Q3 1Q1 4 13 2Q2 1Q2 5 12 2Q1 1Q3 6 11 2Q0 1MR 7 10 2CP1 GND 8 9 2CP0 aaa-015593 aaa-015592 Fig. 4. Pin configuration SOT109-1 (SO16) Fig. 5. Pin configuration SOT403-1 (TSSOP16) 6.2. Pin description Table 2. Pin description Symbol Pin Description 1CP0, 2CP0 1, 9 clock input (LOW-to-HIGH edge-triggered) 1CP1, 2CP1 2, 10 clock input (HIGH-to-LOW edge-triggered) 1Q0 to 1Q3 3, 4, 5, 6 output 1MR, 2MR 7, 15 asynchronous master reset input (active HIGH) GND 8 ground (0 V) 2Q0 to 2Q3 11, 12, 13, 14 output VCC 16 supply voltage 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 3 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = positive-going transition; ↓ = negative-going transition. nCP0 nCP1 nMR Mode ↑ H L counter advances L ↓ L counter advances ↓ X L no change X ↑ L no change ↑ L L no change H ↓ L no change X X H nQ0 to nQ3 = LOW 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7.0 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current VO = -0.5 V to VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW 74HCT4520-Q100 Unit [1] [1] For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74HC_HCT4520_Q100 Product data sheet Conditions 74HC4520-Q100 Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V 0 - VCC 0 - VCC V 0 - VCC 0 - VCC V -40 +25 +125 -40 +25 +125 °C VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 4 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC4520-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V μA VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80.0 - 160.0 μA CI input capacitance - 3.5 - - - - - pF 74HCT4520-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V VOL 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 5 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80.0 - 160.0 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A pin nCP0, nCP1 - 80 288 - 360 - 392 μA pin nMR - 150 540 - 675 - 735 μA - 3.5 - - - - - pF CI input capacitance μA 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 8. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 77 240 - 300 - 360 ns VCC = 4.5 V - 28 48 - 60 - 72 ns VCC = 5.0 V; CL = 15 pF - 24 - - - - - ns - 22 41 - 51 - 61 ns VCC = 2.0 V - 77 240 - 300 - 360 ns VCC = 4.5 V - 28 48 - 60 - 72 ns VCC = 5.0 V; CL = 15 pF - 24 - - - - - ns VCC = 6.0 V - 22 41 - 51 - 61 ns - 44 150 - 190 - 225 ns - 16 30 - 38 - 45 ns - 13 - - - - - ns - 13 26 - 33 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns 74HC4520-Q100 tpd propagation delay nCP0 to nQn; see Fig. 6 [1] VCC = 6.0 V nCP1 to nQn; see Fig. 6 tPHL [1] HIGH to LOW nMR to nQn; see Fig. 6 propagation VCC = 2.0 V delay VCC = 4.5 V VCC = 5.0 V; CL = 15 pF VCC = 6.0 V tt transition time 74HC_HCT4520_Q100 Product data sheet nQn; see Fig. 6 [2] All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 6 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter Symbol Parameter tW Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 80 22 - 100 - 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 120 39 - 150 - 180 - ns VCC = 4.5 V 24 14 - 30 - 36 - ns VCC = 6.0 V 20 11 - 26 - 31 - ns VCC = 2.0 V 0 -28 - 0 - 0 - ns VCC = 4.5 V 0 -10 - 0 - 0 - ns VCC = 6.0 V 0 -8 - 0 - 0 - ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 6 19 - 4.8 - 4 - MHz VCC = 4.5 V 30 58 - 24 - 20 - MHz - 68 - - - - - MHz 35 69 - 28 - 24 - MHz - 29 - - - - - pF VCC = 4.5 V - 28 53 - 66 - 80 ns VCC = 5.0 V; CL = 15 pF - 24 - - - - - ns VCC = 4.5 V - 25 53 - 66 - 80 ns VCC = 5.0 V; CL = 15 pF - 24 - - - - - ns HIGH to LOW nMR to nQn; see Fig. 6 propagation VCC = 4.5 V delay VCC = 5.0 V; CL = 15 pF - 16 35 - 44 - 53 ns - 13 - - - - - ns - 7 15 - 19 - 22 ns 20 10 - 25 - 30 - ns 20 12 - 25 - 30 - ns pulse width nCP0, nCP1 HIGH or LOW; see Fig. 7 nMR HIGH; see Fig. 7 trec tsu fmax recovery time nMR to nCP0, nCP1; see Fig. 7 set-up time maximum frequency nCP0 to nCP1; nCP1 to nCP0; see Fig. 6 nCP0, nCP1; see Fig. 7 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD power dissipation capacitance VI = GND to VCC; VCC = 5 V; fi = 1 MHz [3] nCP0 to nQn; see Fig. 6 [1] 74HCT4520-Q100 tpd propagation delay nCP1 to nQn; see Fig. 6 tPHL tt tW [1] transition time nQn; see Fig. 6 [2] pulse width nCP0, nCP1 HIGH or LOW; see Fig. 7 VCC = 4.5 V VCC = 4.5 V nMR HIGH; see Fig. 7 VCC = 4.5 V 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 7 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter Symbol Parameter trec Conditions 25 °C tsu set-up time nCP0 to nCP1; nCP1 to nCP0; see Fig. 6 fmax maximum frequency nCP0, nCP1; see Fig. 7 VCC = 4.5 V VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [1] [2] [3] -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 0 -8 - 0 - 0 - ns 16 6 - 20 - 24 - ns 30 58 - 24 - 20 - MHz - 64 - - - - - MHz - 24 - - - - - pF recovery time nMR to nCP0, nCP1; see Fig. 7 VCC = 4.5 V CPD -40 °C to +85 °C power dissipation capacitance VI = GND to VCC - 1.5 V; VCC = 5 V; [3] fi = 1 MHz tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 8 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter 11.1. Waveforms and test circuit VI VM nCP0 input 0V VI nCP1 input VM 0V 0V tsu tsu VI nMR input VM 0V tPHL tPLH VOH tPHL 90 % nQn output VM 10 % VOL tt tt 001aae702 Measurement points are given in Table 8. The logic levels VOH and VOL are typical output voltage levels that occur with the output load. Fig. 6. nCP0 and nCP1 set-up times, propagation delays and output transition times 1/fmax VI nCP1 input (nCP0 = LOW) VM 0V tW VI nCP0 input (nCP1 = HIGH) VM 0V tW VI nMR input VM 0V tW trec 001aae701 Measurement points are given in Table 8. The logic levels VOH and VOL are typical output voltage levels that occur with the output load. Fig. 7. nMR recovery time, minimum nCP0, nCP1, nMR pulse widths and maximum frequency Table 8. Measurement points Type Input Output VM VI VM 74HC4520-Q100 0.5 × VCC GND to VCC 0.5 × VCC 74HCT4520-Q100 1.3 V GND to 3 V 1.3 V 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 9 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI VCC VO DUT RT RL S1 open CL 001aad983 Test data is given in Table 9. Test circuit definitions: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance. S1 = Test selection switch Fig. 8. Test circuit for measuring switching times Table 9. Test data Type Input S1 position Load VI tr, tf CL RL tPHL, tPLH 74HC4520-Q100 GND to VCC 6 ns 15 pF, 50 pF 1 kΩ open 74HCT4520-Q100 GND to 3 V 6 ns 15 pF, 50 pF 1 kΩ open 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 10 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 11 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT403-1 (TSSOP16) 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 12 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4520_Q100 v.3 20201009 Product data sheet - Modifications: • • • 74HC_HCT4520_Q100 v.2 20190214 Modifications: • • • 74HC_HCT4520_Q100 v.1 74HC_HCT4520_Q100 Product data sheet 74HC_HCT4520_Q100 v.2 Type number 74HC4520PW-Q100 (SOT403-1/TSSOP16) added. Section 2 updated. Table 4: Derating values for Ptot total power dissipation have been updated. Product data sheet - 74HC_HCT4520_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HC4520PW-Q100 (SOT403-1) removed. 20141204 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 - © Nexperia B.V. 2020. All rights reserved 13 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 14 / 15 Nexperia 74HC4520-Q100; 74HCT4520-Q100 Dual 4-bit synchronous binary counter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................6 11.1. Waveforms and test circuit........................................ 9 12. Package outline........................................................ 11 13. Abbreviations............................................................ 13 14. Revision history........................................................13 15. Legal information......................................................14 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 October 2020 74HC_HCT4520_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 9 October 2020 © Nexperia B.V. 2020. All rights reserved 15 / 15
74HC4520PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC4520PW-Q100J”相匹配的价格&库存,您可以联系我们找货
74HC4520PW-Q100J
  • 1000+7.07178
  • 10000+6.26817
  • 100000+5.30384
